BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 - Time slips/0-100kmph/100-200kmph thread!
      04-07-2020, 08:24 PM   #67
Solid67
Drives: 2019 M240i xDrive MP Edition
Originally Posted by OzBMR View Post
It really depends on the HPFP rail pressure and the load/torque/boost profile of the map.
If the BM3 E30 maps are like the 93 maps with high load/boost overshoot around 3000 RPM then you may already be at the limit of the HPFP and adding more boost will just result in a HPFP crash.
Do you have any current BM3 Stage 2 E30 OTS logs you can share? PM me if you'd prefer.
stg 2 93:
https://www.bootmod3.net/log?id=5dfe...729b4642a50c7f
stg 2 e30:
https://www.bootmod3.net/log?id=5d6d...90c652e3aa327e
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
      04-07-2020, 11:49 PM   #68
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
You definitely wouldn't be able to use a MAP signal spoofer with either of those maps as they are already close to the point of HPFP rail pressure lower limit.
With the Stage 2 93 map the car hits 1116 PSI vs target of 2878 PSI at 4242 RPM This is because of the relatively high boost of 18 - 20 PSI between 2900 - 4500 RPM By comparison MHD equivalent map has about 16 - 17 PSI in the same area.
The Stage 2 E30 map gets to 1522 PSI vs target of 3100 PSI at 4357 RPM with boost 0f 18 - 20 PSI between 3200 - 3800 RPM.
Adding boost on top of that would result in hard crashing rail pressure.
I'm surprised BM3 haven't lowered the load/torque targets in their maps to better cater for the HPFP limits. They should target 170 - 175 Load Target at WOT from about 2000 RPM to about 4500 RPM then ramp it up.
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s
Quarter mile 10.93@127mph
      04-10-2020, 04:09 AM   #69
Stampe
Denmark
18
Drives: BMW F30 lci 340i
Originally Posted by Stampe View Post
Hi
It's been time for some stock times so many don't feel theirs is slow,
340i rwd , 8 speed - bone stock - 1 person - 70% tank
dragy.
0-100 = 5,09
100-200 = 13.02
100-200 = 12.55 return
1/4 mile = 12.97
New time with mppk same day/road as 13.02 new time 11.12
      04-14-2020, 11:22 PM   #70
boosted
enthusiast
boosted's Avatar
Drives: 2018 340i x-drive 8AT
How to view those staging lights to know when to get on it? When I switch to video I don’t see it.
How to use it overall? I connected to satellite.
Just got Dragy but will run tomorrow.
2018 340i x-drive 8AT - MP (Mission Performance) stg 3 DME tune, Xhp stg 3 EGS tune, catted AA downpipe, NGK plugs, E30 blend - 11.4@120mph.
      04-15-2020, 07:13 AM   #71
Glemm1970
Glemm1970's Avatar
Russia
316
Drives: BMW M140IX.
My results with this auto configuration:
MHD stage 2 98 RON. CSF Intercooler Radiator, Full Catalytic Exhaust, Cold Inlet. 0-100 3.66c. 100-200 8.2c. 0-402m 11.6c. When using methanol with control through JB4, the results so far are: 0-100 3.6 s. 100-200 7.7s. 0-402m 11.34s
      04-15-2020, 10:42 AM   #72
yokata
yokata's Avatar
Bulgaria
156
Drives: Bmw F30 340xi
Is this xdrive?
      04-15-2020, 10:56 AM   #73
Glemm1970
Glemm1970's Avatar
Russia
316
Drives: BMW M140IX.
M140IX x-drive.
      04-15-2020, 11:03 AM   #74
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
I’ve never used or own a dragy. But from the videos I’ve seen, I believe the staging lights come on automatically before it detects the car moving. It doesn’t pop up and you don’t have to respond to it. It’s an overlay on the video after it has been recorded.
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
yokata156.00
boosted116.00
      04-15-2020, 01:20 PM   #75
Solid67
I have the same issue as you and I use an android phone. Not sure if it is just android users that have this issue.
      04-15-2020, 03:07 PM   #76
IMS-340C
IMS-340C's Avatar
Egypt
395
Drives: Self Tuned 340i 8AT RWD
Open the Dragy app> me>videos
Choose the video you want then tap next on the top right corner then tap export also on the top right corner.
The Dragy app will set the staging lights automatically.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT --------
boosted116.00
      04-15-2020, 04:39 PM   #77
B58togo
Drives: M240i
11.30's in the quarter. Nice! Won't be long before we see a stock turbo OG B58 in the 10's.
      04-15-2020, 05:07 PM   #78
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
A guy with an M140i, stock turbo custom tune by F80Paul and meth injection did 10.84@127.87mph on 23rd Feb 2020 https://www.picuki.com/media/2250388541683278488
I plan to get into the 10's on stock turbo without meth
Nugget649.50
B58togo808.50
      04-15-2020, 06:19 PM   #79
B58togo
Drives: M240i
Dayuum! Can't wait to install my Dorch pump Friday. This cold weather sucks though. Need it to warm up a bit before I start tuning with Paul.
      04-15-2020, 09:34 PM   #80
boosted
enthusiast
boosted's Avatar
Very happy, overall, changing signature . With some practice, I can drop a bit more.
Only flash and catted downpipe in signature. 0-60 3.56s
VipinLJ1941.50
OzBMR574.50
      04-16-2020, 12:12 AM   #81
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
Nice times.
Do you have xHP tune for transmission? I'd expect a 60ft time of 1.7 seconds or better with X drive in a tuned car.
Also, are you starting in 1st or 2nd gear?
      04-16-2020, 02:04 AM   #82
enemigo13
Drives: F32 LCI 440xi citrineblack
340i xdrive.
boosted116.00
OzBMR574.50
      04-16-2020, 02:10 AM   #83
boosted
enthusiast
boosted's Avatar
Nice times.
Thanks!
I have MP stg 1 trans flash, so I’m all set.
I did break torque around 2300rpm (last night) in D and Sport +.. not manually shifting to 1st or 2nd gear. I need to practice to achieve 1.7s or lower.
Any suggestion - I’m all ears as this is my first AWD
OzBMR574.50
      04-16-2020, 03:08 AM   #84
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
Thanks!
With xHP you can adjust launch control for even faster AWD launches.
A lot of people have recorded quicker times by being in Sport+, shifter to the left, manual shifting, and launching from 2nd gear. This eliminates 1 x gear change to 60 mph and is quicker for quarter mile.
Rev 2nd gear out to about 6800 RPM, change 3rd and 4th at 6500 RPM.
Rev 5th out to 6700 RPM and record 100 - 200 km/h and 60 - 130 MPH times too
boosted116.00
      04-16-2020, 12:36 PM   #85
boosted
enthusiast
boosted's Avatar
Sounds good
I’ll try it this weekend, thanks.
      04-17-2020, 05:13 AM   #86
GM_Gang
Russia
Drives: BMW 320xi lci b58 swap
320xi swapped in 340xi
Tune: Stage 2 KK-Performance
Downpipe: Mikes Custom
First and only attempts[IMG][/IMG]
Supr3me552.00
VipinLJ1941.50
kern4174449.50
      04-17-2020, 11:22 AM   #87
yokata
yokata's Avatar
Bulgaria
156
What size wheels and tyres r u currently running?
      04-17-2020, 11:24 AM   #88
GM_Gang
Russia
Michelin PS4, stock 18 inch 400m wheels. 225 mm front and 255 mm rear
