BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 - Time slips/0-100kmph/100-200kmph thread!
      03-19-2020, 02:39 PM   #45
yokata
yokata's Avatar
Bulgaria
156
Drives: Bmw F30 340xi
I also made a few runs very similar times 9.63 best...Idk ill request custom tune to f80 paul i hope he will max out my hardware
      03-21-2020, 04:45 AM   #46
luke1990
Drives: G30 540ix
Originally Posted by Sµpreme View Post
How much do you think the meth is contributing to your power? I'll have the same setup soon minus the meth and I'm not interested in adding a meth system.
In my case its 50WHP
      03-25-2020, 10:26 PM   #47
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
100 - 150 in 2.85 sec
100 - 200 in 7.12 sec (99.2 km/h to 199.3 km/hr)
4048 RPM in 4th = 99.2 km/h and 6212 RPM in 5th = 199.3 km/h
M140i stock hardware, MHD Stage 2 95_102 with E30 fuel blend, xHP Stage 3, plus DIY MAP spoofer (like JB+)
https://datazap.me/u/ozbmr/ozbmr-mhd...o=0&mark=40-81
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s
Quarter mile 10.93@127mph
      03-25-2020, 11:19 PM   #48
sstyle
Drives: X3MC F97
Guys, what modes (manual, s/sport+, etc) do you use for best results? 01100, 100-200
      03-25-2020, 11:39 PM   #49
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
May depend on your tune, for me Sport+, Manual starting in 4th gear, changing into 5th at about 6500 - 6600 RPM
      03-29-2020, 12:09 PM   #50
theone1973
Drives: M140 -18
Originally Posted by theone1973 View Post
I got 0-100 in 4,36 , 0-200 in 13,17.
4 pulls 100-200 = 8,60, 8,80, 8,65, 8,51
EDIT !
I got 8,24 in my latest verison from Pureboost. I have recived 8 files and we are done now.
M140 Sunset Orange 2018. M719 Jet Black. Maxton sideskirts and spoiler, Ksb front splitter, RK Tuning diffuser, TPI spacers, MHD Stage 2, Xhp stage 3 , Wagner 300 cell cat, MPE silencer , Quaife LSD.
Supra pump and OTS E30, Spool ethanol analyzer (E35)
https://theone1973.imgbb.com/
      03-30-2020, 02:48 PM   #51
janea1207
Drives: BMW 340i
is faster than from 3rd gear? remain in manual mode or go in D?
      03-30-2020, 02:56 PM   #52
janea1207
Drives: BMW 340i
b58
EDIT !
what car? mods?
      03-30-2020, 02:58 PM   #53
janea1207
Drives: BMW 340i
b58
340i rwd MHD stage2 98Ron OTS map + xHP
OzBMR574.50
Solid67187.00
      03-30-2020, 04:03 PM   #54
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
Not for me, about the same starting in 3rd, even a fraction slower.
Remain in manual mode changing in 4th at 6500 - 6600 RPM is fastest
      03-31-2020, 02:18 AM   #55
theone1973
Drives: M140 -18
what car? mods?
M140-2018 2WD
MHD Stage 2
Xhp stage 3
Wagner 300 cells
BCS mid pipe + MPE
Costume tune by PureBoost ( 98RON/93Octane only )
I pull from 4th to 5th.
Same car with same setup and 102 Aral fule is low 7
Octane is everything on this engines...I have got 8 different versions from Pureboost.
OzBMR574.50
      04-06-2020, 11:02 AM   #56
Solid67
Drives: 2019 M240i xDrive MP Edition
Finally got to do some additional 0-60mph (0-100kmh) testing and hit a best of 3.43 (3.6). My previous best was 3.7 with 1500DA. Also been playing around with the xHP custom launch control and it definitely has helped. I'm thinking at -1500DA this thing has a 3.2-3.1 in it, but I wouldn't know since the HPFP wants to crash.
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
OzBMR574.50
      04-06-2020, 01:28 PM   #57
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
Really nice work. Is this on the Pirelli tires or something better now?
Once I get this turbo install dialed in I might be interested in a little bit more detail on how you worked through the launch control adjustment.
2020 X3M
MG Flasher; Wedge Performance E50 tune
MSS Urban; Rohana RFX11
      04-06-2020, 01:41 PM   #58
Solid67
Still on the stock Pirelli run flats with close to 20k on them. Definitely shoot me a pm when you are ready about xHP custom launch control.
Supr3me552.00
      04-06-2020, 04:50 PM   #59
Solid67
Very nice times man! I would be very happy if I got that. Can you explain the benefit of using a JB+ or the DIY version with a flash?
      04-06-2020, 08:09 PM   #60
B58togo
Drives: M240i
3.2, 0-60 with rollout is nuts! All the magazines use rollout. Any 100-200 or quarter mile data?
      04-06-2020, 09:43 PM   #61
Solid67
Hey man thanks! I havent gotten any new 1/4 or 100-200. My previous best in 1500DA was 11.8 at 117mph and 9.66 100-200kmh but my car has significant throttle closure issues. I will definitely try to get both times again soon.
      04-06-2020, 09:47 PM   #62
Solid67
I just broke my record again. It was nice to finally try it in negative DA even if it was by very little.
OzBMR574.50
      04-06-2020, 11:38 PM   #63
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
Thanks, I'm lucky the M140i is pretty low weight but still has the B58 and ZF8. Your 0 - 60 times are great, jealous of your X Drive
I'm using it because I had already made one up myself prior to the general availability of flash tunes and it effectively enables me to adjust the torque/load/boost targets on the OTS tunes.
e.g. the MHD Stage 1 E30 map has a base torque/load target that typically generates 16 - 17 PSI.
Having a JB+ type device connected to the charge pipe sensor allows incremental increases in boost e.g. I'm currently running 18 - 19 PSI on that tune and ran another 100 - 200 in 7.3 seconds this morning.
JB+ and similar do mess with the reported boost, load and torque data coming via the MHD logging software so I'm rescaling boost based on MAP volts data in my logs. The 100 - 200 times and Virtual Dyno results prove the benefit.
Using it on the car when it was stock I got a 12.49@114MPH with a 2.07 60ft, could have been an 11.9 with the Hoosiers and a 1.77 60ft
My DIY version has a resistor and a potentiometer (creates an adjustable resistor) in a little black box that tucks under the engine cover. I sourced the male and female connector plugs, M & F contacts and wire seals from companies in Germany and USA. All up about $20 - $30 in parts and it was an interesting side project.
      04-07-2020, 12:41 AM   #64
Stampe
Denmark
18
Drives: BMW F30 lci 340i
Hi
It's been time for some stock times so many don't feel theirs is slow,
340i rwd , 8 speed - bone stock -
dragy.
0-100 = 5,09
100-200 = 13.02
100-200 = 12.55 return
1/4 mile = 12.97
      04-07-2020, 03:50 PM   #65
Solid67
Do you think I could run it with BM3 Stg 2 E30 OTS? I would be happy to get the parts list from you to make my own.
      04-07-2020, 07:23 PM   #66
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
It really depends on the HPFP rail pressure and the load/torque/boost profile of the map.
If the BM3 E30 maps are like the 93 maps with high load/boost overshoot around 3000 RPM then you may already be at the limit of the HPFP and adding more boost will just result in a HPFP crash.
Do you have any current BM3 Stage 2 E30 OTS logs you can share? PM me if you'd prefer.
