04-28-2021, 10:48 PM | #1 |
Rep 7
Catless Downpipe Better With Muffler Delete or Res Delete
I just got a catless downpipe installed on my f30 330i and I have stage 1 bootmod and the pops aren't as loud as i want them to be, should i get a resonator delete or muffler delete to make them more obnoxious.
04-29-2021, 07:05 AM | #2 |
Rep 100
Drives: F30 328i BMW
I have a muffler delete (3" all the way) with the stock res. Definitely will be loud if you crank up the aggressiveness. I have mine at no higher than 3, but did have it around 7 for a short while. If you want the bangs/gunshots/explosions you'd definitely have it.
sard_f301.00 |
04-29-2021, 09:05 AM | #3 |
Rep 190,633
in my opinion both options are obnoxious, i recommend you get an real muffler instead
04-29-2021, 09:48 AM | #4 |
Rep 73
Full exhaust, secondary deletes, and catless are the way to go. Valvetronic if you want to be able to put the car in neighbor friendly mode.
I posted the video in a few threads. Here it is in this one: https://f30.bimmerpost.com/forums/sh....php?t=1676076
2017 BMW 330ix MSport Estoril Blue - B46, ER Catless DP, ER Chargepipe, FTP Intake Charge Pipe, BMS Cone Intake, BMS OilCC, Bm3 Stage 2. FI Exhaust, xHP Stage 3 OTS Transmission tune. CSFRace heat exchanger. Performance M Brake kit. AFE Carbon Fiber D.A.S.
https://www.instagram.com/bfourtysick/ |
sard_f301.00 |
04-29-2021, 12:14 PM | #5 | |
Rep 7
04-29-2021, 12:16 PM | #6 | |
Rep 7
04-29-2021, 02:19 PM | #7 | |
Rep 100
I will be going to an axel back shortly once the Megan is released through X-PH to go to dual tips. Too loud for me with the current setup especially from 2000-2500 RPMs.
'13 328i Xdrive - BM3 Stg 1; Muffler Delete; BMS Wheel Spacers
04-29-2021, 04:28 PM | #8 | ||
Rep 7
04-30-2021, 12:58 PM | #9 |
Rep 100
I would say your secondary cat is reducing the noise and/or your Active Sound settings through BM3 may be disabled.
05-01-2021, 05:08 PM | #10 |
Rep 1,055
If you want it to be the loudest possible, you are going to have to straight pipe it all the way back after the downpipe. Any muffler shop can do this for you. They will straight pipe the secondary cat + resonator + no more muffler.
Otherwise you can get a cat back exhaust that doesn't have a resonator in it and you'll do the same but a tad quieter.
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
06-01-2021, 01:41 PM | #12 | |
Rep 73
Secondary Cat Delete
FI posted my video to their youtube. XD
milans0.00 |
