12-20-2019, 02:52 PM | #3059 |
Rep 40,779
Post a picture of your ECU List.
12-21-2019, 05:26 AM | #3061 |
Rep 22
Ok, angels eyes are now working, one of the connection modules where totaly rusted and rotten, I replaced it and it's working. I also reprogrammed my radio to polish langugage finally !! I'm super happy with that.
One last thing. The car is from Canada, blinkers (turn signals) in those lamps are not working, therefore I can't drive this car because noone will see if I'm turning left right. My friend told me that because it is a car from Canda I need to disable "sidemarkers" int those lamps and then blinkers will work. shawnsheridan can you direct me how to accomplish that ? Last edited by lukas85; 12-21-2019 at 05:44 AM.. |
12-21-2019, 07:14 AM | #3062 | |
Rep 40,779
12-21-2019, 07:45 AM | #3064 |
Rep 22
Ok, someone said that I need to chenge Typchlussel and than do a FEM VO Code.
here is the link https://cartechnology.co.uk/showthread.php?pid=441542 And that's how my Typschlussel looks like. The problem is I don't know what value should I enter.... |
12-21-2019, 07:54 AM | #3065 | |
Rep 40,779
12-21-2019, 08:02 AM | #3067 |
Rep 40,779
VO Code FEM, and both FLE Modules, but VO Coding FEM to European will affect more than just Sidemarker Lights.
12-21-2019, 08:05 AM | #3068 | |
Rep 22
I'm getting this error after changing value in FA editor
12-21-2019, 08:36 AM | #3069 |
Rep 40,779
"Not all elements of the FA were found in the FA2FP: Type code 8D91"
Means the Option Codes in FA are somehow not compatible with the revised Typschlussel. Need to look at FA for a factory Euro Spec same car, and see where FA differs. Again, this is very broad chnage. You are better off finding Sidemarker FDL Codes and changing only those. Good luck with it.
12-23-2019, 01:22 PM | #3070 |
Rep 22
Ok, some progress with lights. I replaced the LED module (right one) in my car. Now blinkers works in that particular lamp but only for 2 seconds. Then it disables and no longer works.
The left lamp needs to be replaced again, something is totally wrong with this one so now I'm not going to work on it right now, waiting for part to be delivered. Here is the behavior show on left lamp after turning singal right. https://photos.google.com/photo/AF1Q...JSLiMQiMzCSazt So as you can se it only blinks twice....than it shuts off. Ista+ says... Last edited by lukas85; 12-23-2019 at 01:52 PM.. |
01-16-2020, 10:20 PM | #3072 |
Rep 40,779
efrant0.00 |
02-01-2020, 03:46 AM | #3073 |
Rep 1
Hi Guys,
Just starting out here. Got Esys 3.27.1 with psdzdata lite v63.3. EST with PIN is configured and working. Trying to do some coding with an F87 M2C. I'm able to connect, activate FA, load coding values. However when I try Edit FDL all I get is dots with no descriptions. Can I get a hand with deciphering this? shawnsheridan ?? |
02-01-2020, 08:46 AM | #3074 | |
Rep 40,779
http://tokenmaster.blogspot.com/2019...r-pro-282.html
02-15-2020, 03:23 AM | #3075 |
Rep 4
link
Hi shawnsheridan,
Would you mind sending me a link to the working version of Esys and psdzdata? New to this, I want to be sure not screw up something:-) Many thanks in advance. |
02-15-2020, 09:30 AM | #3076 |
Rep 40,779
PM sent.
02-15-2020, 11:47 PM | #3078 |
Rep 151
Drives: 2018, F48 28i
Hi Shawn I am having problems with my first time coding. I use Esys launcher pro 2.8.2. Esys 3.27.1. PSdZ data lite 4.21.32.7. but when I connect and try to VO code. When i tried to code the first ECUs out of four. It stopped working. Would you mind to correct me if I did something wrong. Thanks in advance.
I tried using the PSdZ version 63.3. When I activate FA it was looping If any one can help me with this I appreciate. |
02-16-2020, 03:31 AM | #3079 | |
Rep 2,302
I know the answer, but I’m not Shawn. |
X1604M55.50 |
02-16-2020, 07:08 AM | #3080 | ||
Rep 151
I appreciate any help you can give. Thanks. |
