BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > What's all needed for PI
      03-19-2024, 03:14 PM   #1
Bxrger
Bxrger's Avatar
75
Drives: Bmw
I’m planning on ordering the PR port injection this week and seeing what is all needed to it to run properly, I am wanting a flex fuel map tune. I already have reflex plus in my cart as well and a stage 3.5+ lpfp on the way soon. Will I need any other specific sensors / lines for install or is the kit from PR everything i need. Thank you!
Bxrger
      03-20-2024, 12:18 AM   #2
jav140i
jav140i's Avatar
Drives: BMW M140I
You will also need, Flex Fuel Sensor + Reflex Ethanol Sensor Harness and i also recommend reflex Pressure Sensor, and maybe i don't know your fuel lines but perhaps Ethanol 360 Fittings to fit Flex Fuel Sensor correctly. ooh and check if you have a USB Data cable because you will need it to update reflex maps.
      03-20-2024, 11:04 AM   #3
Bxrger
Bxrger's Avatar
75
Drives: Bmw
What size injectors do you recommend for goals of 750-800 whp?
Bxrger
      03-20-2024, 03:22 PM   #4
jav140i
jav140i's Avatar
Drives: BMW M140I
750cc is more than enough
