BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > F33 N20 428i AT Rough idle really worried...
      05-17-2020, 09:49 PM   #1
bmwaddictt
bmwaddictt's Avatar
Australia
22
Drives: BMW 428i F33 M Sport, 320D F30
Question
Hi everyone, hope you are all keeping safe during these difficult times.
My 428i idle's very very rough, almost like its about to stall. I'll give a little back story. I've been running Bootmod3 Stage 1 93oct for almost 10,000kms now all stock and around 5000kms with a catless downpipe and everything was working and driving like a charm. The car then was due for a major service at 65,000 kms with spark plugs oil change etc all required, everything was allgood till the car came up and eventually popped up with 'overdue 500kms' and i started the car one day and it was like it was about to stall. This happens everytime i come to a red light as well and go to a full stop, car is about to switch off, rpms are very rough. I took the car into BMW my service advisor told me that I did not need to remove the tune so I did not. They serviced the car but they didn't see anything wrong with the idle. Stupid if you ask me. As soon as I jumped back in the car started it, immediately I realised... Very stuttery rough start, and if you just tap the accelerator pedal a little and let go the car is almost about to turn off. What could be the issue? There is no codes that come up, but sometimes a transmission ESG error comes up code CF1531 when the vehicle is switched off after a tune update idk if thats normal. I'm really worried. Even flashed it back to stock, still the same problem... Please someone help!! Thank you
Edit: guys could this be an engine knock?? Please see video
2016 428i F33 Estoril Blue | BM3 Navardi Custom Tune | xHP Stage 3 | VRSF Ceramic Coated Catless Dp | MST Intake | FTP V2 Inlet | GFB DV+ | M4 V2 M Perf Steering Wheel | M Perf Diffuser | M Perf Floor Mats | M Perf Side Skirt Decal | Adaptive M Suspension | Ceramic Coated | LCI Radio Trim Retrofit | M4 ASD | Speed Limit Info Retrofit | Wireless Charger Retrofit | Mods4Cars SmartTOP Module | M Blue Calipers | Michelin PS3 RFT | Andream CarPlay
      05-17-2020, 10:35 PM   #2
muniz_ri
Drives: BMW 320I
I would start by checking the spark plug gap. Improperly gapped plugs will cause a rough idle...not to the extreme that you described but still worth checking.
      05-17-2020, 10:37 PM   #3
bmwaddictt
bmwaddictt's Avatar
Australia
22
Hmm right I'll get this checked. By the way, when changing the Downpipe, does the 02 sensor need to always stay disconnected? I think my mechanic did not remove these. The car has been fine ever since the service light came on at 500kms though?
n20, rough idle, rough start, roughidle
