01-05-2021, 09:12 AM | #23 |
Rep 882
learntocode53.50 |
01-05-2021, 01:10 PM | #24 |
Rep 1,288
Really... that's it...
I looked at the manufacture date of my car and it was made Dec 2014... so technically the original battery is 6 years old... supposed to be nice out tomorrow so I'll venture out to get a new battery... I drive it a minimum once every 2 weeks during the winter... depends on the weather... it came with summer tires so I don't like to go out when it's under 40degrees... roads have to be nice and dry too... |
01-05-2021, 01:16 PM | #25 |
Rep 1,288
Just keep in mind... when unlocking the DME you will need more than a trickle charger... hence why I bought the 15amp... this was before the MHD dongle though...
erickonphoenix1728.00 |
01-05-2021, 03:17 PM | #27 | |
Rep 1,288
01-05-2021, 05:50 PM | #28 | |
Rep 10,352
"Drive more, worry less. "
03-09-2021, 01:56 PM | #29 |
Rep 1,288
Haven't driven my car in almost 3 months... it was 66degrees today and dry streets... it started right up! .... but you could tell the battery was low... message came up after driving it for an hour to charge battery... going to go get the new battery next week or so... but still surprised it started right up considering I knew the battery wasn't in the best shape when I last drove it...
Pussiwillow521.00 F32Fleet3571.50 |
03-13-2021, 07:02 AM | #30 |
Rep 878
My car was throwing up the same message, took it for a 30 mile drive and the warning was still there. Ended up buying a battery charger from Aldi, a 5a charger suitable for AGM, hooked it up and it showed that the battery voltage was at 11.9v, left it charging overnight and it reported the battery being at 12.4v and the car no longer complains.
My car is a 2015, so the battery is at least 6 years old, reason for the post was to state that the battery might not need to be replaced. |
03-13-2021, 09:47 AM | #31 | |
Rep 1,288
03-16-2021, 12:16 PM | #32 |
Rep 169
Since you're coming up on potentially needing a battery replacement, I would say take the time and stop buy an autoparts store that offers free alternator and battery testing to run a test on the electrical system under load. I recently just had power issues which turned out to be an alternator on its way out that overcharged other electrical components in the car. It was intermittent but it gave the same increased battery during discharge and after going through 3 batteries I had the alternator checked instead of listening to shops blame a faulty battery or other things I had plugged in. I'm not saying you will have the same issue but just recommending an extra step that could lead you to saving any extra time/money. Good luck!
IG:@_das_bae_
2015 435i Sparkling Brown Metallic (B53) OEM+ https://f30.bimmerpost.com/forums/sh....php?t=1705873 |
FastF30521.00 |
03-24-2021, 01:47 AM | #33 |
Rep 1,288
Took the car for a drive and low battery drive car message came up again after an hour of driving... So I figured I have this nice Schumacher 15amp rapid battery charger... might as well give it a go... so I ripped out the battery and left the car unlocked (in the city, no access to charge in car)... charger said 51% 11.9v .... 1-1/2 hours rapid charged to 100%... waited 5 minutes and checked... 66% 12.3v... 50 minute rapid charged... 5 minute wait... 72% 12.4v... 40 minute rapid charged... 5 minute wait... 73% 12.5v... another 15 minutes charging and threw the battery back in (didn't want to leave it out too long , heard bad vodoo stuff could happen with electrical)... glad I put Blue painters tape on the posts... much less to worry about... pain getting it back in... very tight area...bottom hold down bracket was major pain... but all in all went smoothly after climbing thru the arm-rest to open the trunk... lol... gonna take it for a drive tomorrow and check for codes etc...should work if I drive the car more for the summer anyways... read somewhere the alternator kicks-out 170-210amps depending on model ... that's crazy amps ... so we'll see...
03-24-2021, 02:02 AM | #34 | |
Rep 7,606
_das_bae_374.50 |
03-24-2021, 02:09 AM | #35 | |
Rep 1,288
03-24-2021, 11:06 AM | #36 | ||
Rep 169
Alternatively if you do not have access to a load tester... If you have a digital voltmeter do a reading at the battery in the trunk at the terminals, then the engine bay posts, then from the alternator. If all are reading the same voltage rating that is one good sign, next step is swap the leads from your multimeter to contact the black contact on the terminal on the side of the alternator and the red contact on the casing of the alternator both when the car is on or off.
IG:@_das_bae_
03-24-2021, 02:50 PM | #37 | |
Rep 1,288
03-24-2021, 07:11 PM | #39 | |
Rep 169
IG:@_das_bae_
