12-08-2022, 10:58 AM | #1 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
[CODING] Disable license plate lights when shifting into reverse - PERFECT FOR NIGHT
On the F3X platform the rear bumper is visible on the backup camera view, and at night the license plate lights reflect off the bumper making it very hard to see. Using e-sys I coded the rear electronics module (REM) to turn those lights off when I put the car into reverse. Shifting back into drive or any other shifter position turns the lights back on, they only turn off in reverse.
Much easier to see now! This may be possible using one of the phone apps but I used e-sys. Here are the coding parameters: Code:
[REM] MAPPING_UNIVERSAL_2_OUTPUT Werte=00(off) to Werte=22(kzl) [REM] MAPPING_UNIVERSAL_2_PART_OF_WL not_active to hard_on [REM] MAPPING_UNIVERSAL_2_FUNCTION Werte=0C(bremslicht) to Werte=0F(rfs) [REM] MAPPING_UNIVERSAL_2_PRIORITY Werte=02(priority_2) to Werte=00(priority_0) [REM] MAPPING_UNIVERSAL_2_FIXED_PWM Werte=00(pwm) to Werte=01(fixed) To adjust the KZL (license plate light) brightness, change the following value in hex. [REM] MAPPING_UNIVERSAL_2_PWM_LEVEL_1 Werte=00(off) to Werte=00 to 64(100%) |
12-09-2022, 05:09 AM | #2 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
That’s a great find!
Do you happen to know how to make the LED DRL lights go dim while using turnsignal on a PRE-LCI ? I did manage to make them dim whilest using my warning blinkers. (I think I did it though) |
12-10-2022, 02:01 AM | #3 | |
E36fiend
285
Rep 637
Are you talking about the front or rear DRL? You mean the angel eyes? What exactly is your intent? |
12-10-2022, 08:38 AM | #4 |
Rep 16,088
That's one way to fix the problem when you've got a white or light colored car. Another is to put a bit of black electrical tape over the bottom of the camera lens, so that it doesn't see the bumper.
12-11-2022, 02:49 AM | #5 |
E36fiend
285
Rep 637
01-26-2024, 07:58 AM | #7 |
Rep 207
Drives: 2012 335i Sport
Coded this yesterday and made a huge difference even on my darker colored car, highly recommend for anyone with a backup camera, thanks for sharing the coding steps!
01-26-2024, 01:29 PM | #8 |
Rep 16,088
Another piece of the puzzle is the backup lights. The camera adjusts its brightness to the brightest spot in its field of view. If you have stock halogen backup bulbs that's going to be the bumper. I have these, which are four times as bright as halogen, so the bumper isn't the brightest spot. Even better, I can see where I'm going. https://www.amazon.com/dp/B01H54SP6O...t_details&th=1
01-27-2024, 12:26 PM | #9 | |
Rep 595
Drives: 2018 F48 X1 xDrive 18D
01-28-2024, 06:33 AM | #10 | |
Rep 595
01-28-2024, 08:26 AM | #11 |
Rep 16,088
There is no such thing as plug and play LED, no matter what the advertising says. They must be coded. With Bimmercode it's a one click job. If you don't have Bimmercode you should, I've coded at least fifteen different items, not including LED on all of my lamps.
01-31-2024, 07:46 AM | #12 |
Rep 595
Ordered similiar LED bulbs waiting for them to come.
Also did this coding on F48. I only had to use UNIVERSAL 3 as I was not sure if 2 was in use or not. Really makes a difference. I coded them to ‘20’ so 32% brightness instead of totally off. |
04-05-2024, 07:54 AM | #15 | |
Rep 50
I do have BimmerCode but i have only used this for the obvious things, like folding mirrors and turning off auto start/stop. Thanks in advance! EDIT: I did some searching and found the answer on the BimmerCode site, thanks! Last edited by Bas_Met_Wielen; 04-05-2024 at 09:42 AM.. |
