01-21-2024, 10:59 PM | #1 |
Rep 2
Perhaps coding can solve my headlight problem?
Hello all. I have an F30 on which I have swapped out the standard headlights for some custom LED ones. Now Ive had them for over a year with no issues (worked totally fine without any coding).
However, a couple of days ago, I started to have an issue with the passenger side DRL. At first, the DRLs would come on during unlock (welcome phase?) however, now only the drivers side DRL turns on. During the day (lights on auto feature), both of the DRLs are working fine. However, during night time, when the low beams are turned on, yet again, the passenger side DRL does not work. Now I am assuming that something as gone bad with the wires. However, I was curious if there was some Bimmercode workaround, or something clever that yall with more experience can come up with to code around this problem. I think it can potentially be done because the DRLs still work perfectly fine during the day, but the combination of low beams and DRLs causes the passenger side to fail for some reason. Thank you very much |
