04-28-2020, 09:32 PM | #1 |
Rep 9
Intermittent N20 low oil pressure warning
Hey guys, I got a 2013 328i with about 58k miles and once about every 4-6 months I get a spontaneous low oil pressure warning on the iDrive screen.
I pull over, restart the car, and light goes away. No ticks, no knocking, nothing. Runs just fine. Oil level is good too and I change it every 5k miles. Today is the third time this has happened. One thing I did notice though is that this ONLY happens when I am cruising on the highway at a higher rate of speed (85-95 mph) while in sport mode in 6th gear (6MT). It has never happened in any other circumstances. I'm suspecting it might just be a minor electrical fluke because my engine would've been toast a long time ago if the oil pressure was in fact low. I did however notice the other day that there is a significant amount of air rushing out of the oil cap when I open it while the engine is idling. i'm not suspecting it to be piston blow by because the car doesn't consume a drop of oil and feels healthy. Perhaps a PCV issue? Although I'm not sure if that can be related to my intermittent low oil pressure light? |
04-28-2020, 09:37 PM | #2 |
Rep 5,463
Drives: F30
You're removing the oil fill cap with the engine running?
04-28-2020, 10:01 PM | #3 |
Rep 9
Yeah, only for a moment while it was idling. Was poking around the engine bay and wanted to see if there was any blow-by (unrelated issue prompted me to look, which turned out to not have been an issue after all).
04-29-2020, 11:07 AM | #6 |
Rep 3,748
04-29-2020, 12:36 PM | #7 |
Rep 9
It did but very little. Considering that and the amount of air blowing out leads me to believe I have a PCV issue however I'm not sure if that correlates to this random low oil pressure light I get.
05-06-2023, 08:48 PM | #8 |
Rep 51
Were you able to resolve this?
Jeovany8181.50 |
