BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY: F30 Surround view retrofit
Studio RSR
      02-22-2019, 02:55 PM   #111
svhout
Drives: BMW F31
Hi there,
just finisht the installation and programming but stil have no view. Just a black screen with the buttons greyed out.
I think i need some more programming. Somebody who can solve the problem or give an excact description of what to programm?
      02-22-2019, 04:05 PM   #112
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Originally Posted by svhout View Post
Hi there,
Did you add "508" (can't have 507 and 508 together), 3AG and 5DL in your VO? Did you code the FEM, REM, HU_CIC/NBT, TRSVC, ICM, and PMA(if equipped) modules afterwards?
Run ISTA diagnostic and will give you a good sense of directions. Or just post the errors here and we can help you.
Do a search for ISTA on this forum and you should be able to download it and also find instructions on how to use it.
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      02-23-2019, 04:33 AM   #113
svhout
Drives: BMW F31
Yessss finaly. There was one setting which was not set correctly.
Now it's working
Thanks!!
Up to the next project => Top view
      04-08-2019, 01:27 PM   #114
artekniem
Bob
Drives: 2018 BMW 430I GRAN COUPE
jkwhar,
I added 5DL, based upon earlier instructions, and I am wondering what 508 and 3AG are?
      04-11-2019, 10:25 AM   #115
jkwhar
Originally Posted by artekniem View Post
jkwhar,
I actually just replied to your PM but here is what I wrote just incase someone else was wondering.
508 is front and rear PDC while 507 is just rear PDC and 3AG is reverse camera.
If you already have a reserver camera, 3AG (and technically you will also have 507 for rear pdc) will already be in your VO list. But if you don't, you will need to add 3AG for the reverse camera. For this retrofit to work, you need both the front and rear pdc which you will need to add 508 (but remove 507 if you already have the rear pdc only)
Reason why you only see 5DL being mentioned is b/c it depends on what options you already have on your car. Some ppl have reverse camera which will also have rear PDC. So their VO will already have 507 and 3AG. But someone elses car may not having anything and those two option code will be missing and needs to be added.
Hope that clears it up!
      06-22-2019, 02:12 PM   #116
Sanelko
Sanelko's Avatar
70
Drives: 2012 Jet Black 328i
https://f30.bimmerpost.com/forums/sh...7#post24943767
Just posted in classifieds for someone interested in doing this. Ended up getting F80 mirrors with everything included so no longer need these.
      07-09-2019, 06:14 PM   #117
Sanelko
Sanelko's Avatar
70
By the way, you can use the following to couple your short rearview HSD with the longer one provided with the surroundview HSD kit: https://www.co-star.co.uk/9307/hsd-a...hsd-neup-neup/
      10-04-2019, 06:40 AM   #118
SantaEugence
Drives: F30 330d xDrive Auto
Has anyone managed to fit the newer surround view with the ICAM for 360 degree view? I’ve got the rear cam just seems a huge amount of hassle to fit the other cams and not even get a full view round the car (keep scraping the front bumper on things so this would be invaluable)
      10-24-2019, 12:19 AM   #119
hegi
Drives: f31
i am selling my whole kit
https://f30.bimmerpost.com/forums/sh....php?t=1663291
      01-28-2020, 03:49 AM   #120
r0b3r
Drives: Bmw F
Hi, do you know if it is possible to activate bmw f80 side cameras in motion and how? thanks.
      05-24-2020, 04:46 AM   #121
EL_Capitan
Drives: BMW F32 440ix 2019
2019 BMW 440ix  [0.00]
Hi guys,
I am still not sure... is it possible to retrofit Top View without the side view cameras in the bumper? Had those on my 2014 F32 and never used them. My new 2019 F32 has just Reverse Cam and Full PDC.
Or is there a way to code in just the Top View via FDL coding, so the other options for Side View are not set active?
Thank you for your help.
      08-09-2020, 09:45 AM   #122
freespirit
freespirit's Avatar
83
Drives: f30 2016 BMW 328i
Sub'ed
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop
      08-10-2020, 02:18 AM   #123
David80
Drives: 328i
Anyone can help me, i just retrofitted surround view for my F36. VO code 5DL 3AG 508 as your guide but why my car image not in center position ? It driff to the right.
Thanks in advance
      08-10-2020, 12:31 PM   #124
steelerfan
steelerfan's Avatar
163
Drives: 2017 X5 Silver
Hey guys, i'm selling a complete kit here... those looking to do this retrofit will save a lot of money if you want to purchase the kit i put together but never installed before i sold my car.
Click me
      08-10-2020, 01:59 PM   #125
freespirit
freespirit's Avatar
83
Can someone please tell me if it's possible to add front view camera as well as part of this retrofit?
fyi ... i have front and rear pdc and rear view camera from factory and I am planning to do park assist retrofit as well along with this.
Thanks
      08-11-2020, 11:05 AM   #126
David80
Drives: 328i
Thanks in advance
Nobody can help me ?
      08-29-2020, 09:04 PM   #127
jkwhar
I'll be selling my surround view full kit if anyone is interested!
      09-18-2020, 12:33 PM   #128
jkwhar
Thanks in advance
Did you calibrate it with ISTA?
      10-17-2020, 12:30 PM   #129
catolard
Drives: BMW X3 F25 3.0d XDrive
2012 BMW X3  [0.00]
Hi,
First of all, so many thanks for all information here. That's really really great.
I decided to change my mirrors and add the top view. There's one thing I don't understand. Today I start the job, and .. regarding the HSD wire inside the door panel, you speak a lot about a wire buying on ebay - si I buy exactly the same of course :
“FAKRA HSD LVDS Straight Female to FAKRA HSD LVDS Right Angle Female Dacar 535 4-Core 1M”, with a pin chart of “1-4, 2-3, 3-2, 4-1”
But the issue is that it seems that we need to have straight female on both side, and not a right angle on one side, isn't it ?
straight female :
right angle :
Is there something wrong with my analysis ?
Many thanks for your help.
Catolard
      10-17-2020, 07:42 PM   #130
freespirit
freespirit's Avatar
83
Originally Posted by catolard View Post
Hi,
"FAKRA HSD LVDS Straight Female to FAKRA HSD LVDS Right Angle Female Dacar 535 4-Core 1M", with a pin chart of "1-4, 2-3, 3-2, 4-1"
straight female :
right angle :
Catolard
No, you need right angle at the door connector. I did this retrofit on my f30 successfully just a month back.
      10-18-2020, 02:22 AM   #131
catolard
2012 BMW X3  [0.00]
Hello freespirit.
Many thanks for your answer. Have you look my pictures ? if I want to plug the coonnector with right angle, it seems that I have to break the side of the plastic plug. You do that ?
And on the other side you use the dremel to modify the orientation, that's right ?
Many many thanks.
EDIT - It seems that's it's not exactly the same connector. I find this pictures for a F30 - and compare to F25
So it seems that I need a straight female and not a right angle for a F25. Is that right ?
Catolard
      10-18-2020, 09:41 AM   #132
freespirit
freespirit's Avatar
83
Hello freespirit.
Many many thanks.
Catolard
Ooh I'm so sorry. I didn't realize you're installing it on F25. Yes, looking at the connector you need a straight connector not right angle.
See if you can just swap the sides. Use the right angle connector inside the mirror and straight connector to door plug.
One more clue if you are following roxxor guide, he mentioned to rotate the HSD internal cable 90 degrees. That worked for right side mirror in my case but for left side, I got an error top view camera not connected in ISTA. Finally I had to rotate 270 degrees anti-clockwise to make it work. So my suggestion would be not to connect the mirror cable to door plug yet. Instead connect the internal HSD directly to mirror cable, complete your coding and make sure everything working fine. By now you will know the connector positions so you can avoid lot of dremel and door plug removal work.
