02-03-2024, 10:41 AM | #1 | |
Rep 38
MHD coolant mode option
MHD has the checkbox for "coolant mode" turned on by default.
According to the MHD manual it means this: Quote:
My question: coolant mode is turned on by default but is this something I really want? Reading the description I would say I should turn it off, I don't live in a hot climate. I am confused about this setting as it is turned on by default. (Note: for info on the difference with the other cooling option see this post: https://f30.bimmerpost.com/forums/sh...85&postcount=5) |
02-03-2024, 10:48 AM | #2 |
Rep 3,879
You sure it is on by default!? Doesn't ring a bell...
02-07-2024, 08:04 AM | #4 |
Rep 250
Drives: 2014 BMW 228i, 2017 BMW M240i
Not sure what MHD's coolant mode is but in BM3 there is a "MAX cooling mode" which sounds similar. Essentially all it does is have the fans constantly running and the pump is always on. I'd recommend leaving it off as you said since this makes it more difficult for you to reach your operating temp.
