BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Finally added Speed Limit Info
      04-02-2020, 07:06 AM   #463
x-m4n
x-m4n's Avatar
Drives: Gran Turismo (F34)
Originally Posted by Chriske92 View Post
I bought one from China and it is in KM/h. Also if he doesn't have any speed info, i dont't get the 150km. Instead a 3 lines panel
Thanks for the intel and picture - Would it be possible to check what happens if you change the car settings to MPH? - I am hoping the number changes to 30 in that 50KPH road in your picture...
      04-02-2020, 08:31 AM   #464
Suprnowa
Drives: F31
Originally Posted by raphaelpais View Post
Any news? I´ve bought one and can open it once it arrives, but it can take up to a month to arrive.
Nothing has changed in the subject. I am waiting for someone to upload a photo of the opened emulator.
      04-02-2020, 08:32 AM   #465
Suprnowa
Drives: F31
Just installed mine I can say the only difficult thing was to get the connectors out of the instrument panel. The rest was plug-play.
Just to let you know. If you are in a garage you receive 3 small lines. Also after install it needs to adapt, so you will get 3 small lines. But after driving a couple of km's it changes to the indicated speed.
I have a request, could you open the emulator and take an accurate picture inside?
      04-02-2020, 09:11 AM   #466
x-m4n
x-m4n's Avatar
Have you tried contacting the Aliexpress seller? Hopefully they would be able to send you a picture quicker...
      04-02-2020, 08:02 PM   #467
Onizukachan
Great Teacher
Onizukachan's Avatar
1086
Drives: 06 e91 325ix
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
Originally Posted by Onizukachan View Post
I’ll let you know, the one I just ordered is for both F and G and apparently had the option for white square mph sign, which is what I requested.
If it doesn’t work I’ll just put it only on the HUD and not the 6WA cluster.
It arrived about 45 minutes ago and is in and tested.
And it works. In MPH. On the cluster. And is P&P.
First: no relation. Just posting this to help others.
Second: see pics
over Terra (one of 1), Nav, Sport, L7
A few OEM+ mods:
MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come…
x-m4n148.00
Dang3r12512.00
      04-03-2020, 01:18 PM   #468
Onizukachan
Great Teacher
1086
The one in the hud was bothersome at night so I turned it off on settings. Cool little toy/feature though.
A few OEM+ mods:
      04-03-2020, 04:36 PM   #469
Chriske92
Drives: BMW 328i
I will see if that's possible, cause mine is specifically made foe KMH
      04-03-2020, 04:38 PM   #470
Chriske92
Drives: BMW 328i
This is what i can give you for info. I hope it helps mate
      04-05-2020, 12:32 AM   #471
SMiGGs
Drives: Msport
Second: see pics
Can you link me brother I would like to purchase it ASAP. Love the results. Thank you in advance
      04-05-2020, 03:33 AM   #472
x-m4n
x-m4n's Avatar
Second: see pics
eBay seller: bimmer8_tw
      04-06-2020, 09:03 AM   #473
Fudz
Drives: 2015 435I 8speed
Do these work without the HUD ?
      04-06-2020, 05:15 PM   #474
freespirit
freespirit's Avatar
83
Drives: f30 2016 BMW 328i
yes it should. I don't have HUD in my car but still it works on the instrument cluster.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop
      04-10-2020, 09:35 PM   #475
freespirit
freespirit's Avatar
83
Hi Guys,
I am in a peculiar situation looking for clues on how to resolve it.
I bought a chinese SLI emulator that displays speed in kmph. After installation, i did the coding and its working perfectly fine. Its able to show speed limits for 25, 45, 50, 55, 65, & 70mph perfectly fine.
After a couple of weeks I saw another SLI emulator from ebay seller which can display the speed sign in mph. Bought it and installed it. But the problem is that its stuck at 50mph and not able to display other speed limits. I drove on the same 45mph road where the old device is showing fine in kmph but the new won't display any speed. Its just stuck at 50mph.
Any idea what could be the issue ? I have removed the 8TH VO code and tested still nothing . Coded again still no issues.
Any clue will be helpful. Thank you.
      04-14-2020, 04:36 AM   #476
SMiGGs
Drives: Msport
Originally Posted by freespirit View Post
Hi Guys,
Where did you get the first emulator from? Link?
      04-14-2020, 08:59 AM   #477
freespirit
freespirit's Avatar
83
Hi Guys,
https://www.ebay.com/itm/253930803672
      04-14-2020, 11:25 AM   #478
Onizukachan
Great Teacher
1086
Did you try unplugging it and plugging it back in?
Mine still works fine.
A few OEM+ mods:
      04-14-2020, 12:26 PM   #479
freespirit
freespirit's Avatar
83
Ooh yes a lot of times. The seller sent a replacement device as well still the same issue. Allow me to explain the pattern i have noticed.
50mph speed limit road : SLI displays 50mph perfectly fine
70mph : displays speed fine
other than 50 and 70 it won't display any other speed sign.
If its an internal road and speed limit is not avilable, then it will diplay the last speed limit. for example i enter into local road from 70mph road, then it will continue to show 70.
for all other speed limits like 45, 55, 65 etc ... it will just display three dots without any square sign.
Not sure if its coding related or something else.
      04-14-2020, 01:52 PM   #480
Onizukachan
Great Teacher
1086
Strange. Maps up to date?
You said the China one Worked fine, but the Taiwan one is the one with the issue?
A few OEM+ mods:
      04-14-2020, 02:58 PM   #481
freespirit
freespirit's Avatar
83
yes maps up to date 2020 qtr1.
Yes china one working fine ... taiwan one has problem.
      04-14-2020, 09:02 PM   #482
Onizukachan
Great Teacher
1086
Mine still works great... where map data exists.
A few OEM+ mods:
      04-16-2020, 04:54 PM   #483
SMiGGs
Drives: Msport
Thanks for the replies fellas
i got this one, it has MPH as well.
https://www.ebay.com/itm/Speed-Limit...72.m2749.l2649
Ill report back when i get it installed
      04-16-2020, 05:06 PM   #484
freespirit
freespirit's Avatar
83
Yes i got it from the same seller. Unfortunately its not working in my car. Please let me know if it's working for you. thanks.
