04-04-2019, 12:12 AM | #89 |
Rep 55
I flashed the bootmod3 Stage 1 91 octane earlier today. It's very noticeable! Smooth power across the band.
The max numbers on my gauges changed as well; the max hp number is 560, and the max tq is 400. That seems odd. Why is the max gauge number for hp that high? |
04-04-2019, 12:30 AM | #90 |
Rep 4
Just flashed the bm3 stg 1...fully stock car (440i xdrive manual) for the next week... But here is a 3rd gear (Mt) roll on... Definitely faster than stock.. Cant wait for the DP to arrive!
Had to stop video due to lack of hands... Hopefully someone can compare stock vs the stg 1 bootmod3 |
kern4174449.50 |
04-04-2019, 12:50 AM | #91 |
Rep 60
04-04-2019, 12:54 AM | #92 | |
Rep 4
The stg 2 AGG is raw... Blurbles are VERY noticeable with the windows down... In cabin not bad. But you can tweak all that in the tune. |
04-04-2019, 12:59 AM | #93 |
Rep 964
04-04-2019, 02:58 AM | #95 |
Rep 155
No transmission tune required at stage 1? 430wtq I thought from hearing some other tuners recommendation the trans tune is needed to keep it smooth and not cut power? Or do Bootmod3 tunes include trans tune with engine tune?
Powaup1253.00 |
04-04-2019, 03:28 AM | #97 | |
Bmw340i Mppsk, bm3 tune,vrsf downpipe dinan intake
96
Rep 178
04-04-2019, 03:45 AM | #98 | ||
Rep 60
Eric, I saw your burble mode video and can't wait to try it out on my m240i. What are you currently running for your exhaust? Thanks again for posting! |
04-04-2019, 06:39 AM | #100 | |
Cheapskate
4450
Rep 4,993
Drove for the first time this morning and everything runs smooth. 2 more things i wasn't expecting:
1. Throttle maps are definitely modified. Comfort throttle is now somewhere between comfort and sport on the OEM tune. That's perfect for me since i found sport mode to be a little touchy when driving around town, expecially while trying to manage clutch engagement. 2. Another note for 6MT users: If you don't have revmatching in all gears, it enables it. Previously the car would only rev match when downshifting one gear at a time, but now it'll rev match if I skip gears as well. 3. I did the custom configuration stuff for burbles and noticed that it doesn't have an option for comfort mode. I also confirmed while driving that there were no burbles in comfort, which is just fine with me. I'm not into the overly aggressive gunshot sounds, so from that aspect the car sounds like it did with the OEM tune. I turned down sport mode some from the BM3 defaults so that sounds close to OEM sport setting as well. Quote:
For reference, this is what it used to sound like on stock tune. |
04-04-2019, 06:44 AM | #101 |
Rep 127
New to this but interested!
I see you need an Enet cable plus a laptop to use flash but will the below items work if we wanted to use an adapter to fit a Amazon Fire tablet? https://www.amazon.com/Amazon-Ethern...way&sr=8-8 |
04-04-2019, 06:54 AM | #102 | ||
Rep 521
04-04-2019, 07:31 AM | #104 |
Rep 178
Drives: 18 MG/CR M240i Conv 6M
Noob question... There is an app available for iPhone/Android. Can that be used exclusively to do all the flashing (initial and updates) via WIFI/Bluetooth OBD plug?
04-04-2019, 08:33 AM | #106 |
Rep 124
Drives: 2017 340i M-Sport
Biggest difference is how smooth it is. It feels like a stock car that is just faster. No choppy shifts ever and the power curve is very linear. Also due to the fueling limitations the tune is able to extra more power than the piggybacks currently before going for something like meth.
04-04-2019, 08:51 AM | #108 | |
Rep 55
04-04-2019, 08:56 AM | #109 |
Rep 964
04-04-2019, 08:58 AM | #110 |
Rep 336
It's being said by other reputable tuning companies. I'm not talking about sound FYI, I'm interested in why it's needed for the higher stage map (no meth).
Tags |
bm3, bootmod3 |
