BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Experience with 10.25" android 7.1 HU's
proTUNING Freaks
      06-19-2019, 06:21 AM   #2355
antonius2018
Drives: BMW F32
Originally Posted by __fred__ View Post
It will not work indeed. The apk is loaded into memory every time it is started. Also, to make sure that resources are not loaded twice, they need to be aligned on 4 byte offsets. Use zipalign after recompressing an Apk.
Thanks!
I thought the APK was "decompressed" after instalation, now I see it works on the fly and loads into memory each time it is run, so my ideia was totaly wrong.
About the 4 byte alignment, as I am using the APK Editor studio, I think it is already made.
Let's see what happens with the new APK (I only changed some images and the strings.xml file with some corrections on the translation).
      06-19-2019, 06:24 AM   #2356
RuLzgzF30
Spain
Drives: BMW F30
This is the choice of the Chinese developers, it's not my choice. I could patch it, but personally I never used the toggle button in the notification area, so i don't really need it. By the looks of your device, Android 8+ is completely different than Android 7 and they don't use the toggle any more.
I have Android 7.1 (Unknown and I can update to 8.1) and at night it dazzles a lot and I lower it from the top slider ... and if I set it to 0 it turns off the whole screen ...
      06-19-2019, 06:30 AM   #2357
Svenson
Svenson's Avatar
Drives: F11 530d
Hello.
My device is PX6, 8.1 and i have root access.
My question is, how can i enable signature spoofing? Who can help and tell the procedure?
      06-19-2019, 06:43 AM   #2358
__fred__
Netherlands
50
Drives: BMW 5 series E60, Mercedes S
Originally Posted by Svenson View Post
Hello.
You could install either haystack or Tingle.
However, my Patched Eventcenter.apk is only for Android 7.1. I have not patched an Android 8+ version as I don't have a PX6 unit to test the patches.
I would advise against it at this moment.
      06-19-2019, 06:50 AM   #2359
Kri
Austria
1084
Drives: E87
Hello.
it was not required on my 8.1 machine to do signature spoofing,the only additional thing i did was disabling verity (adb disable-verity)
sincerely Chri
      06-19-2019, 07:15 AM   #2360
Svenson
Svenson's Avatar
Drives: F11 530d
I have patched the eventcenter.apk from my device with your patches. But i can't install the patched apk.
I have done "disabled signature verification" but need "enabled signature spoofing" also.
      06-19-2019, 07:19 AM   #2361
Svenson
Svenson's Avatar
Drives: F11 530d
sincerely Chri
You can install patched apk with this setting?
By the root process i have used "adb disable-verity".
      06-19-2019, 11:56 AM   #2362
haxx94
Drives: BMW 320d f30
You will need my modified event center first (v0.2):
https://github.com/chinesebmwheaduni...enter/releases
To be able to run it, you first need to make sure that you have signature check disabled and signature spoof enabled.
To keep su enabled, just type "su" and press enter. You will spawn a new shell with root rights (#character instead of $)
Yes, I didn't updated the EventCenter, now the commands works! Thanks very much fred!!
      06-19-2019, 12:39 PM   #2363
hohay
Drives: M240i
That was some reading!!
Interested in one of these screens either from Avin or China directly. Reading various posts about sound quality. I have a m240i idrive 4 (must be the only 240 with a id4!) with the HK audio upgrade. With this setup will I have issues with sound loss? Plan to use it for the nicer screen, Waze from the play store and maybe amazon music. Also if it can run the bm3 gauges that’s a huge bonus
      06-19-2019, 05:53 PM   #2364
antonius2018
Drives: BMW F32
So, I packaged a new Launcher3.apk, rooted the HU, copied the new apk to the OEM directory and renamed the previous as Launcher3a.apk, but
1) The Icon of the Launcher3.apk became a bit strange ... in the download directory were I put it, it had the "correct" icon.
2) Even with this situation I rebooted the device and everything was as before! No errors, no changes on the aspect of the vehicle image, nothing!
Any clue from our Android specialists?
Thanks!
      06-20-2019, 02:09 AM   #2365
nomorebigideas
Drives: BMW X3 xDrive20d SE (2011)
nomorebigideas I've patched eventcenter to send an intent directly. It works by sending an intent:
intent action: com.android.quicksetting.BROADCAST
extra string: key: msg value: backlightPercent
extra integer: key: percentage value: percentage that you want.
examples from adb
or from the terminal like in the video below (you need root):
I'll write a tutorial tomorrow on the wiki which covers the following topics:
  1. Installing rooted ROM
  2. Enabling Signature spoof
  3. Installing Xposed to disable signature validation
  4. Replacing event center with a patched one
  5. Installing Tasker and the Twilight plugin
  6. Hooking everything up.
THIS GUY!!! Amazing. Don't know how I can thank you enough... Will send you beers from Salzburg (I've moved for work!) unless you're interested in a crate of Red Bull???
      06-20-2019, 02:25 AM   #2366
Tavicu
Romania
23
Drives: F31
based on your idea of changing pictures i just tried a couple things, and what should i say, its possible to change pictures, without the need of re signature the .apk file
Hei! I just ordered my navigation one week ago and i should get it soon!
My experience with Android devices ... it's ... none )
In case of an update the changes of images will be lost?
      06-20-2019, 06:29 AM   #2367
renedis
Netherlands
Drives: G21 330e
Got mine yesterday @__fred__
It's ordered from Mekede, BMW F30 NBT PX6 8.1 unit
      06-20-2019, 06:55 AM   #2368
RuLzgzF30
Spain
Drives: BMW F30
For several days I have not taken a GPS signal and before I did it the first time, what can it be due to? the connection of the antenna is checked and before updating mcu and Android it worked well ... very close to when it takes 1 satellite or 2 ... but nothing else.
      06-20-2019, 07:00 AM   #2369
antonius2018
Drives: BMW F32
Can't you go back to the previous version of Android and MCU and check if it has anything to do with that?
      06-20-2019, 07:09 AM   #2370
Kri
Austria
1084
Drives: E87
Maybe it was a little bit misunderstanding, no you cant install a modified apk, you need to replace the apk of the already installed App, IT seems that there is no Signatur check after the Installation anymore
Sincerely Chri
      06-20-2019, 07:12 AM   #2371
Kri
Austria
1084
Drives: E87
Hy, would be great if you could add your Information also to the other thread: here
Sincerely chri
      06-20-2019, 08:07 AM   #2372
RuLzgzF30
Spain
Drives: BMW F30
From the MCU I do not know if there is a security file on the screen and then, I need the mcuupdate.bin file from 012042bJLY-NBT .....
      06-20-2019, 08:31 AM   #2373
__fred__
Netherlands
50
Is the weather worse? We have had a lot of clouds and lightning in the Netherlands, and my signal gets worse then as well. You'll have to move the GPS antenna around in the car while looking at the GPS test app to determine the best location. Probably somewhere in a corner of the windscreen near a pillar. Best would be an outside GPS antenna on the roof.
      06-20-2019, 09:08 AM   #2374
RuLzgzF30
Spain
Drives: BMW F30
I have tried several points inside and outside and with another antenna and nothing .....
      06-20-2019, 12:01 PM   #2375
fullrespect
Drives: BMW E90
Originally Posted by laviniu View Post
I've been using a BMW F30 Ugode android unit (7.1) for almost a year and it's been working fine but recently it started to get errors like in the attached picture. Sometimes it shows 'No Signal' but usually it's a graphic error like the picture. It seems to happen a lot if I start Waze to quickly after it boots but it also happens randomly every day.
The BMW iDrive part works perfectly when I switch and even the Android side works because I can hear the music, change it, I hear Waze instructions. If I turn off and on the ignition it works again. Any idea how to fix this? Any way to reboot the system without turning off the ignition switch?
Hello, have you find some more infos about this issue? I'm having the very same problem with an Andream 2GB Android 7.1 headunit. As far as I discovered, the issue is heat related and almost every demanding app (Waze, YouTube etc.) will crash it really quick.
I've been in touch with the seller and he gave me a firmware update which made the situation even worse.
Thanks!
P.S. Daca ai mai multe informatii sau posibile rezolvari, te rog da-mi un mesaj privat. Mersi si succes!
      06-20-2019, 02:19 PM   #2376
RuLzgzF30
Spain
Drives: BMW F30
Por fin he conseguido el archivo MCU de JLY para NBT
