06-11-2019, 11:59 AM | #2245 | |
Rep 63
06-11-2019, 01:52 PM | #2247 |
Rep 139
Drives: BMW 5 series E60, Mercedes S
Hmmm, that is a bit sad. I don't seem to have your version string yet (012042bJLY-CIC-HW7). Any chance you've found an mcuupdate.bin somewhere from someone with the same unit? I'll search for it myself as well.
Update: I was not able to find any other MCU updates, although there are certainly a few vendor strings like "ALS", "JLY" and "XHCN". There seems to be only one option: exploiting the firmware to be able to dump them. Now I said at first glance that it isn't easily exploited and that still stands, but there are pieces of code that I've seen that look as a target for things like buffer overflows. And now that i have a test unit with debuggable firmware, I can fuzz and test a lot faster. So please continue to send me MCU updates, but I will also try and exploit the firmware so we can dump the contents of the MCU flash memory. Last edited by __fred__; 06-11-2019 at 03:49 PM.. |
amfgray0.00 |
06-11-2019, 04:56 PM | #2248 | |
Rep 63
https://drive.google.com/folderview?id=1paJ2cyavcRH9KMQ_l5buQ2v-OB2cYFgE |
06-11-2019, 04:57 PM | #2249 |
Rep 63
06-12-2019, 12:31 AM | #2251 |
Rep 63
06-12-2019, 02:47 AM | #2252 |
Rep 139
Yes, you sent me the correct file. It was 012042bJLY-CIC-HW7. I patched it. You can download it from here:
https://github.com/chinesebmwheaduni...ming%20patched I drove to work this morning and the difference is night and day. ;-) |
nomorebigideas6.00 |
06-12-2019, 03:50 AM | #2253 |
Rep 139
So koutsouk was so kind to send me firmware 035242bYC-CCC-HW8-190525, which is the most recent firmware I have. There is something interesting with this firmware:
They have introduced a setting to control the auto dimming feature. That means it can be enabled and disabled from android. A part of the update_settings routine writes the setting: It's actually a frame that can be sent from android with hex bytes 0x70 and 0x13 and then 0x00 to enable or 0x01 to disable auto dimming. There must be a corresponding settings apk somewhere in a ROM that controls the setting. This means that the Chinese do listen to their customers ;-) I still patched the firmware for everyone who doesn't have the corresponding settings apk. They made a mistake though. If you disable the auto dimming while your lights are on, the brightness will never return to 100%. (as night_enabled is never processed anymore). So if you have a new unit with the setting in the settings app: Do not turn off auto dimming while the lights are ON. Last edited by __fred__; 06-12-2019 at 08:36 AM.. |
antonius201827.00 |
06-12-2019, 04:14 AM | #2254 | |
Rep 63
Just to check filepath for correct install: Format FAT32 oem/mcupdate.bin Is that right? |
06-12-2019, 04:20 AM | #2255 |
Rep 139
06-12-2019, 04:49 AM | #2257 |
Rep 139
I've got another present for you:
The brightness is controllable through an android intent. Now it's a bit tricky, because its a toggle, that toggles between the 4 brightness levels: 0 = 0% brightness 1 = 33% brightness 2 = 66% brightness 3 = 100% brightness. The intent is sent by the status bar when the button is pressed in the function area of the drop down menu. But you can ofcourse send it programmatically. The intent is named: com.android.quicksetting.BROADCAST and it has extra string data attached: msg "backlight" You can probably toggle it from adb with the following command: Code:
adb shell am broadcast -a com.android.quicksetting.BROADCAST --es msg "backlight" Remember that you probably have to send multiple intents to toggle the levels with a bit of delay in between. I will create a new version of EventCenter.apk that will directly control the brightness level through an intent, but for now, this is already available. Last edited by __fred__; 06-12-2019 at 05:02 AM.. |
06-12-2019, 05:01 AM | #2258 | |
Rep 14
There are two settings "controlled" and "uncontrolled" I don't have the unit right now to give you the exact details but it has something to do with the reading the status from the car. Maybe looking in the fatset.apk from the firmware I posted may shed some light. |
06-12-2019, 05:23 AM | #2259 | |
Rep 139
Update: And it does. In fatset.apk it sets a value in the sysvar.db database. That is subsequently read in Eventcenter.Apk and sent to the unit with hex codes: 0x70 and 0x13 (= 19 decimal). 0 is controlled, 1 is uncontrolled (=autodimming disabled) Last edited by __fred__; 06-12-2019 at 05:48 AM.. Reason: swapped images |
06-12-2019, 05:44 AM | #2260 | |
Rep 190
06-12-2019, 05:50 AM | #2261 | |
Rep 63
It would great if the Tasker intent + brightness selection could be coupled with Locale/Tasker Twilight Plugin to allow for auto-dimming (conversely!) when the sun goes down etc. |
06-12-2019, 06:08 AM | #2262 | |
Rep 139
When going from day to night: send intent 3 times to go from 100% to 0%, 33%, 66%. When going from night to day: send intent 1 time to go from 66% to 100%. You might need one at boot as well if these intents don't fire while the unit was powered off. It will work better when you can send the absolute brightness value through an intent. But this will require modification of the Eventcenter APK. |
06-12-2019, 06:36 AM | #2263 |
Rep 14
Check here https://f30.bimmerpost.com/forums/sh...php?p=24830912
20190505 |
Tavicu22.50 |
06-12-2019, 06:45 AM | #2264 | |
Rep 190
I think I need to update into that firmware to enable the auto dimming feature from factory settings. Does this version have id7? Do you have any photos ? |
06-12-2019, 09:36 AM | #2265 | |
Rep 21
yesterday i just installed it to examine id7 and as for me it is absolutely useless ;(. |
06-12-2019, 10:14 AM | #2266 |
Rep 1,048
Hello
I just wanted to share some information, as i got into the sideload screen by mistake by me, rebooting the device via wlan into sideload mode After this the device is showing the first screen: At this screen no USB device does work at all, also directly rebooting does not help to get out of the sideload screen. I tried to connect the device to my "Android updating" laptop with adb installed via A USB A-A cable, but no success, also there is no response, the connectors seem to be not active at this boot state. to get out of this and into the normal system you have to wait 5 minutes, after this time the second screen does appear unfortunateley as no usb port does work its also not possible to select anything. but the good thing is, when you now powercycle the device it will start normally into bootloader mode again @ Fred, i`m willing to share pictures and informations of my PX6 device, i also have disassebmled is as far as i could, because i`m not using this device so i can play around with it. i have a github account, but i`m not fimilar with the "folder" structure. i think it would be good to start some kind of Database of the different available hardware variants / clones. A database based on the first string of the MCUVer. (+CPU) may be the best i think, because this is the most common identification possible. from there on built like a tree with information / pictures / how-to`s, ect ? any hint for me to start this ? sincerely Chri Last edited by Kri; 06-12-2019 at 10:59 AM.. |
