BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Rear fog light coding
      08-27-2018, 04:21 PM   #1
cesarortiz23
cesarortiz23's Avatar
Drives: bmw m2 lci
Hello you guys
Can you code the rear fog lights to work with the bimmercode app
And if you can what's the steps
I already modded the switch etc.
But now just need to code the car
bmw m2
      08-27-2018, 06:50 PM   #2
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
Contact the author of BimmerCode and ask him.
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      08-27-2018, 06:54 PM   #3
paimon.soror
paimon.soror's Avatar
Drives: 2016 F36 435x MSport
https://www.normalexception.net/BMW-...rear-foglight/
shameless plug but all the data you need is there
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current
sspade2466.00
      08-27-2018, 08:36 PM   #4
cesarortiz23
Drives: bmw m2 lci
so I looked it up on bimmercode app
And it seems to be there
But idk what exactly you change
The values on the picture is what is showing already on the bimmercode app
That's is what I see on my app
On the default setting
L output off
R output off
Or what exactly am I suppose to change them to
bmw m2
      08-27-2018, 08:44 PM   #5
paimon.soror
ah sorry ill have to fix that formatting for mobile.
Code:
ECU	        Module  Option	                        Default	        New Value
FEM_BODY	3060	NSL_Verbaut	                nicht_verbaut	Verbaut
REM	        3063	Mapping_Nebelschlussl_L_output	off	        nsl_l
REM	        3063	Mapping_Nebelschlussl_R_output	off	        nsl_l
      08-27-2018, 08:56 PM   #6
cesarortiz23
Drives: bmw m2 lci
Perfect
Now it worked lol
Thanks dude
bmw m2
      08-28-2018, 05:34 AM   #7
cesarortiz23
Drives: bmw m2 lci
Code:
Hey boss one last thing maybe you can help me out with this
I am installing led reverse lights tomorrow I obviously need to code that they are now going to be leds
But if the bulbs flicker what can I code or what do I need to code to not have it flicker on bimmercode app
Thanks for the help in advance
bmw m2
      08-28-2018, 09:48 AM   #8
paimon.soror
sorry bud, that one i dont have the answer for
There is a coding thread floating around here, i dont have the link handy, but def ask in there.
      08-28-2018, 10:03 AM   #9
oranga
Drives: 335 6mt
I installed LED bulbs everywhere and used Bimmercode to update coding. The bulb options should be available on the main page of the Rear Electronic Module. Just toggle the warm + cold checks to off, and the lamp types to LED.
      08-28-2018, 01:42 PM   #10
cesarortiz23
Drives: bmw m2 lci
Thanks
bmw m2
      08-28-2018, 11:14 PM   #11
cesarortiz23
Drives: bmw m2 lci
video in motion question
Do I have to code something to watch videos through usb
Right now I can only watch dvds
can I watch music videos from a usb
I have the cic headunit ...
bmw m2
      09-01-2018, 08:26 AM   #12
Sunny_TK
BMW Newbie
Sunny_TK's Avatar
Drives: 2015 335xi MSport
i believe that dvd's is your only option that will work. I tried coding this as
      10-09-2018, 04:59 AM   #13
B530e
B530e's Avatar
284
Drives: 2023 BMW 760xi, 2024 BMW 530i
2021 BMW 540i  [0.00]
2020 BMW 530e  [0.00]
Code:
Good Evening, I tried to code my rear fogs with the information above and was unsuccessful. I was able to mod the button and activate the indicator light however that's all that worked. Any idea why?
I drive a 2018 430i Gran Coupe
      03-05-2019, 10:32 PM   #14
KlEaR
Drives: M4
Instead of starting a new thread, I just coded my m4 and did the button modification and i have the rear fog light indicator on the dash when the button is activated, but the rear fogs do not turn on in the tail light. Anyone have suggestions? 2018 M4
The coding is correct, went over it a few times to verify. TIA
      03-06-2019, 02:20 AM   #15
cjn
Drives: 2021 F40 M135iX
Another setting to check is
REM / 3063
MAPPING_NEBELSCHLUSSL_L_FUNCTION
MAPPING_NEBELSCHLUSSL_R_FUNCTION
These should both be set to 0E (fog light), which is the default value
Also, silly question, is there actually a working bulb installed on each side?
Your rear lights are LED but I think they still use the H21W halogen bulb for the fogs. Check there's not just an empty socket.
      03-06-2019, 05:36 PM   #16
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
You should have asked this or did a b4 buying or doing any of the work regarding rear fogs
Rear fogs do not work on the LCI tails
Been there done same as you early on. Wasted $$ on a new OEM headlight switch sold it on the forum to recoup
      03-07-2019, 05:36 AM   #17
cjn
I had mistakenly assumed that the 2018 F82 would have the same setup as the 2018 F30. Not so, the F30 still has the H21W for the fog light, while the F82 is all-LED. Since this applies to the Euro models as well as the US, and the former must have a fog light available somehow, it may well be that the US F82 can be coded for this function.
      03-07-2019, 06:17 AM   #18
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
In my case I have 2015 F32 - retrofitted to the US LCI tails (same as F82 US LCI tails) and the professional well known coder from this forum that I was working with to do remote coding stated there is no way to code these specific tails for rear fogs...
      03-07-2019, 08:26 AM   #19
B530e
B530e's Avatar
284
I was able to figure it out. The rear fog lights use the same lights as the Rear Brakeforce Lights which are the turn signals. I noticed BMW moved the Brakeforce lights in LCI models when I read the manual. I’ll post pics later
      03-07-2019, 04:07 PM   #20
rlmesq
Drives: 2018 440i M Sport
Too bad you sold the switch. Rear fogs DO work on LCI taillights, but the coding for 4 series is different from the 3 series.
https://f30.bimmerpost.com/forums/sh....php?t=1410454
Edit: I noticed that yours are retrofitted to a pre-LCI car. That may be different.
      06-13-2019, 11:59 AM   #21
thakk
thakk's Avatar
Drives: 2014 328i xdrive
Hi Guys,
Necroing an old thread, but I jsut got my Euroswitch and tried setting up my rear fogs.
My left one works fine, but my right one activated my reverse light and not the fog light.
I'm not sure if it is a coding issue and I cannot read german, so don't know what I should be looking at in expert mode of bimmercode on android.
Here are a couple of pictures.
      06-14-2019, 08:55 PM   #22
thakk
thakk's Avatar
So to reply to my own post, I restored the REM module setting and then reapplied the coding for the rear fogs. It worked this time without issue.
Thank you for the code. It worked well.
