10-02-2019, 10:11 AM | #2773 |
Rep 80
Hello guys!
I have an 10,25 screen by fltombo bought in aliexpres... my car is an e87 series 1. the question that i have is that i have bought an idrive controller for retrofiting it in my car, but i dont have the conecctions to the car.. i would like if someone can explain me how can I connect the idrive controller (ccc) to the screen radio.. i didnt find anything in internet.. thank you! |
10-04-2019, 06:22 PM | #2774 |
Rep 399
I think you need the iDrive controller that you can buy with the Android units. Contact the seller and ask for such an iDrive controller.
You can not connect an original iDrive controller. Cars with original iDrive have a different Head Unit, which the Android unit connects to. It will be far too much job retrofitting CCC or CIC for this. |
10-05-2019, 10:34 AM | #2775 | |
Rep 80
And other question, how can i install an update? i´ve done all the steps with the usb but i cannot do anything.. i want to have the chinese idrive cotroller working with android auto app.. Thank you! |
10-05-2019, 02:42 PM | #2776 | |
Rep 80
10-05-2019, 10:44 PM | #2777 |
Rep 399
Your car doesn't have CCC, as I understand you. In that case you will have to replace your Head Unit with a CCC unit if you want the original iDrive controller. A better solution for you is to buy the iDrive controller that is supplied with some Android units. Check the harness from the Android unit, is there a cable labeled X1? This is for connecting this (not BMW original) iDrive controller.
10-06-2019, 04:19 AM | #2778 | |
Rep 1,048
Chri |
Pondaire37.00 |
10-22-2019, 12:57 PM | #2781 | |
Rep 1
Hi!
Have you been able to solve this issue? I got the same one, and mixer_path is also the same. I've spent a lot of hours trying to boost mic volume but without luck... Quote:
10-26-2019, 10:06 AM | #2782 |
Rep 3
Hi dear F30 community,
I've registered here because I'm a little desperate right now. I bought a replacement head unit (display). It runs on Android and loops the signal of the normal radio. Therefore you can use Android and BMW NBT at the same time. I bought the device mainly for retrofitting Apple Car Play. The radio is a harman hb b069. I wanted to have the device installed in a garage first, but then I decided to install the device myself. I used this installation video: https://www.youtube.com/watch?spm=a2...&v=p6qCfTQaKN4 Well, I got down to work. Step by step everything was fine. I then finally connected everything and checked the functionality before finally reinstalling everything. It all worked. Greats But then there were problems with the space behind the radio unit. Everything just didn't fit from the place anymore. Then I tried to move everything a bit and press it to make it fit. You could still hear the radio unit humming a bit. So there was electricity on it. Then it suddenly stopped and everything was dead. Means the radio unit and the display simply remained silent. Nothing works anymore. So suddenly there seems to be no more electricity on it. Now I was fast at a garage and had the fuses checked quickly. They say that everything looks fine. Now I stand here and nothing works anymore. The air conditioner display, the cigarette lighter etc. has electricity. Just the radio unit no longer. I also rebuilt everything and connected the original screen. That didn't help either. Now I wanted to test whether electricity comes at all over this thick black plug or whether I broke my radio unit. Probably I have been stupid not taken the whole thing from the battery. But I also wonder if such a radio can break so fast. I still have the hope that it is only a plug that has come loose. But since I'm not a garage guy nor an electronics technician, I don't know what to do and hope that you can tell me what it is or who I can turn to. I am really desperate. Thank you! Translated with www.DeepL.com/Translator |
10-26-2019, 11:45 AM | #2783 |
Rep 399
10-27-2019, 08:03 AM | #2784 |
Rep 80
It's not the displays because the original doesn't work either.
I'd look at each and every connection. Buy a multimeter and probe every single pin that is supposed to supply power. Chances are you broke a pin, if the fuses are all good. Or you could have also shorted it and burnt something instead of the fuses. |
10-27-2019, 11:37 AM | #2785 | |
Rep 182
It works but the built in mic doesn't work good and sometimes the autoconnect fails to. |
10-27-2019, 01:22 PM | #2786 | |
Rep 63
BTW were you able to get it to work over USB? |
10-27-2019, 06:17 PM | #2787 |
Rep 584
bhe, sorry but I've just used one of your photos in my thread, Avin CarPlay, how do you get Waze to show on the nav tile with the music player, some "knowledgeable" person says it's not possible.....
10-28-2019, 03:37 AM | #2788 | |
Rep 424
I paid for the apk in the hope they had more aspect ratio settings in the full version. No such luck, but they don't seem quite as bad in the full version. It's probably wishful thinking because I've paid |
10-28-2019, 01:36 PM | #2789 | |||
Rep 182
With the latest beta the dpi settings got easier, I played with resolution and dpi? I think this is 160 and 720p then you will get the music player and info screen and buttons to the left side. Quote:
10-28-2019, 10:58 PM | #2790 | |
Rep 63
BTW couldn't get it to work with 2 phones but worked with the third phone... USB never worked, got it going over WiFi. Instructions are confusing... |
10-29-2019, 02:12 AM | #2791 | |
Rep 182
To install the beta you need to install XDA labs first https://labs.xda-developers.com/ See button at the top : Download labs With that app you can pay and insall the full version / beta, you have to choose beta channel in the app |
10-29-2019, 02:34 AM | #2792 |
Rep 32
What I do is press the car's Media button(which switches it to Aux) then tap the screen to switch back to Android.
10-29-2019, 02:43 AM | #2793 | |
Rep 32
Does it now connect seemlessly when you hit Navigation button? I originally used USB route but too many prompts each time. Have played about with WiFi option but still not fully automated |
10-29-2019, 10:00 AM | #2794 |
Rep 63
On the phone enable hotspot and start Android auto server then launch head unit reloaded on the head unit. This only work with my wife's phone but not with my phone or a spare phone. Once I try the full-screen version or should I say widescreen and if it works well I will try to automate it with the Tasker
