01-22-2023, 06:29 PM | #1 |
Rep 1,467
Who here is running BM3 Stage 2 93?
I am running bootmod3 stage 2 93 and my car pulls timing across the rev range. This is the same thing that happened on my n55 Bm3 93 tune. PTF always blame the octane but isnt 93 the same everywhere?
Are there OTS 93 maps bad? I think its odd that both my cars do this on 93. Im also noticing that my 60-130 dragy time is 2 seconds slower than were I should be with exact mods and tune. Can anyone share some logs with this tune?
01-22-2023, 08:10 PM | #2 | |
Rep 5,394
01-22-2023, 08:12 PM | #3 |
Rep 275
Drives: 2018 440i xDrive Gran Coupe
If you have some E85 near you, add a couple gallons and see if it helps. The BM3 93 tunes are really finicky about gas quality, I’ve had the same issues.
01-22-2023, 08:51 PM | #5 | |
Rep 931
01-22-2023, 08:59 PM | #6 |
Rep 1,467
I know but if i want to run e85 then id just run the e30 map. I should be able to run a 93 octane and have the car run right. Im gonna get shell gas and start testing different maps and see what happens.
01-23-2023, 07:29 AM | #7 | |
Rep 2,639
Never assume gas quality is good or the same at any gas station you go to, BM3 OTS maps are also very conservative (I know because I was one of their testers for 91 and ACN91 for PWG, same with the Stage 2H maps.) MHD on the other hand has aggressive OTS maps as EU fuel is considerably better than NA, and most of their OTS maps are made over there. If you really want to just flash a map and forget, get their flexfuel kit (which I have) and use their multimap with it, it'll auto adjust the maps based on Ethanol content (0% to 100% ethanol, depending on map maximum) which is why I use E10 91 octane, as my normal 91 oct is shit here in NS, the flexfuel kit uses the 10% ethanol and clears up timing corrections.
Insane435477.50 |
01-23-2023, 05:00 PM | #8 |
Rep 1,467
So I added a gallon of e85 and the logs look better. Thought on these? It has to be the poor 93 winter mix quality.
https://www.bootmod3.net/log?id=63ce...729b0e1c00df0d https://www.bootmod3.net/log?id=63cf...0b43db0b51bc5e
01-23-2023, 05:35 PM | #9 | |
Rep 1,454
And I've rarely seen a clean timing log on any of the BM3 pump gas tunes. But all their E mix tunes run great. I suggest grabbing a TU and just running a Stage 2+ E30 map if it's convenient enough for you.
2022 CT4-V Blackwing 6-speed
Insane435477.50 |
01-23-2023, 05:52 PM | #10 | |
Rep 93
I usually run the Stage 2+ E50 tune though because the power is incredible and addicting
Chicago (@gp_f30 on insta)
F30 340i xDrive M-Sport (Alpine/Coral) Stage 2+ F30 335i (Alpine/Coral) - SOLD |
Insane435477.50 |
01-23-2023, 06:05 PM | #11 | |
Rep 1,467
2020 M340ix
G.Newt810.00 |
01-23-2023, 09:32 PM | #12 | |
Rep 2,639
https://www.bootmod3.net/log?id=63a4aa3fc090c6712c064b34 Ez |
01-24-2023, 12:26 PM | #13 |
Rep 275
01-24-2023, 01:56 PM | #14 |
Rep 2,639
01-25-2023, 12:38 PM | #15 |
Cheapskate
4450
Rep 4,993
Clean 93 logs are very rare. Even the stock tune has some timing pull.
Like most, I added some E85 to a few tanks and, after seeing the improvement, just switched to E30. No regrets. If you want a clean 93 tune then your best bet is to go with a custom tuner. But keep in mind you can travel somewhere with worse quality fuel and still run into the same issue. It's just a part of the tradeoff. |
01-25-2023, 08:21 PM | #16 |
Rep 126
Can someone explain to a BM3 newbie where the timing pull can be observed?
I've read lots (but have lots more to read) and viewed several logs about pulling timing. Can someone post a graph where there is the timing being pulled so I can see what it looks like? I am running BM3 Stage 3 93 octane myself so wondering if the same thing is happening to me. I feel an initial surge sometime (like boost building up), then it seems the engine reduces power a bit for a second, then the power seems to go back up again. |
01-25-2023, 09:04 PM | #17 |
Rep 1,454
Datalog parameters -> Advanced -> RAM -> Timing Correction. Or something like that, it's been awhile since I've had the car. You want to enable all 6 cylinders.
If those numbers aren't 0, there's timing correction. Although up to -3 in a cylinder or 2 is acceptable. If you're getting timing corrections across several cylinders throughout the pull, most likely your fuel quality isn't good enough. There's a dedicated Log Review thread on this first page where you can post it and have others take a look.
Wires1645.50 |
02-19-2024, 02:35 AM | #18 |
Rep 3
Drives: 2014 435i coupe
Having the same exact issue rn. currently running an e30 blend, fbo 435i. i haven’t logged it since switching the to e30 map but when i was on 91 i noticed how slow my times were compared to other cars. now that im on e30 it honestly doesn’t feel that much different, 60-130 times are almost identical. i need help with this issue
02-20-2024, 05:19 AM | #19 |
Rep 74
You'll have to log it, otherwise anything anyone says will just be a guess.
I was recently dealing with AFRs that were not in line with what I thought they should be for boosted applications and received some good feedback about it, but it was all dependent on my logs. In those logs, I saw what I was looking for, but relevant to this thread, I could also see the timing pull. You can also compare your boost target to boost actual values. For example I saw when I ran the Stage 2 91oct map, my boost bled off by 2 psi over the rpm band... What gives? Well, I was able to compare it to the log and saw that my the boost TARGET bled off at the same rate. So my car was doing exactly what it was supposed to do. ...anyway, that was a just a long winded post that I hope gets across the point of how important your logs for helping diagnose performance issues. Post your logs. |
02-20-2024, 09:51 AM | #20 |
Rep 3
02-20-2024, 10:05 AM | #21 | |
1296
Rep 3,533
02-20-2024, 04:42 PM | #22 | |
Rep 202
