BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > adaptive suspension retrofit
      05-29-2017, 05:10 PM   #23
mikeb129
Drives: BMW F32 430xd
Originally Posted by mhhforyou View Post
BMW wouldnt and cant code this retrofit.
You have to do it on your own or go to a local bmw coder. He has to put SA 2VF in your FA and code the complete car. Nothing hard for a coding specialist.
Thank you very much for answear.
Sorry for lot of questions: Can you feel the difference in comfort mode, on uneaven roads, potholes ? ride is more comfortable ? and also less body roll on turns ? after instalation, compared with OE passive suspension
      05-31-2017, 12:14 PM   #24
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
2014 BMW 420da  [0.00]
Before i fitted the adaptive suspension i had standard suspension with schnitzer springs.
Now with adaptive Suspension and schnitzer springs its in comfort mode a little more comfortable than before. But really only a little bit. Also the way the suspension react on potholes is different. Its a little bit softer at fast compressions. At Sport or Sport+ its sporty but not to much. Hard to explain.
      03-12-2018, 01:36 AM   #25
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
This is the harness you need to retrofit VDC.
      03-19-2018, 10:58 PM   #26
DaFish
DaFish's Avatar
Drives: 2014 435iX, FBO
At least if you can't get the harness to work, you could make some nice mittens...
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S
      04-05-2018, 11:41 PM   #27
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
Also possible yes... ;-)
      07-10-2018, 04:23 PM   #28
Tomcat230
Spain
Drives: F30 320D Alpinweis
Hola a todos
BMW no puede codificar esta modificación. Porque es una definicion de producto propia
Un amortiguador es hardware controlado por un software que es propio de BMW que supuestamente esta estudiado para que el 90% de los compradores se sientan conformescon su diseño
      08-26-2018, 02:25 PM   #29
blueboy_gigel
blueboy_gigel's Avatar
Drives: BMW F30
Hello
That harness should have a reference
Wich are the ecu reference
My f30 haves 153k km right now. When it gets to 200k I wanna change the suspension even that right now are perfect. It's a M sport Suspension.
I wanna install a F80 suspension but I'm not sure it will fit. Any ideas?
      08-27-2018, 03:58 AM   #30
Lancelot
France
568
Drives: 2017 m550i
Hello
I don't think it will work, from the top of my head:
- electronically, f80 use a different ecu for EDC, which probably wouldn't cooperate easily with the other ecus onboard, not 100% sure but that could be tricky. The dampers also connect via the top strut hat, not in the wheel hub.
- physically, the dampers are not the same size and would require a different wheel hub, and therefore brakes and discs.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
      09-10-2018, 02:21 AM   #31
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
EDC Ecu ist the same as in the F3x but with other software. The Software is made for the F8x M Drive Buttons that the F3x dont have. You also need this. But i dont know if the FEM with F3x coding accept the M Drive Buttons.
Damper are physically different.
The EDC Software is made for the F8x not the F3x. The F8x is wider, with other gravity center and complete other suspension (track and camber etc) Dont think this would drive very nice...
      04-08-2019, 06:52 AM   #32
Drimacus
Drives: 2013 F31 320d Luxury
Is there available a part number to order it in bmw?
      04-08-2019, 09:14 AM   #33
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
You cant order this at bmw. The suspension wires are part of the main car harness. This is a harness i did for someone.
      05-18-2019, 02:30 AM   #34
Drimacus
Ad i saw,
To retrofit a full working 2VF you also neeed to change ICM and ACSM.
      05-18-2019, 02:31 AM   #35
Drimacus
how much to create an harness for me?
      06-17-2019, 04:48 PM   #36
Drimacus
I did it!
      06-17-2019, 07:56 PM   #37
cfm56d7b
I did it!
Congratulations!
What did this project eventually cost?
      07-07-2019, 10:35 AM   #38
Drimacus
Thank you!
1000 euros Damper
200 euros VDC Ecu
200 Euro Front and Rear Stabilizer Bars
150 euros harness construction
40 Euros Swing Supports
40 Euros Underride protection
Three Days of work
cfm56d7b5886.00
      07-07-2019, 10:39 AM   #39
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
What wasnt cheap….
      07-07-2019, 07:41 PM   #40
cfm56d7b
Thank you!
1000 euros Damper
200 euros VDC Ecu
Three Days of work
This project isn't for those with high blood pressure. Congrats again!
      07-31-2019, 08:20 AM   #41
alex_beridze
Drives: BMW 335 2008 Year
Thank you!
1000 euros Damper
200 euros VDC Ecu
Three Days of work
good job
do you have part numbers? only need to add VDC ECU and don't need any sensors and other bloks?
BR Alex
      07-10-2020, 09:41 AM   #42
tominfhl
Drives: BMW X5 F15 35d
If I have a car with DHP and 2VP (adaptive comfort suspension) do I need any hardware changes to get 2VF or can I code from 2VP to 2VF?
      07-11-2020, 11:38 AM   #43
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Thank you!
1000 euros Damper
200 euros VDC Ecu
Three Days of work
3 days if work @250 /hr. ... for people who want to pay for this... but by all means a good project to diy when u have time and patience
I think I'm going to install Tein Flex Z with EDFC. Still not decided tho
      09-01-2022, 04:10 PM   #44
Napas
Drives: f11 520d m
On my F11 LCI i have S223A ADAPTIVES FAHRWERK Electronic Damper Control (EDC)
When playing with the configuration of Sport and Sport+, it allows me to put the dumpers Suspension in sports mode also.
I would love to know the diference between the two.
223 vs 2VF
