BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Best Brake Fluid for F30
      07-21-2018, 03:24 AM   #1
djwoodyuk
Drives: F30 335d xDrive 2014
Hi.
I am looking to change my brake fluid shortly.
Which would you recommend?
I have been looking at Pentosin DOT4 LV. Seems good value.
I am not tracking the car, so just need it for fast road.
Also, it is just 1 litre I need?
F30 335d with 370mm Fronts
      07-21-2018, 08:31 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
BMW fluid is no more expensive than most.
Before changing mine I got one of these, to be sure that it actually needed changing:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It showed the water content of my brake fluid at 0%, saving me the bother of changing it when it wasn't due.
      07-21-2018, 08:48 AM   #3
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
https://www.amazon.com/gp/product/B0...UTF8&psc=1
Wow, cool gadget. May have to pick one up. Anyone know what the recommended interval for changing fluid? I seem to remember it being really long, like 100k miles but I could be wrong...
      07-21-2018, 11:29 AM   #4
bheng89
Drives: 2012 328xi
the recommended interval is every 2 years.
I plan to use ATF super blue (or the US variant super gold) when I do it.
2013 328i xDrive | M Performance Exhaust | Injen Intake | DEPO Headlights |
2019 440i xDrive | Muffler Delete |
      07-21-2018, 12:01 PM   #5
Billfitz
Billfitz's Avatar
It's two years or 20k miles, but there's nothing scientific about that interval, they just figure it's better to change the fluid before it gets water in it rather than later. I'm at 3 years but only 12k miles, so I wanted to be sure it was broken before I fixed it, what with the purging and bleeding procedure being the PITA that it is.
      07-21-2018, 01:14 PM   #6
_bdiddyb_
Drives: 2013 335i
Bill, instruction said to dip into reservoir to check. But brake fluid doesn't circulate back up to the reservoir. Don't you need to bleed some out from any caliper to get a better measurement? Cool gadget though.
      07-21-2018, 01:41 PM   #7
rak299
Drives: 2021 M3 6MT
I would expect water content to be highest at the reservoir. At the caliper or in the lines, how would water get in?
      07-21-2018, 02:16 PM   #8
Billfitz
Billfitz's Avatar
+1, the main source of contamination would be water vapor that gets past the reservoir cap. For water to get in further down the line there'd have to be a leak. The directions with the tool say that 2% water content is OK, but I wouldn't wait for it to hit 3% before changing it.
      07-21-2018, 04:41 PM   #9
Polo08816
Drives: 2014 335i M Sport
Castrol SRF hands down. Change out 1x per season since it has such a high wet boiling point.
      07-21-2018, 04:59 PM   #10
sspade
sspade's Avatar
Drives: F30
If its every 20k, why arent dealers performing this under the 50k maintenance warranty?
Has anyones dealer performed this service for free under warranty?
      07-21-2018, 05:31 PM   #11
Billfitz
Billfitz's Avatar
They should, it is a CBS item, just like oil and so forth. I got the dashboard notice that it was due, but didn't take it to the dealer, as that's a 3 hour round trip, plus the time spent waiting. I'd have changed it myself if it turned out that it did need it, and will when that time comes.
      07-30-2018, 04:32 AM   #12
ibn_adam
Drives: BMW M3/F80
CBS!
      07-30-2018, 04:00 PM   #13
MacklinUSOB
Drives: f30 328i 6MT Sport
I use RBF600 and flush once a year. Thinking about trying SRF as I've heard good things, but have yet to boil the RBF. I do a bleed after every couple track days to keep the pedal nice and taught.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
      07-30-2018, 04:02 PM   #14
bimmer456
Drives: 340i
Got my brake fluid done for free as part of free maintenance. Had to pay for new tires though.
      12-09-2018, 02:01 PM   #15
EstorilMSport
EstorilMSport's Avatar
@MacklinOSB how much fluid is required for a full system flush? I’m looking to replace my OEM fluid (about 6 months old) with RBF600 to prep for an HPDE event.
      12-10-2018, 01:53 AM   #16
jh_f30
jh_f30's Avatar
1307
Drives: 2013 335i Sportline Auto RWD
I just did mine with ATE Type 200. 2 liters should be more than enough.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
      12-10-2018, 08:40 AM   #17
MacklinUSOB
@MacklinOSB how much fluid is required for a full system flush? I'm looking to replace my OEM fluid (about 6 months old) with RBF600 to prep for an HPDE event.
As Jh said, about 2 liters/quarts should do the job. I would buy three quarts just in case you over bleed somewhere, worst case scenario you've got an extra bottle when you want to bleed them next. Make sure you do not let the power bleeder go dry (assuming that's what you're using).
jh_f301307.00
      02-12-2019, 09:07 AM   #18
Polo08816
I've been re-thinking this. I used Castrol SRF when I did not have a garage and space to easily put the car onto jack stands. The premium was well worth the time savings to drive 45-60 mins to an Auto Skills Center, spend 1-2 hours to bleed, and drive another 45-60 mins back home.
However, it should be noted that the wet and dry boiling points of RBF600 are only slightly above ATE Type 200. RBF is almost 3x the cost of ATE Type 200. This means that you'll have to bleed RBF600 almost as frequently as ATE Type 200. Even then, the dry boiling point of ATE Type 200 is still higher than the wet boiling point of Castrol SRF.
In conclusion, I think only 2 routes that really make sense are to either bleed frequently (before every other event) with ATE Type 200 or bleed 1-2 times per year with Castrol SRF.
2 quarts is more than sufficient to do the job. You could do both a standard and DSC bleed with that amount of brake fluid.
      02-13-2019, 11:13 PM   #19
bavarianride
Drives: bimmer
My 2013 F30 had two brake fluid change under 4 years/50000 miles of free maintenance.
At year 6 mark, both brake fluid and coolant were changed@dealer for $250 with BMWNA coupon.
      02-14-2019, 11:01 AM   #20
FaRKle!
2L/qts is WAYYYY more than you need. 1L is plenty to change out the whole system (I've done it, and still had some leftover). I disagree with buying 3 quarts (especially if you're getting the expensive stuff like SRF). Also, if you're planning on "using the leftovers later" I'd try to put the brake fluid bottle that you opened in a hermetically sealed container/bag to prevent moisture intrusion.
      02-14-2019, 12:06 PM   #21
MacklinUSOB
Using opened containers is not something I suggested. If it's opened and there is some left, toss it.
Having an unopened bottle of brake fluid is a good thing to have, every person I know who goes to a track has one just in case. If you are bleeding for the first time it is easy to overbleed. If that happens and you have no extra, good luck driving to the store for more.
      02-14-2019, 04:52 PM   #22
Polo08816
That's what the parking brake is for. Who uses the foot brake anyways? That shit is for pussies. Wide open throttle and ripping the parking brake for the most epic drifts is the only way to drive.
