BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > OEM HUD Retrofit
      01-19-2017, 11:15 PM   #1
soso2222
Drives: Z4 35is, F31 330xd
OEM HUD Retrofit
Hi everyone!
Iīd like to retrofit an OEM HUD. I have all the Parts except Dashboard.
Can i just cut a hole in my existing Dashboard, or do i have to buy a new one with a hole in it to fit a HUD-Display?
      01-20-2017, 08:23 AM   #2
atzebmw
Drives: BMW 335XD F30 LCI
And how do you fix it on the dashboard?
There are no screw holes.
      01-20-2017, 08:56 AM   #3
soso2222
Thatīs why i am asking! So, i have to buy a new Dash.....
      01-20-2017, 10:37 AM   #4
atzebmw
Originally Posted by soso2222 View Post
Thatīs why i am asking! So it i have to buy a new Dash.....
Yes, i think so.
And of course a new windshield.
      01-20-2017, 10:39 AM   #5
soso2222
A new HUD-windshield is already installed!
      01-21-2017, 09:07 AM   #6
Cornel_t
Drives: BMW 320 xDrive Touring
Some time ago I was interested to perform HUD retrofit. The informations I've got from a professional installers were that the original factory fitted dashboard can be cut without any problems an even if the cut is not the cleanest one the trim you should buy is covering perfectly any imperfection.
This is the trim link
http://www.realoem.com/bmw/enUS/part...&q=51459239336
As well you should consider that most probably your cars' instrument cluster is not appropriate for retrofitting the HUD, check what you have and compare with what is needed (use realoem.com)
The last but already solved by you is the windshield
Whish you easy retrofitting
      01-21-2017, 09:28 AM   #7
soso2222
Oh, perfect!
That is what iīm talking about! Thank you!
Instrument cluster is already HUD-proof.
Bye and thanks!
One more question: Do you know a partnumber for a wire from cluster to HUD?
By the way, hier is a picture of installation of HUD with 3 screws on a dashboard carrier!
      01-21-2017, 02:30 PM   #8
soso2222
Is this a right partnumber for HSD-Wire?
61119258857
      01-22-2017, 12:16 AM   #9
Cornel_t
I don't know what's the cable that fits but you should find below.
http://www.realoem.com/bmw/enUS/part...MW-330dX&mg=61
This is your PN on leebmann
https://www.leebmann24.de/rep-satz-h...119258857.html
      01-22-2017, 12:26 AM   #10
soso2222
The problem is, i canīt find a HSD wire for 3. series. Only for x3 and x4 series!
      01-22-2017, 04:24 AM   #11
atzebmw
HSD cable from X3 or X4 fits also.
Or from 5series F10 fits also.
      01-22-2017, 04:34 AM   #12
soso2222
Ok, thankīs!
      01-22-2017, 11:56 PM   #13
soso2222
Does HSD wire of F10 fit? HUD-unit in F10 has an ECU in f30/31 doesnīt!
      01-23-2017, 05:26 AM   #14
atzebmw
Yes, i'm very sure because the HSD cables have all the same plug.
But the f10 cable you do not need to take, because that is much too long (1310mm).
      01-23-2017, 08:00 AM   #15
soso2222
Hi, i ordered a HSD-wire for F10 and some other minor parts. I will have to tinker a powersuply for HUD-Unit thow. Itīs a retrofiting time this firday!
      01-23-2017, 08:14 AM   #16
Animal Farm
Drives: BMW F30/Volvo XC90II T6
Wow! This is insanely cool! However, I would just upgrade my car... This could turn into a nightmare. I really hope it does not, but this is a very complicated retrofit.
I can't imagine the cost thus far???!!!
      01-23-2017, 10:22 AM   #17
soso2222
Itīs not that difficult! And The costs are within bounds!
580€ so far.
The Windshield was a matter of insurance and a cluster retrofit was essential!
      01-23-2017, 11:05 AM   #18
roxxor
roxxor's Avatar
606
Drives: 2020 530e
I'm planning on trying this shortly, have to figure out how to make the F30 HUD work with the 6WB instrument cluster first and then I'll worry about the dash/windshield.
      01-23-2017, 12:39 PM   #19
soso2222
I will report how it ended!
      01-23-2017, 08:18 PM   #20
Animal Farm
580€ so far.
Ha ha, nice!
      01-24-2017, 03:52 AM   #21
soso2222
I think it should work! Maybe the diagrams below will help you!
Good luck!
      01-24-2017, 12:50 PM   #22
roxxor
roxxor's Avatar
606
Drives: 2020 530e
Good luck!
Oh yeah, I already have the wiring pinouts mapped out, thank you though. Become quite familiar with Rheingold over the past 2 years
The difference I believe will be in what the 5/7 series 6WB Cluster outputs to the HUD vs what the F30 HUD is looking for, especially since it looks like the HUD from the higher level cars has a K-Can connection. Haven't had a chance yet to compare the coding yet, but i know another person on the forum who had not been able to get it to work, although I don't believe they went too in-depth into attempting to resolve it yet.
Also, according to realoem, the air duct may need to be replaced on the driver side as well, as there is a different part number for vehicles with HUD listed as #5 on the list here.
