02-15-2019, 01:13 PM | #24 |
Rep 387
This is the unfortunate downside to DI engines. I've bought some of that CRC GDI cleaner. CRC generally makes good stuff, but I'm skeptical if this will work. I'm hopeful as it may spare us the expense of a walnut blast. I just need to get around to doing it. I have a borescope, but it's really difficult to maneuver it through the intake manifold to get it to go to the valves you want to inspect for before and after pics.
02-15-2019, 02:10 PM | #26 | |
Rep 5,457
Drives: F30
CRC does make good products however Ive always been skeptical of these types of cleaners specifically. Never used one so have no experience... Would love to hear/see some real work results before trying myself. |
02-15-2019, 02:58 PM | #27 |
Rep 16,054
02-16-2019, 02:07 AM | #28 |
Rep 5,083
02-16-2019, 09:41 AM | #30 |
Rep 387
02-16-2019, 10:34 AM | #31 |
Rep 16,054
One video that I saw was done at something like 82,000 miles. That's a lot of baked on crud to get off without walnut blasting. I imagine if you do it yearly starting at less than 20,000 miles you'd never get a build up so bad that it needed blasting.
02-16-2019, 11:31 AM | #32 |
Rep 5,083
02-16-2019, 12:16 PM | #33 |
Rep 387
It does indeed. I think we just tend to forget it’s there because of the drive by wire technology. This is the first car I have owned that’s drive by wire. Maybe I’m just too old school, but I miss the old cable and linkage set-up. And bring back my dipstick dammit!
bavarianride1505.00 Pittcrew34.00 |
02-16-2019, 12:30 PM | #34 | |
Rep 5,083
Also, can this type of GDI valve cleaner be safely used, say, weekly, to dislodge carbon buildup for last 50k miles? |
02-16-2019, 12:31 PM | #35 |
Rep 16,054
bavarianride1505.00 |
02-16-2019, 12:37 PM | #36 |
Rep 5,083
Have to say that opening is quite a distance from the intake valves. My thinking is that the most effective way to apply this type of GDI intake valve cleaner is to remove intake manifold, and that's 2/3 the labor towards walnut blasting.
02-16-2019, 01:00 PM | #37 |
Rep 5,083
FYI, one amazon comment says shops use this GDI valve cleaner to pre-soak intake valves before walnut blasting(after intake manifold was removed), that makes perfect sense.
Another user commented that he didn't have rpm high enough while using GDI valve cleaner, and apparently the cleaner pooled in misc. areas and led to misfires and limp mode. The fault codes eventually disappeared, but it does not look the right way to clean intake valves. Also, the F30 N20/N26 MAF sensor is behind the air box, with a straight pipe(down pipe?) running to the engine. If the engine is not running, will the cleaner just pool at the turn of that straight pipe? Also does removing MAF sensor while engine is running leads to fault code too? |
02-16-2019, 03:17 PM | #38 |
Rep 16,054
It's a lot closer than the air box intake up at the grille, and yet air still somehow manages to make its way to the manifold. Yes, the cleaner pools. It's supposed to do that. Yes, the engine will misfire for a while until the cleaner is all cleared out. It's supposed to do that. No, removing the MAF sensor will not throw a code. You might get some misfire codes, which you should clear with your OBD tool after the engine is running normally again.
02-16-2019, 04:19 PM | #39 |
Rep 5,457
Drives: F30
Im going to be honest... I aint sprayin' that shit into my engine.
I do hope to have a proper walnut blast one day, maybe around 100k miles. About to crack 70k. Really wonder what my valves look like at this point. Sure there is some buildup but how much? I haven't seen any photos of N2X valves while everything was apart... Ive also been running a catch can since 29k miles so Id imagine that has helped at least somewhat. |
02-16-2019, 08:56 PM | #40 | |
Rep 5,083
02-16-2019, 08:58 PM | #41 | |
Rep 5,083
02-16-2019, 09:04 PM | #42 | ||
Rep 5,457
Drives: F30
Im a victim of over maintenance and care (like a lot of us) but I still like to be cautious and do research. I honestly dont think trying this stuff once will cause any noticeable harm but Im going to pass. Anyone heard of dealer specials or just generally know the cost of walnut blasting? May consider at 100k as kind of a halfway point thing. Hell or high water... I will be driving this vehicle for 200k + miles |
02-18-2019, 08:04 PM | #43 |
Rep 5,083
Another thought is, does no hard driving before warming up reduces carbon buildup?
Also can ECU do something(e.g. limit PCV blowback?) to alleviate carbon buildup? |
02-18-2019, 08:57 PM | #44 | |
Rep 5,457
Drives: F30
I have no idea if this is just an old wives tale? Truth be told... I do baby my car around like its a 1987 Cadillac Brougham de Ville most of the time. I do try to redline or near redline once every few days or once a week though. No idea how this relates to others driving habits but thought Id share : |
