11-15-2019, 05:29 PM | #419 |
Rep 282
ive went from oem pump over to the evo one and now hdp6 , since they are all bosch they dont need extra coding .
both fired right up without any hickups , i ran numerous tunes even mhd's beta ones for pwg ps2 . never had any issue . check you rail pressures on a monitoring app or in BM3 ? ( i have no exp what can be read in bm3 ) . try and use your stock program aswell , is it rough on both . could very well be something's wrong with the pump . i hope you were carefull not to have any dirt into the pump's in and outlet while cutting away the flange . two clips after installment of both evo and hdp 6
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
11-15-2019, 06:03 PM | #420 | |
Gettin It Figured Out
1820
Rep 2,669
Without WOT logs to look at, everyone would be "shooting in the dark" .
11-15-2019, 08:22 PM | #421 | |
1820
Rep 2,669
Pull a few plugs and take a quick look see .
11-16-2019, 01:01 PM | #422 |
Rep 928
Where's the best price for these pumps? Their just over a grand?
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
DreamerJoe240.50 |
11-18-2019, 01:20 PM | #423 |
Rep 928
You searching by the part number?
11-18-2019, 05:04 PM | #424 |
Rep 282
be sure to get the hdp6 as it is much more capable
beastwood have you solved the rough running yet ?
11-20-2019, 05:35 AM | #425 |
Rep 1,282
Just spoke with spool performance and their hpfp is out 2-3 weeks. They said it will be $1399.
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ Last edited by oma3710; 11-20-2019 at 11:34 AM.. |
11-20-2019, 10:55 PM | #426 |
Rep 928
Used hpd6 sounds like best deal.
11-24-2019, 07:02 PM | #427 |
Rep 16
Spool HPFP
I installed the pump today. From what I can tell you guys; it was a simple install. No cutting of wires, lines or anything. At first start i did have a couple of misfires, but reset adaptations and that made them stop. You will NEED a custom tune for it until MHD releases a ots map for it similar to what they did with the XDI. I think Wedge and pureboost are the only ones tuning it at the moment. I am working with Fabian @Pureboost.de in order to go full E85 on the stock EWG turbo. This pump is still in Beta testing, but so far it is looking like a good alternative for those who do not want port injection.
2014 F30 335i, FBO E85 custom tuned
IG @jerryjuarez96 |
11-25-2019, 05:23 AM | #428 |
Rep 282
looks good , perhaps some pictures of the install in your car ?
did you have to move your knock sensor ?
11-25-2019, 10:41 AM | #429 | |
Rep 16
I am currently testing it on E40 on my second revision and car pulls nice and smooth. I will be gradually increasing ethanol content. |
11-29-2019, 03:21 PM | #431 |
Rep 99
B58 hpd6 installed. Car started right up.
Have some logging to do now Link of it running https://youtu.be/Qci4q-eBJfY Link of modified pump https://youtu.be/9iXdbfXKEkw Last edited by Rondavouz; 11-29-2019 at 05:50 PM.. |
12-03-2019, 12:09 AM | #433 |
Rep 9
Pray for Mojo429.50 |
12-03-2019, 05:08 AM | #434 |
1820
Rep 2,669
Uhmmmmmmm..........huh? Information and/or links to your HPFP to support your "photo" would be helpful... .
12-03-2019, 06:23 AM | #435 | |
Rep 9
You can check out our website here: https://dorchengineering.com/ And our vendor introduction here: https://f30.bimmerpost.com/forums/sh....php?t=1674769 The tables posted above are maximum flow rate numbers for each of the available Bosch variants along with our upgrade kits. The N55 numbers differ from the B58 numbers due to the difference in the camshaft fuel lobe. The N55 has a 3x4.7mm camshaft lobe while the B58 received a slight bump up to a 3x5.0mm lobe. We are a new name, but we have been supplying GDI solutions for years "behind the scenes" so to speak via contract engineering and private-labeling. We are now taking things direct to the consumer to provide quality kits for the best possible prices. Stay tuned this week in our own thread for more updates from our tuner along with some horsepower records from our beta testers.
ZM22810.50 Pray for Mojo429.50 |
12-03-2019, 06:35 AM | #436 | |
1820
Rep 2,669
Good to know. The requested information also included XDI/Spool differences....which you did not provide. May I suggest creating a “Hey guys...., we also have an HPFP option” thread (N55/B58 Forums)? EDIT: Dorch Engineering I took a look at your site and S2 pump info. Sounds VERY promising!! Will definitely be following your release. 🍻 .
ZM22810.50 |
12-03-2019, 07:33 AM | #437 | |
Rep 3,695
Also, do you have an idea of the E mix limit on your S1 HPFP for an N55 with a Stg 2 turbo (such as Pure), and a standard tune that’s not just boosting for a dyno run? |
12-03-2019, 07:51 AM | #438 |
Rep 282
thanks for the info , now we have a decent idea about flow numbers
12-03-2019, 11:13 AM | #439 | |
Rep 9
As for E mix, honestly we were hesitant to list whp and E mix recommendations just because that can be entirely dependant on the tuner. That being said our estimates are accurate and conservative and you would most likely end up at an E50 mix on our S1 pump with PS2. That pump will cover most everyone's PS2 needs, but we will update with more data from independent beta testers soon! |
ZM22810.50 |
12-03-2019, 11:26 AM | #440 | |
Rep 3,695
General question for the forum guys: is anyone seeing power gains by pushing Stage 1 & 2 turbos beyond E50? I know the S55 crowd with twin turbos sees big benefits in running E85, but can full E85 be taken advantage of on the N55? |
