04-15-2024, 12:46 PM | #45 | |
Rep 5,395
235/45-18 245/45-18 245/40-18 Can’t really go wrong with any of them. Stock tire diameter for 225/45-18 is 26.0”, so that’s where speedometer and odometer are calibrated. My favorite tire size of those three is 245/40-18 for the best handling. It’s diameter is about 25.7” which means that at highway speeds the car is actually going 1-2mph slower than what the speedometer indicates. So if you pick a size with a 26.3” diameter then that will have the opposite effect of at highway speeds actually traveling at 1-2mph faster than the speedometer indicates. 245/45-18 has a slightly higher sidewall so it’s probably the most comfortable ride. 255/40-18 tires are dead on 26.0” diameter but don’t fit on an 8.0 wide wheel according to tire manufacturer specs. So you would need 18x8.5” or 18x9.0” wheels of about ET35 offset Hope this helps! |
alohasurftoad3104.00 keithyo88117.00 |
04-15-2024, 08:31 PM | #49 | |
Rep 4,353
for a staggered setup, one of these combos are better... 18x9 ET30 front + 18x10 ET40 rear with 235/45/18**+265/40/18* or 245/40/18*+265/40/18* or 245/40/18*+275/35/18 or 255/40/18+265/40/18* or 255/40/18+285/35/18 *light stretch **medium stretch bold is what i'd get |
04-15-2024, 10:01 PM | #50 |
Rep 212
thank you for the insights. so do these squares make sense?
front: 18x8.5 w/ 245/40r18 ET:40 rear: 18x8.5 w/ 245/40r18 ET:40 or front: 18x9.0 w/ 255/40r18 ET:30 rear: 18x9.0 w/ 255/40r18 ET:30 front wheel has about 1-3/4" top of tire to wheelwell, rear about 1" |
04-15-2024, 10:58 PM | #51 | |
Rep 4,353
if you browse through the apex thread linked below, it has most of the setup combinations. many with 255 or 245 @ ET30 square so you can get an idea. https://f30.bimmerpost.com/forums/sh....php?t=1393886 |
triax37130.00 |
04-15-2024, 11:26 PM | #52 |
Rep 212
Grateful for the confirmation: square 18x8.5 w/ 245/40r18 ET:40
I will get a better idea of the look, possibly add spacers and change my order tomorrow. Will update when they arrive. This is an excellent crew and thanks again. |
alohasurftoad3104.00 |
