BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - NY / NJ / CT / PA > *SOLD* GFB DV+ Diverter Valve for N55
      05-08-2020, 10:01 AM   #1
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
Arrow *SOLD* GFB DV+ Diverter Valve for N55
I Have FS: SOLD
(1) NEW/UNUSED GFB DV+ Diverter Valve for N55 #T9356 (Not compatible with the M2)
I Purchased this New for my 435 N55 from Mike @ XPH, so it is Guaranteed Genuine, Decide To Go Another Direction with My Build...
By retaining the factory ECU control and recirculating the vented air, the DV+ is a purely performance-oriented product that offers the following benefits:
  • Sharper throttle response
  • Faster boost recovery on gearshift
  • Solves boost leaking issues
  • Built to last
> Retains the factory solenoid coil for seamless integration
> Replaces plastic valve parts with metal for reliability and strength on chipped engines
> Direct-fit replacement with GFB’s TMS benefits
> Exclusive “pilot-actuated” valve mechanism for rapid response at high boost
This currently goes for $135 from XPH...
SOLD! to ghatiey1990 - Thanx!
No Worries Dealing with Me - Check My iTrader/Long Time Forum Member
Includes All That Came Originally
https://gfb.com.au/products/blow-off...abarth-detail/
From the Mfg:
GFB expands the DV+ range with a direct-fit solution for the weak factory diverter valve used on many European vehicles.
The solenoid coil itself from the factory-fitted valve is great (the ECU opens it faster than any pneumatic valve so why replace it?), but the weak point however is the valve mechanism itself. So GFB’s DV+ solves this problem by replacing just the valve parts with an anodised billet aluminium housing fitted with a brass piston machined to exacting tolerances.
The end result is sharper throttle response, lightning-fast valve actuation, and it will hold as much boost as you can throw at it.
On with the Pics:
      05-09-2020, 10:02 AM   #2
ghatiey1990
Drives: F30 335i
Pmed
      05-09-2020, 03:12 PM   #3
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Replied
      05-09-2020, 05:07 PM   #4
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
