11-21-2019, 11:05 AM | #23 |
Barge driver
8647
Rep 12,421
I think on modern car with already very bright rear lights the use of fog lights in the rain is overkill, I can see you already no need to blind me.....also the spray is often not consistent so for most of the time you're just annoying everyone behind you.
730d/Z4C
11-22-2019, 12:52 AM | #24 |
Rep 8,081
Exactly.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
Wills28647.00 |
11-22-2019, 01:49 AM | #25 |
Rep 4,935
Drives: 340i MPPSK
I thought fog lights made you immune to accidents in poor conditions? I've seen many a rep mobile doing 85mph on a dual carriageway in driving rain with their fog lights on
Life is a state of mind |
11-22-2019, 03:35 AM | #26 |
Rep 2,808
I love the morons who put their fog lights on in built up areas when visibility is around 300m. They are usually on then for the next 3 or 4 days until their brain engages once more and they turn them off.
Current: G26 i4 M Sport Pro, Tech Pk, Sunroof
Previous: 2016 440i MPPSK, 2014 330d Saloon F30, 2013 Audi S4 Avant, 2011 Mercedes C350 |
Wills28647.00 |
11-22-2019, 04:04 AM | #27 | |
Rep 3,037
When it's dim and you can't see your hand in front of your face fine use them, gives the advance warning that you're there to the car behind but if you can see their headlights behind you then they can see your normal lights... so turn them off....quite simple really. The benefit is then when you brake they will see the brake lights, which helps them not plough in your arse end. Should have the adverts on TV bit like the old Green Cross Road man, but then there's no educating some folk !! |
11-22-2019, 04:23 AM | #28 |
Rep 8,081
Yes, if only everyone did that. If you can see the car behind and he hasn't crashed into you, you can assume he's seen you so switch the bastard things off. It should be perfectly permissable in cities to drag folk from their cars and club them to death if they sit in front of you, at traffic lights, with fog lamps and brake lights blazing away. "I've SEEN you, you fucking bellend!!"
Ian
MashinBenzin8450.00 gr4z1135.00 |
11-22-2019, 04:37 AM | #29 | |
Rep 8,777
Drives - 2020 LR Discovery HSE-L Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE |
xenon1394.00 RENT-A-GOAT461.00 |
