04-16-2018, 10:43 AM | #1717 | |
Rep 90
Got a response back from Hella and these they say would not fit my car. Not sure why but they supplied me with the US part numbers and they are around $1K each and do not come with modules or bulbs. Not going to work for me as I don't want to deal with that. I want a complete plug and play assembly. Last edited by skunis; 04-16-2018 at 12:03 PM.. |
04-16-2018, 05:38 PM | #1718 | ||
Rep 4,031
Much closer to before.
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
04-16-2018, 06:17 PM | #1719 |
Rep 2,382
Yeah, I can see it now.. Curious if there was still more room down there to adjust it even higher..
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
04-16-2018, 06:33 PM | #1720 |
Rep 4,031
Yeah, Kies Motorsports did it, you could email Bryan. He used washers under the light to raise it through the wheel arch. It looks a lot better so I didn't want to push my luck! Very happy that is is not so noticeable!
04-16-2018, 06:38 PM | #1721 |
Rep 2,382
Yeah, I'll shoot him one and ask his opinion. That'd be awesome if we had a sure-fire way to have these sit flush and help out with those installing fresh.
MSCD3186.00 |
04-17-2018, 12:04 AM | #1722 |
Rep 6
Does anyone know where to find Depo lights in US, seems everywhere you look they are out of stock. I found on schmiedmann.com in EU but not sure if they plug and play in US. Anyone order from there?
Any recommendation as to where to look would be much appreciated. |
04-17-2018, 02:52 AM | #1723 | |
Rep 13
Which bulb color did you go for on the retro-solutions? I want it really really bright and was thinking about the max 15,000k strong blue color , but am afraid that it'll be too blue and look rice lol |
04-17-2018, 05:49 AM | #1724 | |
Rep 4,031
On average they get them delivered every 6 weeks or so. That's the way I got mine.
04-17-2018, 09:02 AM | #1725 |
Rep 2,382
15K is crazy blue! Lol. I went with 6k and it's perfect. A little blue in comparison to the halos, but oh man, it lights up the road so perfectly. If you go with Retro Solutions, please talk with them before hand on getting the correct H7 Euro adapters that go with their bulbs. I didn't get the rightt ones and they didn't lock or clasp together, so I had to force them in (PTA because two hands do not fit into that tiny hole in the back). The bulbs and system itself is amazing and high quality. I really recommend them. Just get with them on finding the right H7 bracket and you're golden!
04-17-2018, 12:19 PM | #1726 | |
Rep 13
Is there a video anywhere out there that shows the application of the adapters? I recall seeing a video of an HID installation kit however, the guy just drilled holes through the back cap of the headlight housing and stuck the cords through. |
04-17-2018, 12:47 PM | #1727 | |
Rep 2,382
04-17-2018, 08:03 PM | #1728 | |
Rep 13
https://i.gyazo.com/d76826a1b2980c3c...a4798bd51d.png This was their response. Is it not necessary? |
04-17-2018, 09:05 PM | #1729 | |
Rep 2,382
You need it because "adapter" on the stock holder is what is held in place. Since the adapter isn't holding a bulb in place, you need something to. So, you get the H7 Euro adapter to hold it in place (Two screws pin the wings in)
04-20-2018, 11:25 PM | #1730 | |
Rep 13
https://gyazo.com/186958c68de828dfcc6502657c46d865 It isn't as complicated as this picture shows right? Also I will most likely have to drill a hole in the headlight caps correct? I remember them just being a solid cap. |
04-21-2018, 12:57 AM | #1731 | |
Rep 2,382
04-22-2018, 07:47 PM | #1732 | |
Rep 13
One side would turn on, however the other wouldn't. Then we switched the connectors on the other side and then that side would turn on, which leads to the opposite side wouldn't turn on. Not sure what the problem is since both sides are powered, but they both won't be on at the same time. No error codes or anything. Sucks since there's no returns for retro solutions and kind of stuck in what to do. Thinking it's a relay problem since both wont turn on at once? Note: BMW 2014 F30 with DEPO headlights from unique style racing which originally came w/ halogen bulbs. Last edited by accfortradingg; 04-22-2018 at 07:59 PM.. |
04-22-2018, 11:54 PM | #1733 | |
Rep 2,382
Ensure polarity is correct and double check all connections just to be sure. Ensure you put grease on all connections told to (Unlikely to be the issue, but always helps)
04-22-2018, 11:58 PM | #1734 | |
Rep 13
Ok, I will try that again. I have the same problem as you, when the car electricity is on one of the bulbs work and one doesn't. I then turned on the engine fully and neither turned on. So I should turn off daytime running lamps for this week and then try to set it up again on the weekend? Hopefully this is the solution, it'd suck to have to set it up and dismantle it again if this doesn't work Edit: You had the HID kits installed however, they weren't working, did you leave it in your car and disable the DRL? Then you re-enabled it and all of a sudden it worked? |
04-23-2018, 12:01 AM | #1735 | |
Rep 2,382
04-23-2018, 12:06 AM | #1736 | |
Rep 13
Then turned on the engine and both wouldn't turn on. So what I should do is leave the kit and the bulbs in there and drive w/o low beams for a day or two with the DLR's off for a couple days and re-enable it , and it should work? Props to you for leaving them in there; I had them in, but decided to just dis-assemble it since it didn't work and put back the old halogen low beams. Last edited by accfortradingg; 04-23-2018 at 12:20 AM.. |
04-23-2018, 12:23 AM | #1737 | |
Rep 2,382
Once you disable them, the lights will work; however, in the "Auto" mode during the day, the DRLs won't turn on. Obviously, we like the halo's to be turned on, which is why you want to renable them later. You can manually switch on the halo's by putting the lights to the parking lights mode in the meantime.
molnii481508.00 |
04-23-2018, 12:26 AM | #1738 | |
Rep 13
I think my problem may be more serious since I turned the engine on, turned off DRL's and both still didn't turn on. When the electricity is on only, no engine, only the left side would turn on. I think it may be a relay issue? I've emailed them and waiting for a response. |
