07-07-2018, 07:55 PM | #1 |
Rep 1,170
Help please suspension loose unstable
Hello you guys
So check this out I took my car to the BMW dealer to get it serviced for my rear wheel bearings And front top hat for making noise The car was at the dealer or 2 weeks Today I go pick it up finally I start to drive home and the car has no sort of handling at all Literally loose like the car shifts side to side sooo Nasty to the point I almost lost control like if it didn't have sway bars or shocks Just on springs lol Like really bad Mest up thing is that the dealer closed once I took off so I couldn't go back Luckily a friend of mine works there and he is telling me he can't see it intill Monday What do you guys think it can be
bmw m2
07-08-2018, 10:08 PM | #2 |
Rep 1,934
If they did any tophat work they should have also done an alignment, but it sounds like they didn't. Knowing dealers they would have simply replaced the tophat which would require the entire suspension unit to come out. So alignment.
07-09-2018, 02:53 AM | #3 | |
Rep 1,170
Rear passenger side wheel is completely loose I don't think the bearing is on correctly The wheel has way too much play
bmw m2
07-09-2018, 06:04 PM | #5 | |
Rep 1,170
The axle nut was loose so there was a lot of play on the wheel
bmw m2
07-09-2018, 08:36 PM | #6 |
Rep 1,043
Damn.
Reading your post, is like reading a poem. |
cdwalls701.00 deadserial30.00 |
