12-18-2019, 07:18 AM | #3038 |
Rep 22
Nope, no success. I connected ICOM, established connection with E-sys but nothing works.
Then I tried again with Ista+, I tried to diable Transport mode, but it didn't help. The ignition of the car can't be turned on/off. The dashboard turns on when I connect the car battery. When I click "calculate measures plan", program just hangs, nothing works, I even left it for 20 minutes andnothing happened. Any clues, maybye I'm doing something wrong or I really bricked ECU. |
12-18-2019, 07:48 AM | #3039 |
Rep 2,302
12-18-2019, 07:55 AM | #3040 |
Rep 22
Nope, I never worked with E-sys I selected connection to ICOM IP Address and I'm trying to read antyhing from the car to make sure it is working before programming. It is e-sys 3.30 with launcher pro 2.8.2 by tokenmaster.
12-18-2019, 08:09 AM | #3041 | |
Rep 2,302
Do you see the VIN of your car at the connection window? |
12-18-2019, 08:15 AM | #3042 |
Rep 22
I have ENET cable but It somehow doesn't work. ICOM works ok on ISTA+, so I decided to connect to my car through tcp://169.254.92.38:50160 because that IP address is my ICOM device. ENET cable doesn't show under "ZGW" it is greyed out.
I believe that ICOM works with ista+ because ZGW module in my car was corrupted during flashing procedure. That's why ENET will not work. If anyone is interested with helping me to programm DME or whatever is the problem I am willing to pay by paypal. We can use teamviewer for this purpose. Just contact me on pm. Last edited by lukas85; 12-18-2019 at 10:40 AM.. |
12-18-2019, 12:18 PM | #3043 | |
Rep 40,783
12-18-2019, 12:23 PM | #3044 |
Rep 22
I'm not right know ath the car. I'll be there tomorrow. What I remember that when I clicked READ ECU the FA poped out but it was 0 (nothing in it).
I think I know wy e-sys is not properly communicationg with icom. I think I need to use "easy conneect utility" to change the bus of ICOM. Last edited by lukas85; 12-18-2019 at 12:38 PM.. |
12-18-2019, 12:42 PM | #3045 | |
Rep 40,783
Connection via ENET is a lot easier and simpler. You say it is not working because ZGW failed flash, but when you connected with ENET 1) Did you bypass E-Sys launcher and use E-Sys Direct? 2) Was MOTOR Running? 3) Did you disable All Windows Defender / Windows or any 3rd Party Firewall applications?
12-18-2019, 12:44 PM | #3046 |
Rep 22
1. No. I always run E-Sys with Launcher pro
2. No, I can't turn on the motor (start/stop doesn't work) 3. Yes windows defender and Firewall disabled, no third party apps. |
12-18-2019, 12:50 PM | #3047 | |
Rep 40,783
You need to put car on a Commercial Grade 50+ Amp Charger, or jump car to another car with its Motor Running. ENET Cable should work, unless you have bad ENET Cable.
12-18-2019, 02:33 PM | #3049 | |
Rep 40,783
Note xxx.xxx.xxx.xxx IP Address of ICOM Hit Reserve Button to Lock ICOM Open E-SYS Click the connection icon Select the car model Select type of connection: "Connection via ICOM / Ethernet:" and put in box = tcp :/ / xxx.xxx.xxx.xxx:50160
12-19-2019, 05:40 AM | #3051 |
Rep 40,783
12-20-2019, 03:32 AM | #3052 |
Rep 22
There is one more thing left. I need to enable "angel eyes". Left lamp was replaced in my F30 2018 and angel eyes works only only on that left lamp. Which "coding" I need to change in order to enable "angel eyes" on right one. Also blinkers doesn't work on both of these lamps.
I believe these are called sidemarkers not angel eyes, I'm not sure. :P Last edited by lukas85; 12-20-2019 at 03:55 AM.. |
12-20-2019, 05:44 AM | #3053 |
Rep 40,783
12-20-2019, 09:23 AM | #3055 |
Rep 40,783
Do as I wrote. VO Code FEM and individual Light Modules.
12-20-2019, 02:27 PM | #3057 | |
Rep 40,783
Connect => Read FA (VO) => Activate FA (VO) => Read (ECU) => Right-Click on FEM_BODY (the ECU itself not the underlying CAFD) => Select CODE.
12-20-2019, 02:45 PM | #3058 |
Rep 22
Thank you for that clear instructions !
You also said individual light modules. How can I check which module is for lights ? Is there any kind of cheat sheet for that? |
