05-06-2015, 11:11 PM | #309 |
Rep 8
Drives: 2014 i3
Thanks, I downloaded the correct file, modified the lookup.xml file and was able to generate a working code. I now have 2015-2 loaded and working.
I added the following to the lookup.xml file </SgbmId> <SgbmId id="NAVD_000014B8_255_001_054" SWID_FscShort="00A80006" name="Road Map NORTH AMERICA Next 2015-1" supplier="TAS" sop="01.03.2014" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> <SgbmId id="NAVD_000014B8_255_001_055" SWID_FscShort="00A80007" name="Road Map NORTH AMERICA Next 2015-2" supplier="TAS" sop="03.03.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> Thanks for all your help. |
FlorinQCK-2.50 |
05-16-2015, 03:12 PM | #310 |
Rep 1
Hi,
I've tried to update my 2011 CIC navi, but after 3 wrong FSC code, now I cannot try any more. I put the USB into the glovebox, start update, and then I cannot get FSC code promt. It goes back to the menu and that's all. Is it locked forever or? I think my FSC generator was wrong. Do you know what option does it need? Ive tried Dr Ho's generator with this options: fsc.bat a.hex 0x47 0x08 Navi: CIC motion Map: 2014-1 Road Europe Motion Thanks, BR, Gabor |
FlorinQCK-2.50 |
05-26-2015, 11:08 AM | #312 |
Rep 8
Hi,
I have read carefully and tried to apply all my advice to retrofit cic in my E61, but without results: The VIN read in the CAS is different from that of the CIC. How should I proceed? Can not change VIN CIC! (yet well TOOLS32 the VIN of my vehicle!) Thank you in advance for your help |
FlorinQCK-2.50 |
05-26-2015, 11:39 AM | #313 | |
Rep 40,650
<SgbmId id="NAVD_000004CE_255_002_061" SWID_FscShort="0028000A" name="Road Map Europe West PREMIUM 2015-2" supplier="NTQ" sop="01.03.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CIC-HB" Format="CIC" /> <SwUpdate SwUpdateEntry="No"/> </SgbmId> East: <SgbmId id="NAVD_000004CE_255_002_062" SWID_FscShort="0028000A" name="Road Map Europe East PREMIUM 2015-2" supplier="NTQ" sop="01.03.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CIC-HB" Format="CIC" /> <SwUpdate SwUpdateEntry="No"/> </SgbmId>
FlorinQCK-2.50 |
05-26-2015, 11:41 AM | #314 | |
Rep 40,650
So, you must pull 1B file from CIC, in which case you need an ICOM Interface.
FlorinQCK-2.50 |
05-26-2015, 12:02 PM | #315 | |
Rep 8
no, i don't have an Can filter....i just update CIC because i had malfonctions Yes i have an icom ! |
FlorinQCK-2.50 |
05-26-2015, 12:07 PM | #316 | |
Rep 40,650
1) Load your original CIC FSC Codes into CIC using ICOM and ISTA/P. If Donor VIN is newer than your VIN though, you will need to make CIC Virgin first, which is not an easy process. 2) Use Activation module.
FlorinQCK-2.50 |
05-26-2015, 12:22 PM | #318 | |
Rep 40,650
I have no idea on wiping the hard drive. Frankly, I wouldn't worry about this. It may cause more problems then it solves.
FlorinQCK-2.50 |
05-26-2015, 12:37 PM | #320 |
Rep 40,650
Everyone wishes there was...
FlorinQCK-2.50 |
05-26-2015, 12:49 PM | #322 |
Rep 40,650
Yes, but that is a royal pain in the ass, and it applies to car with Script Activation, which is a totally different animal that you do not have to deal with.
FlorinQCK-2.50 |
05-26-2015, 07:59 PM | #325 | |
Rep 40,650
http://f30.bimmerpost.com/forums/sho...&postcount=317 <SgbmId id="NAVD_00000939_255_002_051" SWID_FscShort="0047000C" name="Road Map Europe West MOTION 2015-2" supplier="NTQ" sop="01.04.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CICM-HB" Format="CIC" /> <SwUpdate SwUpdateEntry="No"/> </SgbmId> <SgbmId id="NAVD_00000939_255_002_052" SWID_FscShort="0047000C" name="Road Map Europe East MOTION 2015-2" supplier="NTQ" sop="01.04.2015" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="HU_CICM-HB" Format="CIC" /> <SwUpdate SwUpdateEntry="No"/> </SgbmId> <SgbmId id="NAVD_000014B9_255_002_182" SWID_FscShort="00A90007" name="Road Map EUROPE Next 2015-2" supplier="NTQ" sop="01.03.2015" version="10_09" MapOrderNumberBMW="65902350335" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId>
FlorinQCK-2.50 |
05-27-2015, 03:49 AM | #327 |
Rep 95
Hi Shawn and Kitster,
My symantec endpoint AV finds a Trojan.Gen.2 virus in the fsc.exe file in the FSC generator tools Kitster shared in his post http://f30.bimmerpost.com/forums/sho...1&postcount=33 What should I do? Tks in advance for your help. |
FlorinQCK-2.50 |
05-27-2015, 02:16 PM | #328 | |
Rep 1,894
and replace the lookup.xml with the one attached, change the *.zip extension to *.xml. |
FlorinQCK-2.50 |
05-27-2015, 05:23 PM | #329 | |
Rep 95
I have dowloaded from that location and again the same result: the AV finds that virus in the FSC.exe file located in the CIC folder. The other FSC.exe in the NBT folder is ok and unfortunately the one I need is the CIC one... Do you have a safe version? Another 2 questions: 1) does the lookup.xml file that you added has already the XML block for the 2015-2 Europe West Premium for CIC? 2) What are the other files I have downloaded from the new location you shared (CIC mafia, swid reader, CIC language coding utility, etc)? Tks again for your help! |
FlorinQCK-2.50 |
05-27-2015, 05:28 PM | #330 |
Rep 1,894
Tks kitster!
I have dowloaded from that location and again the same result: the AV finds that virus in the FSC.exe file located in the CIC folder. The other FSC.exe in the NBT folder is ok and unfortunately the one I need is the CIC one... Do you have a safe version? - Sorry I just use some crappy offline laptop for my NBT coding. Another 2 questions: 1) does the lookup.xml file that you added has already the XML block for the 2015-2 Europe West Premium for CIC? - YES 2) What are the other files I have downloaded from the new location you shared (CIC mafia, swid reader, CIC language coding utility, etc)? You just need the FSC Code Generator folder. Tks again for your help! |
FlorinQCK-2.50 |
