BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > BMW Fxx/Gxx B58 OBD Flashing is now supported by mFlasher
Closed Thread
      07-20-2018, 08:46 PM   #133
Bullitt1841
Drives: F36 B58
Very excited!!!
What are the units for boost in your DZ log?
      07-20-2018, 08:50 PM   #134
MissionPerformance
MissionPerformance's Avatar
Drives: '17 F31 340xi US Spec
Originally Posted by Bullitt1841 View Post
Very excited!!!
hPa absolute with 1010 atmospheric
      07-20-2018, 09:48 PM   #135
Araemo
Drives: 2017 340iX 6MT
Posting the datalog, talk about putting your money where your mouth is.
That said, any chance to see the datalog from the stock run? I'm curious on the differences in timing, lambda, etc?
      07-20-2018, 09:53 PM   #136
Mamyf30
Drives: f30
Will we be able to get a 93 oct option?
How does the install work? Can you post a YouTube vid?
      07-20-2018, 09:54 PM   #137
Bullitt1841
Drives: F36 B58
It's all in the first post...
      07-20-2018, 09:59 PM   #138
Bullitt1841
Drives: F36 B58
Timing looks stock. The DME should be adjusting as necessary.
However, my stock MPPSK AFR is a lot richer than the "MPPK" logs he posted. Curious as to how he came up with the "MPPK" tune. My AFR looks like his Stage 1 and 2 AFR, getting into the low 13's/high 12's with my JB4 in Map 0.
      07-20-2018, 10:02 PM   #139
Bullitt1841
Drives: F36 B58
Thanks!
      07-20-2018, 10:04 PM   #140
Mamyf30
Drives: f30
Lol don't see anything on 93 oct option or a video with procedure/audio in a normal version someone could actually follow but thanks
      07-20-2018, 10:52 PM   #141
MissionPerformance
Here is a fully stock 340. First pull is for 91 octane and second 2 pulls are for few gallons of E85. Those logs I took few days ago and now they are on datazap, so I cant go back and rename the parameters to something more human, but I'm sure you can figure them out:
https://datazap.me/u/missiontuning/2...?log=0&data=11
Now from today on the dyno, here is MPPK log:
https://datazap.me/u/missiontuning/2...k?log=0&data=6
"MPPK" tune is a factory file (swfk: 3c9e_080_017_001) loaded on computer with modified eeprom and cas certificate check. The file it-self is bare virgin factory flash.
Your AFR are richer because your car has to make more boost/load to achieve torque target. MPPK can go from anywhere in 1700 to 2100hpa of boost at 5-6500rpm just to hit a desired demand.
With load of anything under 155, you will be running stoich lambda all they way to redline since there is enough timing to meet the desired demand. On that MPPK run, we had E85, so even though there was some knock, computer didint pull timing as you can see due to engine not "Super Knocking"...YES, Super Knocking is actual BMW terminology as off N54/N55 days and is different then regular knock.
Araemo190.50
Taskmaster2465.00
      07-20-2018, 11:12 PM   #142
B58
B58's Avatar
558
Drives: 922 Turbo
Possible to be well over 400whp on day a E30 blend?
2024 X3 M40i
2014 BMW M5
      07-20-2018, 11:14 PM   #143
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
https://datazap.me/u/missiontuning/2...=0&data=11
https://datazap.me/u/missiontuning/2...g=0&data=6
MP Doing big tings! Now race that in a straight line against an M3/4 would be a great video, just saying.
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles
      07-20-2018, 11:16 PM   #144
MissionPerformance
Fueling Limitations:
As we have found out by doing extensive and pretty risky testing, fueling system on B58 is MUCH better then the one on N55. On our 380whp pulls, even with few gallons of E85, we were able to maintain a very good 20MPa of rail pressure with safe drop to ~19MPa.
Now, on a way back from the dyno, the car was running our 380whp revision as I decided to find the fuel system limits. I filled up with even more E85 bringing a tank mixture to around 8/7. After adjusting fueling for the mixture, I went on a drive to get a car adapted a bit. Around town the car felt good with even more mid range torque. Pushing it a bit in a gear showed no problem, but as soon as I did a 2-3-4th pull, the pump HPFP said "Hell No" and fuel pressure dropped. So from all the logging and testing it seems that at around 400whp/ the fuel system can hold about 2-4 gallons tops. That is more then enough to remove the unwanted knock and still give the HPFP a headroom.
Now, on 93-95 octane, these cars should be capable of 450-470whp with stock pumps.
Bmw doubles I really want to try and do a 2-3-4 pull with a bone stock M3. That could be a good test for sure.
Araemo190.50
Nugget649.50
kern4174446.50
      07-20-2018, 11:33 PM   #145
B58togo
Drives: M240i
Any plans to dyno with a catless DP? Sucks you’re in Cali with crappy gas. I can see 410-415 whp with dp and 93 octane. I think I need to order this. Hello 11’s.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
      07-21-2018, 12:25 AM   #146
Antec800
Drives: 340i x drive
In comparison to a jb4 with the recommend 93 oct used how much more power is this flash tune making? And how bad is the cutout during wot shifts(torque reduction) will making this much power
      07-21-2018, 12:26 AM   #147
Bullitt1841
Drives: F36 B58
Here's some testing against a stock M3: http://www.n54tech.com/forums/showpo...8&postcount=23
I was running 21 PSI on stock turbo with JB4 and meth. S55's are quick.
      07-21-2018, 12:53 AM   #148
StockLOL
Drives: 2018 340i MPPSK
Numbers not that impressive, is that dyno low reading?
Also, I’m located in SoCal with 91 octane max access running MPPSK tune, should I be running a couple gallons e85? Will I gain any power?
      07-21-2018, 12:56 AM   #149
Bullitt1841
Drives: F36 B58
You don't read at all, do you? Why are you just looking at peak HP?
What does your car with MPPSK dyno at with 91 octane?
kern4174446.50
      07-21-2018, 01:15 AM   #150
StockLOL
Haven’t had it dyno’d but I would like to. Last dyno I saw was 370/370 but on 93 octane I think it was in Midwest. Burger tuning said e85 was not good on b58 because not enough fueling but this seems contradictory. Maybe I’m not understanding it but seems like the ethanol blend was good for their test car?
      07-21-2018, 02:10 AM   #151
B58
B58's Avatar
558
Drives: 922 Turbo
They’re also located in Southern Cali so those tests were done with our gold 91 octane.
2024 X3 M40i
2014 BMW M5
      07-21-2018, 02:40 AM   #152
cookiesowns
cookiesowns's Avatar
587
Drives: X5 45e, 535i N54, X3 N55
Thank you for posting and sharing info! Transparency is key for me to finding/recommending a reputable tuner!
I love the raw logging channels , just wish I had some MDG1 files to dig around and a tool/car to flash with, would be interesting to learn more about these cars.
Keep it up MP!
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
      07-21-2018, 06:24 AM   #153
jrdoming
Drives: 2017 340i M-Sport
2017 BMW 340i  [0.00]
Keep in mind that one is a piggyback while the other is new ecu software. This means that the jb4 has to coax the ecu into doing what it wants through lying to sensors. This means that they can have limitations (I.e fueling). When overwriting the software they are only limited by the hardware on the car. BMS will eventually release a backend flash for the ecu to help them take advantage of the fueling cap removal.
      07-21-2018, 08:53 AM   #154
B58togo
Drives: M240i
Nobody knows the exact answer to your first question, since no direct, same day, same dyno comparison has been done with the JB4 and this flash tune.
Closed Thread
