07-02-2018, 03:31 AM | #1 |
Rep 4,516
F series replacement windscreen c/o Autoglass
Folks,
Got a stone chip close to passenger A pillar - developed into a crack. My insurance is covering new screen c/o autoglass. Need a steer as never had a BMW screen crack before so keen to know about re-install of rear view mirror/FLA/KAFAS camera onto new screen and re-calibration of the system etc ? Anyone had their screen changed via A/glass able to give me any tips ? TIA BP
Current '22 X3M LCI.. |
07-02-2018, 03:42 AM | #2 |
Rep 168
I had one replaced on my old F11. There is a plastic clip that is glued onto the inside of the screen by the fitter. The camera modules fit onto this if I remember correctly.
Mine did not need calibration and I think it's a fairly straightforward fitting. May be slightly different if you have hud though. |
Bee Pee1779.00 |
07-02-2018, 04:00 AM | #3 |
Rep 1,201
I just needed to get the rain sensor reinitialised, just to calibrate for the new windscreen. You can do that with yourself with ISTA
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
Bee Pee1779.00 |
07-02-2018, 04:31 AM | #4 |
Rep 2,126
Had the screen on my old 420d changed. We informed them beforehand as to what the car had, and they sent out a 'specialist' (so not all fitters are trained to do it?) who was used to changing the BMW screens.
He changed the screen, plugged something in then went for a 5 minute drive to make sure everything was working.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
Bee Pee1779.00 |
07-02-2018, 05:34 AM | #5 |
Rep 4,516
Update:-
Got OEM screen part # from my friendly BMW parts dept then spoke to A/glass and they have confirmed their screen is compatible with my car [A/glass rep quoted correct OEM part # w/o being prompted which I took as a positive sign). A/glass also said that new gel pad is supplied for rain/moisture detection so no calibration/ADAS needed given my car's spec ie VLD/HBA only and no driving assistant/lane detection options. Thanks all for the input, car ia A/glass 1st thing Wednesday morning. BP
Soul_Glo13346.00 |
07-02-2018, 07:50 AM | #7 |
Rep 4,516
Naz - OK and thanks for the tip. Cheers, BP
07-02-2018, 10:01 AM | #8 |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
Every non OEM screen I've ever had has been inferior to the original. Waviness is usually much worse. Fitting very variable too. Worst example was RAC who took three attempts to get it right on my E46 - the final one also including a guy from a paint shop to fix the damage the second attempt caused.
07-02-2018, 02:49 PM | #10 |
Barge driver
8656
Rep 12,425
I had a really shit experience with autoglass for me they haven't got a clue what they are doing and a business I'd avoid like the plague.
Hopefully the OP experience will be better, but expect a cheap ill fitting screen not a BMW one.
730d/Z4C
Bee Pee1779.00 |
07-02-2018, 03:10 PM | #11 |
Rep 32,881
But what’s the alternative? Auto Windscreens are absolute muppets, definitely worse than Autoglass, just.
07-02-2018, 05:11 PM | #12 |
Eh? Team member
514
Rep 1,190
Drives: F31 335i
I think the whole windscreen replacement business is crap. I suspect the insurance companies pay absolute bottom dollar and margins are wafer thin accordingly. So, we get cheapest of cheap glass fitted by poorly trained and under-paid staff.
07-02-2018, 05:18 PM | #13 |
Fool
1857
Rep 3,542
The key (and alternative) is to choose your insurer carefully and pick one which allows you to use your own installer and BMW branded glass. There are loads of great independent installers out there and they can all source genuine glass from dealers.
07-03-2018, 03:43 AM | #16 | ||
Rep 1,863
It's a UK problem, we want to pay cheapest bargain prices. Result, we get cheap product. Quote:
Far too many insurers rely on people not reading the documents. Most will say it's a small excess and you have to use their own repairers. UK insurance group for example do this but they also allow you to go outside this but in that case will only pay up to £500. Lose lose situation for the Customer. |
stu14t450.50 |
07-03-2018, 04:01 AM | #17 |
Jeff
318
Rep 1,451
I would say from having a few fitted over the years that, as long as the fitter does a careful job you generally should be fine. I have had windscreens replaced that obviously had been replaced themselves and the trim had not been removed/replaced properly. If it was me, I would just make sure that everything looks OK and if you have time, actually watch the guy doing the job - very interesting.
Bee Pee1779.00 |
07-03-2018, 05:07 AM | #19 |
Rep 2,598
I had mine done by National Windscreens.
Morons. Branch manager was a complete clot who was plain rude and seemed personally offended that I wanted to make sure my car wouldn’t be damaged during the process and that I wanted BMW glass! After a back and forth between myself & my policy underwriter it was agreed the genuine BMW glass would be authorised. Had the work done by NW. They caused micro scratches & swirls in my paint as the cretins used rubber ‘blades’ to dry a dirty car to carry out their ‘pre-work inspection’ to identify any pre existing damage (ironic) They also couldn’t align the wipers, they were left pointing down into the engine bay after multiple attempts to put it right. Rear view mirror cowling was also loose. They lied when challenged and then were forced to pay for a full detail by my policy underwriter after I caused a shit storm. Why can’t people just do their jobs properly?! |
Bee Pee1779.00 |
07-03-2018, 05:18 AM | #20 | |
Fool
1857
Rep 3,542
07-03-2018, 05:30 AM | #21 | |
Deadly
1315
Rep 2,070
07-03-2018, 05:49 AM | #22 |
Rep 922
If AutoGlass etc are crap, is there not an option to get BMW to do it? Or does it not work like that?
Coding. LED Front Fogs. DIY Driver Glovebox. KW Street Comfort. 15mm Rear ARB. Tarox SS Brake Lines. Motorwerks Remap. DIY Rear 12v Socket. M Performance Discs. Tarox Strada Pads. Spacers (10mm & 12mm). Head Unit USB Cable. Rear Diffuser. Rear Light Tints. Non RFTs.
