08-09-2022, 08:23 AM | #16215 |
Rep 40,792
PM sent.
08-12-2022, 10:20 AM | #16216 |
Rep 46
08-12-2022, 10:21 AM | #16217 |
Rep 40,792
PM sent.
08-17-2022, 07:13 AM | #16218 |
Rep 25
Hello my friends,
I did a quick search but didn't find anything related... Does anyone have a code list for LED conversion and lamp verification by Esys and Bimmercode? By Bimmercode there are some conversion options but internal lights and some other lights don't have. Last edited by Jems32; 08-17-2022 at 08:42 AM.. |
08-17-2022, 12:02 PM | #16219 | |
Rep 332
External filament (halogen and non-halogen) bulbs mostly have hot and cold monitoring implemented. This involves the control unit applying a small voltage across the bulb at startup and during use. If there's a problem (a short or open circuit) you'll hear about it. The current passed is very small so the bulb doesn't show any sign of it. If the car does the same for an LED bulb it will have a noticeable flicker, unless it's designed to avoid this or you have a resistor in parallel. The best solution is to code out the bulb monitoring for every affected bulb. I did this for every external bulb in my 2014 F30 330D and the changes are probably relevant for your car. If you want to see my list let me know and I'll get something to you in the next day or so. |
08-18-2022, 03:04 PM | #16220 |
Rep 64
Hello Guys,
Does someone knows if there is any possibility to have the window rolling up automatically at door openning, by codding ? (I have a 3 series 335i F30, 2013 MY) Thank you in advance for your hints. |
08-18-2022, 03:07 PM | #16221 |
Rep 40,792
Not possible.
08-21-2022, 09:28 AM | #16223 |
Rep 30
Hi guys, I'll be coding a heated steering wheel as a retro fit and need the latest and greatest software. I understand this is the place to get it
Thank you in advance!
2000 323ci | 2015 328i xDrive
08-21-2022, 12:22 PM | #16224 |
Rep 40,792
PM sent.
phat_joe30.50 |
09-03-2022, 08:52 PM | #16225 |
Rep 5
Hello, the engine of my 320d broke. I replaced it with an engine from a 118d. Use the injectors from my 320d and the DDE.
The only thing that differs one engine from another is the turbocharger actuator. The Siemens (118d) is 4 pin and the Hella (320d) was 5 pin The DDE has the 5-pin configured and I need to change to the 4-pin actuator (The DDE will use either of the two actuators). How can I change the type of actuator in the DDE? I look forward to any suggestions. |
09-22-2022, 09:57 AM | #16226 | |
Rep 78
Resetting trip computer in side screen (BimmerCode)
I'm using BimmerCode and a vGate Bluetooth adapter, and I've previously set this to reset periodically. IIRC, I think I previously set it to 1 hour using hex (0x1) back when BimmerCode only had "expert mode." So this was years ago. My car recently stopped resetting this time for some reason after an oil change and rear brake service, which I had done by a non-BMW mechanic who may or may not have used an OBD device to reset them. I went into "Average Values Reset" under KOMBI_L7_MID (Instrument Cluster)... and it had "unassigned value" displayed. I changed it to "After every ride" and it still doesn't seem to be resetting... though I could only turn the car off for a minute and turn it back on to check if it was reset. Anyone have experience with this? Does "After every ride" change the time to literally 0hr 0min 0sec, so that as soon as the car turns off, it's reset? Or is there still a short buffer period so that it doesn't reset when you get gas on a trip or run into a store? Thanks! |
10-04-2022, 04:52 AM | #16228 |
Rep 2
im newbie here and would like to get all software, necessary files and tokens that is known to work correctly. i will try to code my 2013 f30 316i for some cheats and clear dtc history.
not sure if my pm is active but can you give a try when available? thanks in advance... |
10-04-2022, 08:47 AM | #16229 | |
Rep 40,792
10-11-2022, 11:52 AM | #16230 |
Rep 8
E-Sys 3.33.0
Hi there,
I'm having a terrible time getting e-sys 3.33.0 to work. Granted, I have not attempted coding yet, so this is all new to me as well. Does anyone have up-to-date instructions on how to install e-sys (what version?), launcher (what version?), and the appropriate data file(s)? Thank you in advance, Brian |
10-11-2022, 12:41 PM | #16231 | |
Rep 40,792
10-12-2022, 08:56 AM | #16232 |
Rep 8
I'm new to this forum and it looks like I need to reply to some posts before my PM function is enabled. "Thank you for verifying your account! In order to use the PM system and be a full fledged member of this community, you will have to make a certain number of verified post replies and wait 7 days for your account to be upgraded." So, I'll try and do this and follow back up with you in a week or 2. Thank you |
10-13-2022, 10:10 AM | #16233 | |
Rep 8
Great post, thank you!! |
10-17-2022, 09:20 PM | #16235 |
Rep 40,792
Sorry, I cannot help with ISTA. PM sent.
