BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Maybe one of the Fastest F30 0-100km/h acceleration 3.27s
      10-18-2017, 09:12 PM   #1
A7H335
Drives: BMW F30
Lightbulb Maybe one of the Fastest F30 0-100km/h acceleration 3.27s
Hi ALL,
A few days ago, my F30 335i xdrive N55 PWG has just achieved 0-100km/h in 3.27s measured by two different 10GHZ accurate GPS.
1/4 mile in 11.1s
youtube link:
Car: 2014 F30 335i xdrive PWG N55
Mod: Pure stg2 turbo, BMS JB4, BM3, PI and meth 25psi boost
Temp.: 20 degrees C
With driver and half tank, the car was around 1800kg. I will try to do some weight reduction, what's the most efficient way to reduce weight on this F30? please share your valuable comments! Thank u in advance!
My wechat ID: 1405817816
blcmn4.50
kern4174446.50
jeffc83725.00
TBN54426.50
      10-18-2017, 09:48 PM   #2
goj
goj's Avatar
Drives: 2016 EBII 340i 6-MT
Very fast. What boost do you drive at every day?
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04
Instagram: @brandons340i
      10-18-2017, 09:55 PM   #3
zulu1niner
Drives: F30 bmw 328i
2013 BMW 328i  [0.00]
thats insane. What mods are in this beast???
      10-19-2017, 02:35 AM   #4
Calvin36
Calvin36's Avatar
Drives: F30 335i M Sport
Mine: BSM F30 335i M Sport
Hers: AW F30 328i M Sport
      10-19-2017, 03:13 AM   #5
stormlv
Human
Switzerland
932
Drives: Yes
Awesome time! Congrats!
Small note: the GPS is 10Hz not 10GHz
2023 BMW M4 CP xDr | 510HP / 650Nm | Isle of Man Green | Photo album
Sold 2018 BMW M4 DCT / ZCP| 450HP / 550Nm | Sakhir Orange | Photo album | Tribute
Sold 2014 BMW 435xd | 360HP / 710Nm | Estoril Blue | Photo album
2010 BMW Z4 sDrive35i DKG | 306 HP / 400Nm | Space Gray | Photo album
      10-19-2017, 10:21 AM   #6
razzy530
razzy530's Avatar
Drives: 335i M Sport RWD
that engine won't last very long.
2013 X3 2.8iX
2013 335i M-Sport RWD
2007 530i RWD 6-Speed manual
BMWCCA MEMBER 397411
      10-19-2017, 10:43 AM   #7
kern417
Cheapskate
4447
Nice time.
Easiest ways to reduce weight:
Go down to a quarter tank of fuel
Remove rear seats
Remove trunk Lining
Remove catback
If you get really serious, definitely swap smaller brakes/wheels. Find a salvage 320i and take the set off of it.
      10-19-2017, 01:02 PM   #8
stormlv
Human
Switzerland
932
Drives: Yes
Also look into a set of light forged wheels, if you want to shed some weight.
You want to reduce as much as you can from "rotating" mass
      10-19-2017, 01:19 PM   #9
dereksM3
dereksM3's Avatar
Drives: 2016 MG 340i M-Sport
Judging from his picture he looks to have BBS FI-R which are about as light as they come...I would assume they are authentic ones but it's hard to tell.
      10-19-2017, 03:21 PM   #10
stormlv
Human
Switzerland
932
Drives: Yes
Well spotted!
      10-19-2017, 05:47 PM   #11
dereksM3
dereksM3's Avatar
Well spotted!
Those would be the wheels I would own if I could swallow the $$$...them boys are expensive!
      10-19-2017, 07:55 PM   #12
A7H335
Drives: BMW F30
25psi to maxed out PS2 turbo
      10-19-2017, 07:56 PM   #13
A7H335
Drives: BMW F30
Flash : bootmod3
Tune: JB4
Turbo: pure stg2 550whp
Fuel: E35 mixture
      10-19-2017, 07:57 PM   #14
A7H335
Drives: BMW F30
Originally Posted by kern417 View Post
Nice time.
Remove rear seats
Remove trunk Lining
Remove catback
Thank you and I will starts to remove muffler as it was 25kg T309
      10-19-2017, 07:58 PM   #15
A7H335
Drives: BMW F30
BBS Ri-D for F30
      10-19-2017, 09:03 PM   #16
kern417
Cheapskate
4447
you can remove the midpipe too and just dump the exhaust from the downpipe if you're willing.
and no matter how your wheels are made, bigger will weigh more and the tires will grip less. i'm telling you, drop down to 17s and some tall tires and your times will jump without changing anything else. removing weight from the inside of the car might not have as big of an effect as you expect, but it'll help too.
      10-19-2017, 09:21 PM   #17
Mike.
Mike: Everyone's Pal
Mike.'s Avatar
Drives: F80 M3
2013 BMW 335xi  [10.00]
honestly thats a good time and all but my 320i with stock run flats(75% tread) runs this time..
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix
      10-20-2017, 02:22 AM   #18
cngo
His BBS RI-D already weigh less than 19 lbs per wheel. It's also going to be next to impossible to find 17" wheels that will clear 380mm brake rotors.
      10-20-2017, 11:15 AM   #19
jnecr
Drives: 2014 328d
It's more than just absolute weight though. It's also about Rotational Inertia, which the 20" wheels will have a much great moment of inertia than 17" wheels even given the exact same weight.
If he's really searching for 1/4 mile times then those brakes need to go as well. He'd probably save 50 lbs just dropping down to base calipers, then another 20-30lbs dropping down to base size rotors. This doesn't even factor in the lower moment of inertia on the smaller rotors..
Edit: I'm guessing he'll find much better drag tires with smaller wheels as well. Proper drag tires will help his time more than any weight savings.
2014 328d
kern4174446.50
      10-20-2017, 12:41 PM   #20
A7H335
Drives: BMW F30
Thank you very much for your hint, so far I am using Michelin CUP2, due to Xdrive, slippery issue can be improved by better launch techniques. BBS RI-D only weight 7.5kg each
      10-20-2017, 12:43 PM   #21
A7H335
Drives: BMW F30
I will focus on reduce rotation weight, thank you very much!
      10-20-2017, 12:50 PM   #22
Extirpate
Drives: 328i 2012
Hi ALL,
1/4 mile in 11.1s
youtube link:
Temp.: 20 degrees C
That's some serious speed man, congratulations
f30 0-60mph, n55
