BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Missing CAFD files when coding
      03-31-2019, 07:46 PM   #1
saterade
Drives: Man
I was trying to code my new retrofit rear-view camera today and when doing so something when terribly wrong. the CAFD file under HU_NBT2 decided to go missing. I have a backup SVT file I made before i started coding and have tried to code the backup to replace it with no luck. I get "No Signal" on the screen but the AM/FM work. I get a notExecutable error when i try to code. Below is the log file if anyone could help me decypher it. I would be extremely grateful.
Caf's suchen
Tal wird generiert
Abarbeitung wird gestartet
Read SVT before TAL execution started.
Read SVT before TAL execution finished.
ExecutionID=2018/07/31-18:33:45.888
[] prepareTALExecution started
[] prepareTALExecution finished
[] prepareVehicleForCoding started
[] prepareVehicleForCoding finished
[HU_NBT2 - 63] prepareECUforCoding started
[HU_NBT2 - 63] prepareECUforCoding finished
[HU_NBT2 - 63] authenticateECUforCoding started
[HU_NBT2 - 63] authenticateECUforCoding finished
[HU_NBT2 - 63 - cafd_00001ef6-006_030_168] Transaction type: cdDeploy; Message: TA started
MCDDiagService<id=62649, job=com.bmw.psdz.jobs.uds.MCD3_PerformECUCoding, service=WDBI_PLAIN - WriteDataByIdentifier with unlimited Data-ID (plain hex value), description=error: negative response : requestOutOfRange, link=HU_NBT2_63_ETHERNET>
[HU_NBT2 - 63 - cafd_00001ef6-006_030_168] Transaction type: cdDeploy; Message: TA finished
[HU_NBT2 - 63] -MessageID is used multiple times, so MessageText may be ambiguous-job failed with negative response error:
code: repeat job
description: Service WDBI_PLAIN returned a negative response with response code requestOutOfRange; LinkName: HU_NBT2_63_ETHERNET
severity: ERROR
[HU_NBT2 - 63] - [Exception - HU_NBT2 - 63] job failed with negative response error:
code: repeat job
severity: ERROR
MCDDiagService<id=230634, job=com.bmw.psdz.jobs.uds.MCD3_PrepareECUforCoding , service=DSC - DiagnosticSessionControl, description=error: negative response : conditionsNotCorrect, link=HU_NBT2_63_ETHERNET>
MCDDiagService<id=16727, job=com.bmw.psdz.jobs.uds.MCD3_AuthenticateECUforC oding, service=SA_SK - SecurityAccessSendKey, description=error: negative response : serviceNotSupportedInActiveSession, link=HU_NBT2_63_ETHERNET>
[HU_NBT2 - 63] There was an error during TAL execution, please check the log files.
code: service returned global negative response
description: Service SA_SK returned a negative response with response code serviceNotSupportedInActiveSession; LinkName: HU_NBT2_63_ETHERNET
severity: ERROR
[HU_NBT2 - 63] finalizeECUCoding started
[HU_NBT2 - 63] finalizeECUCoding error
code: exception in job
description: MCD3_FinalizeECUCoding threw java.lang.NoSuchFieldError: WRITE_NCD_ERROR; LinkName: HU_NBT2_63_ETHERNET
severity: FATAL ERROR
[] There was an error, please check the log files.
[] - [Exception - HU_NBT2 - 63] job failed with negative response error:
severity: ERROR
[] finalizeVehicleCoding started
[] finalizeVehicleCoding finished
[] finalizeTALExecution started
[] finalizeTALExecution finished
TAL-Execution finished with status: "FinishedWithError". [C207]
TAL execution finished. Duration: "7s". [C206]
Read SVT after TAL execution started.
Read SVT after TAL execution finished.
Abarbeitung beendet
      04-01-2019, 01:37 AM   #2
sicess
Drives: BMW 3 LCI 318i
PM sent
|Plug&Play USB FSC sets for NBT and NBT EVO ID4,5,6 - cheapest price on Bimmerpost forum - 40 POUNDS per pack|
18/11 remote FSC pack + CARPLAY FULLSCREEN - 50 POUNDS ONLY
Lifetime MAP update codes NBT NEXT, CIC PREMIUM 10 pounds each
Whatsapp for quick communication: +886908958631
      10-23-2020, 02:24 AM   #3
LTKARE
Drives: BMW 320d
I have the same issue, would you be of any help?
Thanks a lot!!!!
      10-23-2020, 02:43 AM   #4
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
Click on the HU folder in the SVT tree, press the Detect CAFD from SWE button and select the correct CAFD then press code.
