BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Restore to default in Esys
proTUNING Freaks
      07-19-2021, 03:24 AM   #23
atzebmw
Drives: Tesla Model 3
Originally Posted by Abarth695 View Post
Hi,
Can you make sense of the message. It seems from what I can understand the vcm is locked and or not allowing the code to factory.
I tried to inject cafd and this gives same message
Thank you
I think now i have to ask which car this is?
Is it a G-series car?
Because i wonder a bit about the ecus, which i have never seen on an F3x.
The coding for G-series cars works partially differently.
The message with the VCM is normal because most people deactivate the update of the VCM.
If it bothers you, you can reactivate the update from the VCM via options-> settings-> options and the first VCM update message will not appear again.
The only problem i see is the coding of the DSC_VIP_IB4 which doesn't work.
A quick search on google showed the result that other people also have the problem with this control unit.
But i don't know why this happens.
      07-19-2021, 08:20 AM   #24
MM2
MM2's Avatar
Australia
Drives: M2 G87
2024 M2  [0.00]
No, it’s for an f40
All other ecus have been fine but this doesn’t want to change back
Can you tell me why these boxes are always told to be unchecked?
What does activating them do, so I can understand more
Thanks
      07-19-2021, 03:34 PM   #25
atzebmw
I think @Almaretto explained that here quite well
https://f30.bimmerpost.com/forums/sh...14&postcount=2
Another question.
When you connect the car with E-Sys you choose S18A?
      07-19-2021, 04:22 PM   #26
MM2
MM2's Avatar
Australia
Drives: M2 G87
2024 M2  [0.00]
Wil read post and yes s18 with my latest data
      07-19-2021, 04:30 PM   #27
MM2
MM2's Avatar
Australia
Drives: M2 G87
2024 M2  [0.00]
Ok so in my case I should check the update vcm and code to factory dsc and see if this works. I assume this will give the authority to write to vcm which the error message is saying I don’t have. When finished uncheck the box
      07-28-2021, 09:28 AM   #28
scotsman335dxDrive
scotsman335dxDrive's Avatar
Scotland
60
Drives: 335d xDrive M Sport Plus
Originally Posted by atzebmw View Post
Almost right...
Open E-Sys
-> left menu "coding"
-> connect with car
-> Read FA
-> activate FA
-> Read SVT (VCM) or Read (Ecu)
-> Mark the ecu you want to code
-> click "code" on section "coding" on bottom right hand site or at the ecu you want to code right click and "Code"
Much appreciated sir.
F30 335d xDrive M Sport + 2014 |Birds B3 Dynamic Suspension Kit Springs and Dampers |Pro Media Pack | Visibilty Pack | Interior Comfort Pack | Electric Adjustable Heated Front Seats + Driver Memory
      07-30-2021, 03:03 AM   #29
Jakki2
BMW's for life tai jotain....
Jakki2's Avatar
Finland
Drives: F30 330e 2016
I too have lost the "CID" information on the Kombi - is there certain codes for these or is the restore only way ?
So, could i just FDL code them "back"?!
I did only remove TPMS (and enable RPA) but i had some hickups on the way.
Now, with latest PSDZData i got over to coding ok - but like said, disappeared the hybrid/e information...
      07-30-2021, 03:28 AM   #30
atzebmw
Can you describe what you mean with "CID" Information on the Kombi?
      07-30-2021, 07:04 AM   #31
Jakki2
Jakki2's Avatar
Finland
Well actually i'm not sure how it is called - under tachometer is the small screen (or part of it) where normally is e-drive information and economy dash.
this dash is now gone, only visible is battery level (box with columns in it) and chosen drive mode if not default.
i try to find some pic to elaborate.
Edit: Picture shows the stuff under tacho and in the middle is gone ;(
https://www.driving.co.uk/s3/st-driv...0e-01-2016.jpg
      07-30-2021, 10:22 AM   #32
atzebmw
Unfortunately I don’t know the FDL code for it.
But you can look in the iDrive menu to see whether all items are activated in the settings for the kombi.
If so, you may have to reset the kombi.
      07-30-2021, 10:53 AM   #33
Jakki2
Jakki2's Avatar
Finland
thanks - just played around but without resolution. Once kombi is being coded, i can in the dash those missing items, but they are to disappear and won't come back.
I was trying to enable Sport+, which i did so that i can select it, but the Sport+ is missing the menu - that is probably because my EGS fdl doesn't show all the needed selections. Still i was able to do that with Bimmercode.
Just to confirm - if i select KOMBI, then click on CODE (on the folder, not ncd) - it will reset KOMBI ECU to factory? setup?
I appreciate the help, thanks already
      07-30-2021, 12:09 PM   #34
atzebmw
Yes, it will reset the kombi to the factory settings.
      07-31-2021, 01:07 AM   #35
Jakki2
Jakki2's Avatar
Finland
Did that, didn't help.
But, as were browsing through the diffrerent options, i discovered there individual ones that brought back the economy/electricity meters:
ECO_RW_ANALOG_ENABLE
ECO_RW_DIGITAL_ENABLE
DISP_CON_HYB_APPL
Don't know exactly which one of those did the trick, but worth the try if needed!
atzebmw588.00
      02-24-2023, 08:53 AM   #36
jd85_m
Drives: BMW G20 330e
Just a hint if someone else faces this. To code DSC_VIP_IB4 you have to put the car into diagnostics mode. Otherwise coding this ECU will fail.
      04-13-2023, 07:34 AM   #37
penfold2105
Drives: BMW 430d M Performance
Almost right...
Open E-Sys
-> connect with car
-> Read FA
-> activate FA
Thanks for this it saves so much time. My neighbour has a garage and has swapped a steering rack on an x5 last time I updated and flashed the module then used ista to clear the codes and activate the steering angle.
This time I did what you wrote it wouldn't show the cafd file so couldn't code it but I clicked detect caf and chose the latest version.
Then finished setting up and clearing codes in ista.
So thank you for this.
I have always been worried doing it the previous way because once I update to latest firmware it doesn't show again if there is no later firmware this way I can reset the firmware or even roll it back (if that makes any sense)
      08-05-2023, 03:04 PM   #38
ph38sor
Drives: f30 bmw
Hello,guys,today i use esys first time and deactivate my navigation on f30,cant acces anymore,can help me to can reactivate,thank you
      08-05-2023, 03:06 PM   #39
TheNine90
Drives: bmw
Which headunit is it?
Is the navigation grey or ask for activation code?
      08-06-2023, 10:50 PM   #40
ph38sor
Drives: f30 bmw
Hello,anyone can help me?i deactivate many function from system,im beginer in esys,i deactivate maps,bluetooth,and many think,and a error apear with system restraint airbag function seat belt force limit,test sw ecu airbag,anyone can tell me how to do my car back?
      08-07-2023, 02:08 AM   #41
TheNine90
Drives: bmw
Which error codes do you have?
      08-07-2023, 03:18 AM   #42
ph38sor
Drives: f30 bmw
Only messages apear like error,and my navigation dont have many fucnction
      08-07-2023, 03:21 AM   #43
ph38sor
Drives: f30 bmw
And dont have anymore bluetooth and other stuff,dont know what i do there,if anyone can help me to restore data
      08-07-2023, 06:20 AM   #44
Siki78
Siki78's Avatar
136
Drives: F30,G30
If you have enet cable I can see car over teamviewer
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
