BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > bootmod3: Map Switching (DEMO) - Advanced End User/Tuning Features
      09-08-2020, 02:32 PM   #1
proTUNING Freaks
proTUNING Freaks's Avatar
3901
Drives: powered by bootmod3
Hey guys,
Wanted to share a quick demo of an upcoming new feature for bootmod3 called map switching. In this demo it is running on a 2015 BMW M3 with the MEVD17.2.G DME, S55 motor.
This enables users with bootmod3 to flash once but be able to switch between maps in the car without any other flashing. Custom BM3 maps can be created with current 4 entirely independent maps embedded into one with separated settings for load/torque/boost, ignition timing, fueling, knock sensitivity, iDrive gauges and burble.
Map 1: 0.1 BAR of boost (1.5psi ) - Valet map
Map 2: E30 OTS map
Map 3: 1.8 BAR (26psi) 12 degree timing
Map 4: 2.2 BAR (32psi) 18 degree timing with WMI
At the moment, under the covers over 30 calibration tables and the logic driving them have been exposed to enable this level of configurability, with more coming..
Soon, we're releasing a demo of rolling antilag as well as flex fuel integration using flex sensor integration over the canbus.
DME on the N55 is virtually the same and we're looking to port the features over to the N55 as soon as its finalized on the S55.
All the best, cheers
Appreciate 7
Conr4d19.50
aps263.00
MAKH 557.50
      09-09-2020, 01:02 PM   #2
aps
aps's Avatar
263
Drives: '13 F30 335i
this is awesome! excited for the N55 release
2013 335i (8AT, PWG) /// BM3 Stage 2, FBO: CTS Turbo FMIC, CTS Catless DP, ER CP /// Bilstein B14, OEM 437Ms, MP LSD, MP Brakes
      09-09-2020, 02:40 PM   #3
Fudz
Drives: 2015 435I 8speed
This sounds awesome
how do you switch maps?
      09-09-2020, 03:27 PM   #4
Eschmacher
Car Hypochondriac
2014 BMW 335i  [0.00]
The guy at my shop told me this was coming... glad to see it's true!
Power mods: VRSF CP/IC/Catted DP - AFE Cat-back - BM3 S2 93 - XHP S2
Handling mods: B6 damptronic - Eibach prokit - M Performance LSD - M3 brakes - EBC yellow
Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser
Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327
      09-09-2020, 04:56 PM   #5
MTWO
Drives: M2
This is so full of awesomeness!!
      09-09-2020, 05:28 PM   #6
xnick101
Drives: 2014 Bmw 335i (F30)
This is awesome!!!! Can you guys please add an option where we can set an RPM limiter in the map settings?
2014 335i M-Sport
Bootmod3, VRSF 5" IC, VRSF CP, VRSF 4" DP, AFE Pro Dry S Drop-in Filter
      09-09-2020, 05:31 PM   #7
xnick101
Via steering wheel controls
2014 335i M-Sport
      09-10-2020, 09:59 AM   #8
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
      09-10-2020, 08:20 PM   #9
MTWO
Drives: M2
I wonder how the antilag will sound once this is out
      09-12-2020, 09:38 AM   #10
TroyBE
TroyBE's Avatar
Belgium
Drives: BMW F32 435i
This sounds awesome
For now you switch maps with the brake and the gas pedal but they are working to getting it on the steering wheel.
I'm so excited for this!
2017 - 2020: BMW F20 114i 2013
2019 - now: BMW F32 435i 2015
      09-12-2020, 10:35 PM   #11
Logicoeur
Logicoeur's Avatar
695
Drives: F30 335i xDrive
Oh la laaa.
F30 335iX | Remus Axleback | 18X9 ET32 19lb TR-1 255/40/18 | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete
      09-13-2020, 05:44 PM   #12
AlpineweissF10
Drives: 2012 535i Xdrive
This is awesome! I'm assuming this will work on the F10 N55. If so I'll be happy I went with BM3!
      09-14-2020, 07:42 PM   #13
MTWO
Drives: M2
They said they’ll add it to all cars they support most likely. I can’t wait for it on my M2 and my B58
      09-15-2020, 05:00 PM   #14
MAKH 5
MAKH 5's Avatar
Drives: 335i (Retired), M340i
Steering wheel controls like M1 and M2 buttons ? ... that would be amazing!
      09-15-2020, 06:08 PM   #15
xnick101
No, I would assume cruise control like other cars that have map switching on steering wheel. Tach goes to 1-2-3 depending on which map you are choosing.
2014 335i M-Sport
      09-15-2020, 09:41 PM   #16
Logicoeur
Logicoeur's Avatar
695
If they can add functionality to enable map switching from cruise control stalks/buttons, it isn't a stretch to link that feature to a button of our choosing. The underlying software to enable that would already be hard coded to the module for the cruise control. Bm3 would just need a dynamic way for the end user to "tell it" which button to use as a "switch". Result would then be adding our M buttons to empty place holders and configuring bm3 to use it at runtime.
aps263.00
MAKH 557.50
      09-16-2020, 05:31 PM   #17
MTWO
Drives: M2
Once they release this stuff World is your oyster then for them in terms of what they’ll be able to do. I can’t wait to see what’s yet to come
      10-13-2020, 08:34 AM   #18
proTUNING Freaks
3901
Hey guys, quick update:
First off, ton of fun working and testing these new features! Testing is going really well. We've moved the trigger controls away from the pedals (accel. pedal and brake) to the left side of the steering wheel for ease of use while driving. We're expanding to even more tables that are switchable for each map slot which will make for some really interesting new features not possible so far. Flex fuel tuning is using a continental flex fuel sensor sending ethanol content and fuel temp over CANBus. Along with these changes on the DME side we're expanding the abilities of the tuning editor with features and changes we've been working on for some time now. Lots more to follow here soon. Cheers
ZM21670.50
      10-13-2020, 08:45 AM   #19
14F30Daily
Thanks for the update, you guys have been great.
2014 335i M-Sport, CTS intake, VRSF FMIC, VRSF CP, BM3 stage 1
      10-13-2020, 09:10 AM   #20
Eschmacher
Car Hypochondriac
Just curious, where/how does the flex fuel sensor patch into the DME?
      10-13-2020, 09:31 AM   #21
Logicoeur
Logicoeur's Avatar
695
Left side of the steering wheel as in buttons on the steering wheel, the stalk on the left side, or buttons around the left side vent for the driver?
Still wondering about those M buttons
      10-13-2020, 11:02 AM   #22
proTUNING Freaks
3901
Cruise buttons on the steering wheel, left of the horn, not the stalk we'll also have it in the app if using the app you can tap on a map slot and switch and see the map slot change in the RPM gauge in the dash cluster indicating it there as well
Logicoeur695.00
harkes893.00
bm3, bootmod3
