12-13-2020, 05:41 PM | #1 |
Rep 584
AFE Air Scoop AFE 54-12218
I'm going to fit an AFE Air scoop AFE 54-12218 to my car. And I'm looking for one at a decent price from a UK seller. The price for these vary a lot. Amazon have it for £50. Any other sellers that could be recommended and that have the item in stock?
Cheers
[/B]2017 330e M Performance, MG Flasher Stage 2, RM Motors DP, xHP Stage 3, Armaspeed CIA
12-14-2020, 01:49 AM | #2 |
Rep 413
I ended up buying direct from afe with a 20% discount offer.
B58 Dry Drop In Filter & Scoop - £130 delivered.
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
12-14-2020, 04:34 AM | #3 |
Rep 2,126
I got mine from ML Performance.
Be sure you buy the correct one for the correct side. Also, mine didnt fit as easy as it was supposed to, I had to basically glue it.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
12-14-2020, 04:38 AM | #4 | |
Rep 584
I think I might go with Amazon at £50 Inc fee deliver and duty paid |
12-14-2020, 05:30 AM | #5 |
Rep 2,047
Does it make sense for open air intakes like the AP? Thought they were already getting plenty of air from the grille
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage Last edited by winther1; 12-14-2020 at 05:36 AM.. |
12-14-2020, 05:50 AM | #7 |
Rep 413
I also fitted this hot climate kit so it is a continuous duct from the aFe scoop through to the air box.
https://williamsperformance.co.uk/pr...ate-intake-mod
Mick.86uk79.50 |
12-14-2020, 05:52 AM | #8 |
Rep 584
These part numbers
(intake duct 13717646767) and (grill 13718507321) added before fitting the scoop
12-14-2020, 05:54 AM | #9 | |
Rep 584
I might try making a scoop myself. I have access to material to make one. Although it could be a bit fiddly with the location
12-15-2020, 03:21 AM | #10 |
Rep 2,126
It will get plenty if you have taken the blank plate off.
12-17-2020, 02:09 PM | #11 |
Rep 584
Fitted the intake pipe and grill today. Awkward little job. Top tip: to ease installation. Out the duct until billing water for 30 seconds or so. This will make it more pliable, and easier to install
Quick question regarding installation. The flange rubber section that is at the pass through hole. Does it sit on the radiator side or behind plastic, or closer to the headlight? Last edited by jcdub; 12-17-2020 at 02:17 PM.. |
12-17-2020, 02:35 PM | #12 |
Rep 413
It should look like this once installed.
Took a fair amount of skin off my knuckles and fingers getting it into position.
Mick.86uk79.50 |
12-17-2020, 03:02 PM | #13 |
Rep 584
12-17-2020, 03:51 PM | #14 |
Rep 107
I’ve gone slightly different , cold air feed behind the grill and then ducting up to the inlet above
The inlet can just be seen here |
12-21-2020, 07:27 AM | #15 |
Rep 2,126
Mines a right bodge 😅
Only photo I've got, but I made my own mesh out of the original blanking plate.
12-26-2020, 02:42 PM | #16 |
Rep 584
Had a little time to kill today. So decided to make my own air scoop. Formed using aluminium sheeting and wrapped using some carbon film.
I'm pretty happy with the result.
12-28-2020, 03:20 AM | #18 |
Rep 584
I used the same aluminium sheeting to make two small brackets. I then used rivets to attach the brackets to the scoops top and bottom leading edge. I then used a self tapper to secure the top bracket. And a plastic rivet clip, similar to the clip supplied a with the afe air scoop. This secured the lower leading edge using the hole that was there. Again the same mounting point as the afe scoop.
I'm happy with the way out turned out a. And it seems to be well secure. I was going to paint it. But I thought the wrap would stand up a lot better to stone chips . |
12-28-2020, 01:16 PM | #20 |
Rep 584
That's a neat install. I couldn't get away with a low air intake. With heavy rain where I live, there's a chance of hitting big puddles.
With the length of reinforced pipe. The wire rib would most likely disturb the air flowing to the air box. Would be best to have the air being channeled into the air box with a route as short as possible. |
01-12-2021, 09:40 AM | #21 |
Rep 6
