07-19-2020, 04:31 AM | #287 |
Rep 420
Updated my results. Firmware for 98Ron, but fuel was poured by E20, plus WMI JB4 Map6. Checked at night, on plain asphalt. The road is slightly uphill.
M140IX. Turbo Pure 800 Cast.
07-20-2020, 05:49 PM | #289 |
Rep 585
Starting in 4th at about 3000 RPM change into 5th at 6500 RPM and run through to 6500 RPM in 5th seems to be best.
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s Quarter mile 10.93@127mph |
07-22-2020, 04:11 PM | #290 |
Rep 242
AGAIN the DA is killing me but e30 makes big difference to my 100-200 times im recommending it to everyone that is considering to go this way! https://www.bootmod3.net/log?id=5f17...0b432a4784fa46
07-27-2020, 06:20 PM | #292 | |
Rep 345
07-27-2020, 10:10 PM | #293 |
Rep 164
07-27-2020, 11:18 PM | #294 | |
Rep 585
07-27-2020, 11:40 PM | #295 | |
Rep 164
08-01-2020, 12:50 AM | #296 |
Rep 585
Queensland Raceway drag strip results from today. Perfect conditions and 1.69s 60 ft times.
Ran Dragy too and same 1/4 mile result, better 100-200 time than previous best I'll post the logs over in the log review thread.
08-01-2020, 09:25 AM | #298 | |
Rep 1,369
Seriously thinking about switching to MHD. I'll be lucky to trap 123-124 in perfect conditions once the weather cools off a bit.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
OzBMR574.50 |
08-01-2020, 11:44 PM | #299 | |
Rep 585
When MHD released the Stage 2+HPFP E30 they referenced a test car M140iX that did a 10.72@128mph, 100-200 in 6.97s and 0-60mph in 2.87s. No mention of other mods or whether meth was used. X drives are popular for the quarter mile and 0-60mph stuff. Maybe one of the quickest RWD's? Shows that the stock air intake, filter, charge pipe and exhaust aren't causing much in the way of restrictions. My hardware mods are CG-Precision 200 CPI catted downpipe, Dorch Stage 2 HPFP, front silencer delete (for a little more exhaust noise), E40 fuel and sticky tires.
08-01-2020, 11:46 PM | #300 |
Rep 585
Here's a 0-100km/h time recorded at the drag strip as well
08-02-2020, 12:02 AM | #301 |
Rep 1,067
08-02-2020, 08:31 AM | #302 |
Rep 1,369
Your 0-60 mph is in the 2.9x range with rollout. That's insane for RWD. What drag radials are you running?
08-02-2020, 08:12 PM | #303 | |
Rep 585
Also with the conditions and grip levels I had to revert to 1st gear launches. 2nd gear I couldn't get better than 1.8s 60ft. 1st gear resulted in 1.68s 60 ft If the track surface/conditions are limiting grip 2nd will be quicker, but for conditions like last Saturday even 1st gear I could just brake boost and 100% pedal off the line with no slip.
08-02-2020, 10:12 PM | #304 | |
Rep 10
08-02-2020, 10:41 PM | #305 |
Rep 585
Yeah, just small burnout to warm and clean. I have some external video of the runs I'll put together and post a link to soon.
GM_Gang4.50 |
08-02-2020, 11:09 PM | #306 | |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
Awesome time!
10.84@127.87 He was stock turbo with a custom e50 tune and meth. [IMG]https://supra.***********.com/attachments/1582523702429-png.35374/[/IMG] |
OzBMR574.50 |
08-04-2020, 10:43 AM | #308 | |
Rep 13
Or is separate topic about tires for best grip for f20/22? Last edited by vladyslav-r2; 08-04-2020 at 10:48 AM.. |
