05-08-2024, 02:03 PM | #1 |
Ü
79
Rep 474
EGR fault : solved
EDIT updated Original Post
EGR valve faults . Been having the Drive-Chain fault flash up recently on cold start ups and the car had felt sluggish in the lower gear changes. View post on imgur.com Update : Originally Fitted a Aftermarket one (not an OEM or genuine). the BorgWarner 710327D (Wahler) supplied BMW for EGR valve purchased direct from Autodoc. These have a different design when it comes the valve shaft compared to the original. Problem Solved : Since ordered a replacement direct from a German supplier that is the same as the original design with the thinner valve shaft. https://www.hubauer-shop.de/en/egr-v...717810871.html Roughly 160 euro posted. Ran the ISTA+ reset adaptations procedure before install and cleared all faults, running back to how it should be. Last edited by brtttt; 06-05-2024 at 04:19 AM.. Reason: update |
05-08-2024, 03:04 PM | #2 |
Rep 2,122
Drives: F30 335d
For the egr valve always go genuine. I replaced mine with a pattern one (before bmw started doing recalls for it) and got a fault code for the valve not closing fully. I did the adaptation reset correctly too.
Put the original back in and the fault code went away. |
05-08-2024, 03:34 PM | #3 | |
Ü
79
Rep 474
I did go for the wahler brand which is suppose to be the original brand bmw use, how true this is I don’t know. |
05-08-2024, 11:54 PM | #4 |
Rep 524
I would try to remove errors to see if they are permanent or just one off incident.
If they are permanent there should be a warranty for EGR, however, if it has visible mechanical damage due to improper installation this may be difficult. What's car mileage?
1995 E34 525td auto • 2016 F30 320ed auto
brtttt78.50 |
05-09-2024, 03:15 AM | #7 | |
Ü
79
Rep 474
I fitted it myself and made sure not to damage anything but will try removing the faults as you suggested. |
06-13-2024, 12:27 PM | #9 |
Rep 1,467
Good stuff. I got a genuine one for £180 from a BMW dealer on ebay for the reasons you discovered with pattern ones (I never buy pattern with important stuff), but in my case it turned out to be a bad O2 sensor. Exactly the same symptoms though. Glad you got it sorted
