BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Trouble coding battery with Autel Maxisys Ultra (2018 340i xDrive)
      01-14-2024, 03:36 PM   #1
GarageSL
GarageSL's Avatar
Drives: E36 M3, E34 530i, 1974 '02
Hi everybody, first post here, tell me if I do something wrong
So I was trying to code an 80Ah battery instead of an 90Ah battery on a 2018 340i xDrive with my Maxisys Ultra, looking in the RETROFIT menu, thinking I would find all the options there but they weren't (the way it was with E90).
Scanner was up to date, everything seemed ok
I am new to any kind of programming so I tried many different menu and, beginners mistake, ended up retrofitting a power option (HO-WORT: NPOW) trying to see if the battery options where there (I will do a second post for the 1F2102 and limp mode triggered by this and how I fixed it if people are interested?).
I finally found the good menu (by selecting NEW ENTRY in the PROGRAMMING menu, which I previously selected only to access the RETROFIT menu at first) and changed E-WORT code from "A090" to "A080". thinking I found the good procedure.
I then went and registered the battery but here is my problem:
---> The registration now indicate that the car is supposed to be equiped with an 80Ah battery (thanks to changing the E-WORT code) but that the DME registered battery is 90Ah. I can't find how to change it to 80Ah and I am worried that it is still going to overcharge the battery.
      01-14-2024, 11:12 PM   #2
TheNine90
Drives: bmw
You can try coding the ca and dme module.
      01-14-2024, 11:13 PM   #3
TheNine90
Drives: bmw
FEM module
NPOW is POWER_KIT_BENZIN
      01-16-2024, 01:59 PM   #4
GarageSL
GarageSL's Avatar
Does the E-WORT data repeat itself in the DME module? So I would need to change it at both places? Or I need to find a different line? Is it also going to be "A090", "A080", etc?
Should I have not changed E-WORT and change it only in the DME?
      01-16-2024, 02:10 PM   #5
GarageSL
GarageSL's Avatar
FEM module
I figured it was something like that �� Thanks for the info, I will not forget this one!
My temporary issue with it is that when I retrofitted it back to normal, it stayed in limp mode, triggering 1F2102.
I only needed to re-program (or is it "update"?) the DME to clear it but it lasted long enough to give me a good scare ��
      01-17-2024, 12:37 AM   #6
TheNine90
Drives: bmw
The coding is in the FEM, DME isnt affected but it will still show the battery capacity in the battery registration.
