01-14-2017, 08:53 AM | #1 |
Rep 621
First problem with the 340i this morning at 14k miles
Low coolant warning. Took it in to top it off. Took a quart! Seems like a lot. Discovered the 2 sort-of-separate reservoirs. Not sure if they're completely separate or not?
The dude at the BMW service said that if you drain the big one, the little one will empty too, which i thought was either strange/wrong - why have two filler caps if they connect somewhere?
2021 M2C, HS / 6MT
2019 Mini Cooper S Hardtop 4 Door / 6MT 2022 Mini Countryman All4 JCW No longer with me: 2018 Golf R, 2017 F80 M3, 2016 F30 340i xDrive |
01-14-2017, 05:46 PM | #3 |
Rep 703
It's common on the b58 to need coolant added sometime after purchase.
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
01-15-2017, 01:11 PM | #7 |
Member
28
Rep 344
Got a low coolant warning at 12.5K miles after one year of driving, needed 2-3 cups to re-fill.
Present - 2016 340i, Alpine White, Black, M-sport, 6-spd, Track Handling, Tech pkgs
Past - 2011 E90 335i, Alpine White, Ivory, Sport, Premium, Steptronic Past - 2008 E90 335i, Titanium Silver, Dakota Grey, ZSP, Steptronic, 6FL, Wagner FMIC, Bilstein B12 Pro-kit, M3 control arms, SS F/R brake lines |
mwh2009289.00 |
01-15-2017, 03:53 PM | #8 |
Rep 3,622
I had this issue at 7700 miles. I have done numerous visual tests and now it looks like I am below the minimum marker in the tank again. I am at 13.6k mikes.
It looks like coolant is evaporating and drying out right below my coolant cap. I am on a business trip away from my car but when i get home i will snap a picture of it. BMW has done this before: a bad seal on the cap causes slow evaporation. Everyone reporting this seems to have an early production 340i. I'm thinking the batch of caps is bad. It makes no sense for an engine to burn coolant like this.
BMW CCA Member #516012
01-15-2017, 04:05 PM | #9 | |
Rep 4,516
2 reservoirs Larger one is for engine cooling system. 2nd smaller one is for water to air charge cooler integrated into intake manifold
Current '22 X3M LCI.. |
01-15-2017, 10:32 PM | #10 | |
Member
28
Rep 344
01-16-2017, 04:17 AM | #11 |
Rep 703
I don't have an early production 340i. Mines was built in July 2017 and I have the same problem. I would be interested to know if the M140/240 guys have this issue also.
01-18-2017, 10:18 PM | #12 |
Rep 202
01-19-2017, 07:31 AM | #14 |
Rep 621
It's the same coolant - the service guy at BMW topped off both reservoirs from the same jug
2021 M2C, HS / 6MT
01-19-2017, 11:01 PM | #16 |
Member
28
Rep 344
I tracked my car at an all-day HPDE, seven 20min+ sessions. No signs of overheating and the oil temp didn't budge, unlike my previous N54 335I at the same track.
01-20-2017, 06:32 AM | #17 | |
Rep 703
sttlondon46.50 |
01-20-2017, 08:43 AM | #18 | ||
Rep 1,270
01-20-2017, 09:30 AM | #19 | ||
Rep 3,622
01-20-2017, 09:50 AM | #20 |
Cheapskate
4448
Rep 4,993
that's really not ok imo. if i do a coolant flush, it might take 2-3 thermostat cycles to get it topped off, and that's worst case scenario. 1000s of miles and some people having to do it twice indicates there is an issue, however minute it may be. i would not say that's typical or normal at all.
