BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Valve Cover Gasket Replacement
      01-18-2021, 07:42 AM   #23
XxThe_RemedyXx
Greece
676
Drives: 2014 335i XDrive
Originally Posted by jgoens View Post
I have been putting off this job for awhile...do get smoke and see oil at rear passenger side. What I am wondering us why replace whole cover instead if just gasket? How hard was it to replace the vent hose, as far as bottom connection goes?
PCV hose was easy. Put a zip tie around it, in front of the 4 tabs and slide it under them so they all open at the same time, then slide it off. The base is easy as well, one screw and pull it out.
'14 335 xDrive EWG FBO - VRSF Chargepipe - VRSF Catless Downpipe - AA Intercooler - MPE - BM3 Custom Tune by Cary Jordan - R1 Concepts Front/Rear Geomet Cross Drilled and Slotted Rotors - xHP Stage 3 8AT
      01-18-2021, 12:59 PM   #24
mlev
mlev's Avatar
Drives: 2014 335i M-Sport
My '14 needed this repair too, with only 47k miles. Seems like they just get bad over time.
      01-18-2021, 02:46 PM   #25
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Nice.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      01-19-2021, 09:11 AM   #26
jgoens
jgoens's Avatar
3659
Drives: 2013 335i msport
Originally Posted by cjlane View Post
The cover gets brittle and is prone to cracking. Since you are already there, it's a good idea to replace the cover at the same time.
I'm kind of debating on changing the whole thing--pretty big price difference as far as the whole piece or just gaskets--especially if the cover is fine. My car has 65k. Couple of vids, including the one in this thread, show just the gasket change. Wondering what the dealer does by default.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP
      01-19-2021, 09:45 AM   #27
XxThe_RemedyXx
Greece
676
I swapped the entire thing for piece of mind. Who knows if the old one was warped or had micro cracks in it that would eventually fail. I figured if I'm doing all of this work I might as well just swap the entire thing out and be done with it. I would HIGHLY recommend swapping the PCV hose, I'd go as far as saying it was a requirement for this job. No way I was putting that back.
I'm still trying to figure out what that hose was in the video that was missing on my vehicle. That and why both vacuum ports were plugged instead of just the one.
jgoens3659.00
      01-19-2021, 10:45 AM   #28
jgoens
jgoens's Avatar
3659
I think I will get the PCV hose---still try to figure out the cover part. I'm fine getting a new one if that is needed, but I don't really want to spend an extra $400+ if its not necessary. I think if the car has 100k or so its an easier decision...but replacing the whole cover at 65k....kind of lame if these things need to be replaced that often.
      01-19-2021, 04:54 PM   #29
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
They don't replace the cover unless they find cracks. However they don't typically replace gaskets on vehicles closer to 100k miles on the odometer.
      01-19-2021, 04:56 PM   #30
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
IIRC was a port for vacuum activated wastegates. I think there used to be a cap. You could reach out to FCP.
      01-19-2021, 06:09 PM   #31
XxThe_RemedyXx
Greece
676
This is the only picture I've been able to find with regards to this port. It's number 2 in the picture but no solid info...
Should it be capped?
      01-19-2021, 08:16 PM   #32
khj24
khj24's Avatar
186
Drives: 2015 m235i
Mine was unused when I replaced my VCG and I left it as is. No issues for over a year, I think it's just a leftover port for older N55's that isn't utilized with EWGs.
      01-19-2021, 09:27 PM   #33
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Mine factory cover wasn't so I wasn't to concerned
      01-19-2021, 11:17 PM   #34
Tchao
Boost Addict
Tchao's Avatar
Drives: E30, E82, F30
The lower part of the VC is a built-in vacuum reservoir, with ports to the vacuum pump and wastegate. It's not used in EWG cars.
N55 PWG | Three Pedal Club | E30TU
      01-21-2021, 01:33 PM   #35
Randy Johnson
BM3
127
Drives: BMW 435i GC M-Sport
2015 BMW  [0.00]
Thank you for the explanation. I did not have the vacuum lines on my 435i either and could not find a reference online that there was a change.
435i GC M-Sport
      02-08-2021, 08:37 PM   #36
Chaos236
Chaos236's Avatar
70
Drives: Porsche Cayenne , Lexus GS
Just ordered everything up and hopefully will have the parts by Saturday. Looking forward to fixing this. The only thing I worry about is rolling the gasket when installing the new one. Wonder if I should pick up some gasket tack... FCP says the gaskets and bolts are preinstalled so I'm hoping they're in there nice and tight. I ordered all OEM parts so they should be good.
I need to do all the same repairs, what’s the deal with FCP shipping options and long time to get the parts?
      02-09-2021, 08:07 AM   #37
XxThe_RemedyXx
Greece
676
FCP is amazing. They're based out of CT and I live in NY, about an hour away. I pick the free shipping option and I get everything the next business day. Parts are what you expect from OEM and FCP's customer service is top notch.
      02-09-2021, 10:14 AM   #38
designatedposter
Drives: m235i
Fcpeuro.com
M235i rwd 6mt
      02-09-2021, 11:35 AM   #39
thejeremyman9
thejeremyman9's Avatar
1915
Drives: 2015 BMW 335i
FCP euro is good and i have used them for most things.
I have also found that ecs tuning has the fastest turnaround time and very fast (1-2 day) shipping options should you need that and want to pay for it.
      03-03-2021, 02:53 PM   #40
frchdragon
frchdragon's Avatar
Drives: 13 335ix MSport
This is a lot of good information. I am going to start pulling the valve cover out, mine is also leaking.
I have a question regarding the BMW Valvetronic Actuator Seal, anything special regarding the replacement?
'85 635csi M30 turbo race car
'13 335ix Msport BM3 stage MPPK
      03-03-2021, 03:18 PM   #41
XxThe_RemedyXx
Greece
676
Nothing to it. Purchase a replacement and it comes with self tapping screws. Screw them down hand tight until they bottom out, no further. The gasket will seal and you're good to go.
      03-03-2021, 04:09 PM   #42
frchdragon
frchdragon's Avatar
Thank you, my part supplier has the gasket only, no screws... I wonder if the stock screws can be reused. I can see some seeping from the area so I want to change it while I am at it.
I didn't see anybody in the videos changing it, I guess I will try and report back.
The zip tie trick worked perfectly, here is a pic of it in action.
      03-10-2021, 11:48 PM   #43
antzonthe1
Drives: BMW 435i
My 2016 f32 has 94k miles and hardly a leak but it did show itself and smoke a tiny bit once or twice so I'm gonna dig in. From just inspecting with cover off and flashlight it looks to be the gasket, actual cover shows moisture in two spots hope it's not a cracked. Ordered a VC off amazon for $100 hope it's good enough lmao. Goin to order a gasket off fcp in case I want to only do the gasket since I don't know the history of the car but it's been great and all parts everywhere look newish and clean. Will let yall know how the amazon VC is
      03-11-2021, 07:35 AM   #44
Jungatron
Jungatron's Avatar
173
Drives: 2015 335i M Sport
If anyone has questions please feel free to message me. This was a great experience and I learned a lot.
Love it! I gotta do this at some point. No leaks yet but 48k on my 15 335i so almost to that time.
2015 - 335i RWD A8 | MPE, MP LSD, M sport Wheel, M Sport Suspension, 245/35/18 square, BM3, VRSF Chargepipe |
