BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > CIC/NBT FSC Generator - Windows/Linux/OSX
      01-16-2019, 07:14 AM   #111
kungfupanda92
Drives: f30 luxury
hallo friends
I have a F30 with CIC and a professional navigator with road map Europa premium maps 2012
I would like to put maps that I have downloaded road map west europe 2019-1 but I can not find fsc code
could you help me?
my VIN is : F241921
thank you all
      01-16-2019, 09:50 AM   #112
IH8I405
IH8I405's Avatar
Drives: 2015 BMW 428i
2015 BMW 428i  [0.00]
What does the 'SELECT DATE' mean in the program? Do I use the default selected after I enter in the VIN and values? Or do I need to change the SELECT DATE.
VIN: K223992
Map Type: Premium
Region: North America
Maps: Road Map North America Premium (USB) 2019 *Lifetime*
Code:
      01-17-2019, 04:53 AM   #113
reischi82
Drives: F31 LCI 320xD
VIN: K223992
Map Type: Premium
Code:
the software can be used by
- file meaning that you do have to export the file from your car using for example E-SYS and cable connection
- date meaning that you do have to select a date close to the manufacturing date of your VIN to try getting a working code
      01-18-2019, 04:51 PM   #114
Kacost
Drives: Bmw f31 320d
Hi,does anyone have extracted file from car:f30 nbt around Prod.date: 2013-09-14
i would appreciate to send me pm so i can use it in fsc generator,thanks.
      01-19-2019, 07:41 PM   #115
M1LLSY83
Drives: 320d M Sport
Hi, I have MOVE 2012 maps on CHAMP HU/CIC, production date is 2012/9/13 can I use this to generate and FSC code for 2018 maps?? Many thanks
      01-21-2019, 05:43 PM   #116
Lafleur
Lafleur's Avatar
Drives: 320d E91N 04/2011
VIN: K223992
Map Type: Premium
Code:
From Your VIN:
428i N26 F32 coupe USA 02/2015
These 3 are around February 2015
2015/01/20 HJHVL5KW754AAABNAD7Q
2015/03/06 HW6DGKBIQ2S6WABNAD7Q
2015/03/09 Q75XTZZ6OHNFIABNAD7Q
      01-22-2019, 09:16 PM   #117
IH8I405
IH8I405's Avatar
Originally Posted by Lafleur View Post
From Your VIN:
I tried all three and it did not work for my 2019 North America NEXT map. I'll try again with the generator. Worst case scenario, I'll have to find the cable. Thank you for trying kind sir!
EDIT: Okay, I see what you did. You opted for my PREMIUM because I thought that's what I had. Now I have NEXT, will use the dates you provided. w00t. Hope this works!!
      01-25-2019, 10:43 PM   #118
lastgearlife
Drives: Nesto E46
Can I get a copy for my 335 i xDrive please
Originally Posted by Jagaer View Post
This is (hopefully) a more user-friendly CIC/NBT FSC Key Generator for Windows, Linux and OSX based off of the work of the original FSC Key Generator and Intel123's certificate Patcher.
Input Files
  • The Key Generator will auto-detect and accept either Base64 (Text) or binary FSC file inputs, as well as the file type (1B or NBT). (You can over-ride the detection setting, using the "CIC/NBT" radio buttons).
Support Files
  • The Key Generator will download and use the most recent copy of the BMW "Lookup.xml" file for key generation parameters. In Linux and Windows, this file is stored in the same directory as the Key Generator. For OSX, it is stored in ~/Downloads/
  • The RSAKeys.txt file keeps a copy all submitted RSA keys. The Generator will download and use the most recent copy of the file. In Linux and Windows, this file is stored in the same directory as the Key Generator. For OSX, it is stored in ~/Downloads/
Unsupported Feature
  • It appears that the key stored in the "FSC" file pulled from the car is not necessarily unique to the car, but may be shared across multiple cars built within a short time window.
As an example:
Code:
FSC Date	VIN Build Date			Days Difference
200910211749	Thursday, October 22, 2009	-1
201001271515	Thursday, January 28, 2010	-1
201004011026	Monday, April 04, 2011		-3
201006071536	Tuesday, June 08, 2010		-1
201107121301	Wednesday, July 13, 2011	-1
201110310756	Wednesday, November 02, 2011	-3
201201111004	Thursday, January 12, 2012	-1
201203301822	Monday, April 02, 2012		-4
201204181719	Wednesday, April 18, 2012	0
201205242316	Friday, May 25, 2012		-1
201210010521	Tuesday, October 02, 2012	-1
201210010703	Tuesday, October 02, 2012	-1
201210241654	Thursday, October 25, 2012	-1
201211081709	Friday, November 09, 2012	-1
201305140635	Wednesday, May 15, 2013		-1
201308142104	Friday, August 16, 2013		-2
201403071931	Monday, March 10, 2014		-3
201404091427	Thursday, April 10, 2014	-1
201404300545	Friday, May 02, 2014		-3
201406241001	Tuesday, June 24, 2014		0
201406241307	Tuesday, June 24, 2014		0
201409161938	Wednesday, September 17, 2014	-1
If you would like to help out, and have pulled your FSC file, please send me a copy. I will not include or publish any car-specific information, but will add the FSC file date and RSA key to the RSAKeys.txt file. Hopefully if enough are gathered, some people will be able to create an FSC for their car, without having to pull any files.
Links expire 27 January 18
  • Windows: https://ufile.io/wos5y
    Windows users must extract the file to a writeable directory (Desktop, Downloads, etc...), not run it from the zipped file. The generator needs to download support files (Lookup.xml and RSAKeys.txt) in order for it to run correctly.
  • Linux: https://ufile.io/n3f70
    Linux users must extract the file to a writeable directory (~/) and will need both QT5 and OpenSSL installed.
  • Linux Console: https://ufile.io/ein94
    Linux users must extract the file to a writeable directory (~/) and will need both QT5 and OpenSSL installed. Network not required.
    Code:
    Usage:  ./BMW_CIC_FSC_Generator_Console FILE.fsc TYPE [TYPE] YEAR [YEAR]
                    Example ./BMW_CIC_FSC_Generator_Console FILE.fsc 0x28 0x0A
            FILE.fsc - 319 byte hex OR BASE64 encoded version of hex
            TYPE     - 1 or 2 bytes representing the map type
                       If TYPE is two bytes, YEAR must be two bytes
            YEAR     - 1 or 2 bytes representing the map year
                       If YEAR is two bytes, TYPE must be two bytes
Code:
Version History
v1.9 - Add support for F0 Files.  NBT EVO Headunits which use NEXT style maps.
v1.02 - Allow Numerical First Digit for VIN.  Bug Identification & Explanation provided by txomin in post 71
v1.01 - Unhide "Lifetime" Checkbox
v1.0  - Initial Release
      01-26-2019, 07:32 AM   #119
Tonno
Drives: BMW320
Cant pull 1b file
The seller told me there was a lifetime fsc code installed in my BMW. I tried this by updating to NBT-NEXT 2018-1, and it indeed started instaalation without asking for FSC. However, after installation was complete, the system asked for FSC, which I don't have.... And previous version is overwritten now. I can't pull the 1b file through the middle-console, no USB IN THE GLOVEBOX.... anybody any ideas please ?
      01-28-2019, 03:35 AM   #120
reischi82
have you already tried to create a key using the "by date" method where you need your VIN and the production date to enter into the software?
the other way would be to go to someone having E-SYS and E-NET cable to read the file one time from your NBT so you can use this for creating the key in the future.
      01-30-2019, 12:09 PM   #121
Tonno
Drives: BMW320
Thanks Reischi82. By date didn't work unfortunately. I could get a Enet cable from Alibaba, is the Esys software to be downloaded somewhere?
      01-30-2019, 09:14 PM   #122
IH8I405
IH8I405's Avatar
$4 on AliExpress. I can wait for shipping. Software will be provided when link is sent out.
      01-31-2019, 07:30 AM   #123
reischi82
Originally Posted by Reimns View Post
Can anyone help me whit FCS for K400888, I have EVO 2016-1
have you seen my post above yours?
      01-31-2019, 07:38 AM   #124
reischi82
you will have to search for it (like a lot of others did) - for example in this forum - and you will also need e-sys launcher and psdzdata for beeing able to run the software.
for example:
http://blog.obdii365.com/2017/05/23/...-bmw-fsc-code/
http://blog.obdii365.com/2017/04/11/...-1-map-update/
http://blog.uobdii.com/bmw-navigatio...es-generation/
      02-03-2019, 03:15 PM   #125
Tonno
Drives: BMW320
for example:
How can you know the VIN build date the closest?
      02-04-2019, 07:35 AM   #126
reischi82
you can use a VIN decoder page like the one listed below
https://bimmercat.com/bmw/DE/vin/decoder/online
      02-08-2019, 08:55 AM   #127
mDrive1
Drives: X1
Is it going to work for NA ROUTE map? That's what I have in my X1. Thanks,
      02-08-2019, 08:57 AM   #128
shawnsheridan
shawnsheridan's Avatar
No. Not possible for ROUTE nor EVO maps.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      02-08-2019, 10:17 AM   #129
EricTiger
Erictiger
Taiwan
Drives: BMW F10
I have a F10 with NBT and a professional navigator with road map Taiwan Next maps 2018-2
I would like to put maps that I have downloaded road map Next Taiwan 2019-1 but I can not find Map from list of - "ROAD MAP Taiwan NEXT 2019-1"
could you help me?
thank you all
      02-08-2019, 03:41 PM   #130
starwilling
Drives: BMW X1
Is this app working for Route maps? Has anyone tried?
      02-08-2019, 04:12 PM   #131
shawnsheridan
      02-10-2019, 10:44 AM   #132
SmartyB
Netherlands
Drives: 518Da
And here is mine; NBT unit
Vin D065799 Prod Date 2014-05-06
Road Map EUROPE Next 2019-1
Code used; AXQEXN6W6T3RMAFJAA4A
Good luck
