03-21-2018, 07:01 AM | #1 |
Rep 6
Problem F33 (Convertible) Folding Mirrors with Comfort Access
Hi Guys,
New to the forum and just got myself up and started coding. I'm having an issue coding folding mirrors on remote and comfort access. Previously the car was allowing me to fold and unfold by comfort access handle and to fold by remote while standing within the range of the comfort access (ie. next to the door handle!) When I follow the cheat sheets I can code all the parameters required to enable cfolding and unfolding by remote and comfort access except the last one. There are two duplicate copies of: ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN - the first one cannot be edited and is set to not active. the second, which can be changed, is set to active. I've found several old posts on this issue but neither seems to help. POST_1 POST_2 Previously, the car would fold mirrors by handle and remote while I was standing next to the door (ie. within range of comfort access) and would do the same for unfold. I can now get it to unfold mirrors with long range remote and by handle (all good) but folding mirrors now only works with remote while I am standing within range of comfort access. Folding by handle has stopped working. I am using Esys Launcher Premium 2.8.0.143 while waiting to get activation codes for v3 Pro and am using v63.3 pzdata. Please can anyone shed any light on this or help me to get it sorted? thanks... Adrian. Last edited by AidyBee; 03-21-2018 at 01:52 PM.. Reason: I got the Chassis wrong - I have an F33 not an F32 - Doh. |
03-21-2018, 09:27 AM | #2 |
Rep 2,302
KOMFORT_SCHLIESSEN from 0F (1,5S) to 1 (0,1s) and the mirrors will fold immediately.
ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN looks the same to me, but I have not changed anything there. |
03-21-2018, 11:23 AM | #3 |
Rep 6
Thanks atzebmw - I know about the time delay; I'm not worried about that. I'm trying to get the car to fold mirrors if I press lock on the keyfob for longer than 1.5 sec (standard delay) OR if I hold the lock portion of the door handle for longer than 1.5 sec.
Cheat codes I have seen on this say that I need to set: FEM_BODY | 3053 | KOMFORTOEFFNUNG_FB to aktiv (unfold mirrors on Keyfob) FEM_BODY | 3053 | KOMFORTSCHLIESSUNG_FB to aktiv (fold mirrors on keyfob) FEM_BODY | 3110 | ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN to aktiv (unfold mirrors on key or CA) FEM_BODY | 3110 | ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN to aktiv (fold mirrors on key or CA) I have coded the first 3 but the last one will not code as there are two duplicate entries for ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN - one that can be edited and is set, and one that cannot be edited and is permanently set to nicht_aktiv. |
03-22-2018, 05:07 PM | #4 |
Rep 6
Just to close this out, all working having added an FDL that isnt mentioned in most descriptions on how to implement folding mirrors.
My F33 at least requied FEM_BODY | 3053 | KOMFORTSCHLIESSUNG_PA to AKTIV. For the record and to help others, I found the last piece of the puzzle here: http://f80.bimmerpost.com/forums/sho....php?t=1241750 |
05-03-2019, 05:16 AM | #5 | |
Rep 102
05-05-2019, 12:05 PM | #6 | ||
Rep 23
09-15-2019, 12:17 PM | #8 |
Rep 2
Hi,
Has anyone had any success at programming the F33 convertible 4 series for the mirror folding to work? I have followed all available guides and have changed numerous settings (including the below) to active but none seem to work. Any suggesstions? FEM_BODY | 3053 | KOMFORTOEFFNUNG_FB to aktiv (unfold mirrors on Keyfob) FEM_BODY | 3053 | KOMFORTSCHLIESSUNG_FB to aktiv (fold mirrors on keyfob) FEM_BODY | 3110 | ASP_AUSKLAPPEN_NACH_KOMFORTSCHLIESSEN to aktiv (unfold mirrors on key or CA) FEM_BODY | 3110 | ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN to aktiv (fold mirrors on key or CA) |
01-14-2020, 12:14 PM | #9 | |
Rep 2
Drives: 2014 BMW 435i F33 cabriolet
Poochie9104.50 |
03-14-2020, 02:26 PM | #10 | |
Rep 165
