BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Tire size for 19x8.5 et 35 on f30 xdrive
Studio RSR
      07-11-2018, 09:05 PM   #1
BowensF30
Drives: Black F30 335i xdrive
So i just got my new square wheel setup 19x8.5 et35 and was wondering if i can run 245/40/19 without rubbing issues. Or would 245/35/19 be a better option? This is for front and back as its a square wheel setup. I will be slightly lowering my car with a set of lowering springs so that needs consideration as well. If need be i will run a 235/40/19 or 235/35/19 but id prefer the slightly wider 245 if possible. Thanks for any help
      07-11-2018, 09:12 PM   #2
alohasurftoad
Drives: 440i gran coupe w/mppsk
just do 255/35/19 square, like this... https://f30.bimmerpost.com/forums/sh...35%2F19+square
      07-16-2018, 09:47 AM   #3
classyfast
Drives: e36m/e46m/E92 LCI 335/f30 335
This is 245/40/19 on xdrive stock msport suspension (edc also). 19x8.5 et35 vmr v810 wheels. The ride is super smooth, quiet and I like the beefier look of the bigger rubber. You could prob lower the car without issue as well. I'm leaving it like this but you could....
      07-16-2018, 02:25 PM   #4
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
Looks great but isnt that a pretty tall tire for the F30. Its F10 tire sizes. you are .7" taller than stock
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      07-16-2018, 04:20 PM   #5
classyfast
From what I'm told it was about .5 over stock, no adverse effects as of yet! Speedo seems more correct actually, it is a slightly taller tire but the additional rim protection is good for me and I dig the look.
Over the past 17 years of owning bmw's and playing with tons of tires and rims, I've noticed visual differences in same size tires, this set actually rubbed at full lock on the guys 328xdrive that owned these before me. On mine they don't.
When I get new tires I may try 255/35/19 all around or 235/40/19 maybe we'll see.
19x8.5, square wheel setup, tire size, xdrive
