03-21-2018, 02:58 PM | #1 |
Rep 2,598
Wheel Alignment
Hi all,
Had my H&R springs fitted today & a wheel alignment done at the same time. I have 245/35/19 front & 265/35/19 rear tyres & the lowering quoted by H&R is 20-25mm front & rear. In reality upfront it’s more like 30-35mm. Car feels great, except in the very small amount of driving I’ve done so far I’ve noticed that the rear is braking traction more often than it did prior to being lowered. Any thoughts on this - here is my alignment print for refrence! |
03-21-2018, 03:16 PM | #3 |
Rep 2,598
03-21-2018, 04:35 PM | #5 | |
Rep 15,858
Could simply be the stiffer suspension contributing to less consistent grip. Harder to follow the road contours and more bounce, therefore less grip. Stiff suspension can compromise tyre grip. It is well documented. |
03-22-2018, 02:54 PM | #8 | |
Rep 1,453
03-23-2018, 06:01 AM | #9 |
Rep 15,858
03-23-2018, 12:11 PM | #10 | |
Rep 2,598
I've lowered all my cars over the last 10 years and never really had any detrimental (to my driving style / ability anyway) effect on the cars handling or drivability. I was just concerned that something might not be right as the TC was flicking on more than usual - but having driven it a few times now since fitting all seems to be OK! |
03-18-2020, 09:32 AM | #11 |
Rep 1,721
Hey guys, just a quick question
I am due to get the wheels aligned shortly due to inner tyre wear, i have radar cruise, lane departure etc, would these systems need recalibrating once the alignment is complete? Cheers |
03-18-2020, 10:15 AM | #12 | |
Rep 810
If its shoulder wear, particularly on the front tyres, this is usually under-inflation. RFT's are particularly bad for this due to the huge sidewall strength. X-Drive cars shouldn't have enough camber at the rear to cause uneven wear (<1.3 Deg i think), but you typically need over 2Deg negative to cause this, which is easily view-able when looking down the length of the car. |
03-18-2020, 10:42 AM | #13 | |
Rep 1,721
Attached is alignment readings, the guy said to adjust the camber he'll have to start tinkering with the ball joints/lower arms, I thought it'd be best seen by bmw, so didn't go ahead ? Do you think that it could be adjusted or will the arms have to be changed ?
ICE
Fronts: Morel Hybrid Ovation II 4, Rears: DLS R4, Center: Focal 100CA, Subs: Earthquake SWS8, JL 10W7, Amps: Audison LRX 6.9, Audison LRX 2.9, JL Slash 500/1 V2, DSP: JBL MS8 |
03-18-2020, 11:43 AM | #14 |
Rep 25,113
I wouldn't think they need re-calibrating? If a windscreen or the other sensors themselves like the radar unit) but I'd be surprised due to wheel alignment
My car made front page of Bimmerpost
03-18-2020, 04:33 PM | #15 |
Rep 810
05-04-2021, 04:26 AM | #16 |
Rep 2
Hi R99,
Bringing back an old thread as had a question as to what springs you have fitted. My car is a rwd touring with adaptive suspension. Looking to get some H&r springs like your setup, but there are 2 options that both look identical; 28878-4 28878-3 Which ones did you go for? |
