07-11-2017, 02:51 AM | #155 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
In your video you stated you?re not sure if the turn signals are LED?s, they are in fact LED?s. Only the reverse bulb is incandescent. Otherwise sweet video! I?ve watched quite a few of them.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
07-11-2017, 08:47 AM | #156 | |
Rep 88
LiquidMercury212.50 |
07-12-2017, 10:13 AM | #157 |
Rep 2,083
MMM Thinking on getting these. No one on a Silver one? I guess they will look good on mine as I have the rest MP black parts. What do you think? Any news on the Shadow-lines yet?
07-12-2017, 10:44 AM | #158 |
Rep 968
07-12-2017, 03:50 PM | #159 |
Rep 34
Drives: 2013 BMW 328i M-Sport
I finally got the time to install my new taillights today. Loving the new look, I was surprise how easy the installation was
If anyone interested, I'll be selling my full rear set of WeissLicht LED bulbs for pre-LCI taillights which includes amber signals, red brake lights & white reverse for $70.00 each pair |
07-12-2017, 06:44 PM | #160 |
Rep 2,036
Looks great. Matching lines with the Msport kit and wheels.
07-12-2017, 06:46 PM | #161 |
Rep 2,036
Good find.......now you might cost me to empty my wallet for my silver F31.
07-14-2017, 09:54 AM | #163 | |
Rep 589
Anyone have instructions on installation at all? I'll be attempting to do this over the weekend or have someone do it, but it'd be nice if there were instructions on accessing and installing...or is uToob muh friend here? Thanks! Btw, no, mine didn't come with any installation details. |
07-14-2017, 10:42 AM | #164 | |
Rep 34
If you were local, I'll be gladly help install them for you. Very clean/ easy to do, no cutting wires, just swap/ re-pin wires. Here are the instructions on how to:
http://f30.bimmerpost.com/forums/att...7&d=1481021366 Quote:
07-14-2017, 12:06 PM | #165 | |
Rep 589
07-17-2017, 11:39 PM | #167 |
Rep 1,015
Ignore the wiring instructions....use the BMW PDF attachment i posted earlier in thread and reposted above instead...
But this is pretty much step by step for installing the physical units. http://f30.bimmerpost.com/forums/sho....php?t=1180852 |
07-25-2017, 02:00 PM | #169 |
Rep 307
Afternoon guys,
I've installed these this afternoon, but can't get inner indicators to work, I've coded Flashing Rear: REM 3061 FRA_H_L_KALTUEBERWACHUNG /nicht_aktiv REM 3061 FRA_H_L_WARMUEBERWACHUNG /nicht_aktiv REM 3061 FRA_H_L_IS_LED /aktiv REM 3061 FRA_H_R_KALTUEBERWACHUNG /nicht_aktiv REM 3061 FRA_H_R_WARMUEBERWACHUNG /nicht_aktiv REM 3061 FRA_H_R_IS_LED /aktiv Reverse lights: REM 3061 RFS_L_KALTUEBERWACHUNG /nicht_aktiv REM 3061 RFS_L_WARMUEBERWACHUNG /nicht_aktiv REM 3061 RFS_L_IS_LED /aktiv REM 3061 RFS_R_KALTUEBERWACHUNG /nicht_aktiv REM 3061 RFS_R_WARMUEBERWACHUNG /nicht_aktiv REM 3061 RFS_R_IS_LED /aktiv Brake lights outside: REM / 3061 / BL_L_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / BL_L_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / BL_L_IS_LED /aktiv REM / 3061 / BL_R_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / BL_R_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / BL_R_IS_LED /aktiv Interior Brake lights: REM / 3061 / BFD_L_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / BFD_L_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / BFD_L_IS_LED /aktiv REM / 3061 / BFD_R_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / BFD_R_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / BFD_R_IS_LED /aktiv Rear fog lights REM / 3061 / NSL_L_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / NSL_L_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / NSL_L_IS_LED /aktiv REM / 3061 / NSL_R_KALTUEBERWACHUNG /nicht_aktiv REM / 3061 / NSL_R_WARMUEBERWACHUNG /nicht_aktiv REM / 3061 / NSL_R_IS_LED /aktiv Followed BMW instructions to the letter and everything else works fine I have installed the wire adaptor kit with wires for the inner indicators going to REM sockets 5 & 13? (on another installation guide it uses different locations in here?) Any help would be great. Also so should there be a brake light on the inner lamps? Many thanks |
07-26-2017, 10:25 AM | #170 |
Rep 54
You need to also code the following:
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_FIXED_PWM = fixed* REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_FIXED_PWM = fixed* REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_PWM_LEVEL_1 = 13.7V [Default]
2015 328i M-Sport - Wagner FMIC, ER Charge Pipes, JB4, Injen CAI, Wagner DP, M-Performance spoiler, M-Performance LED Tail Lights, H&R sport springs, Bilstein Shocks, M-Perfomance Exhaust.
07-26-2017, 10:30 AM | #171 | |
Rep 54
REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_L_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BLINKER_H_R_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_L_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_L_PWM_LEVEL_1 = 100% [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_R_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BRAKEFORCED_R_PWM_LEVEL_1 = 100% [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_L_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_L_PWM_LEVEL_1 = 13.5V [Default] REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_R_FIXED_PWM = fixed REM_01 > LceLampMapping1 3062 > MAPPING_BREMSL_R_PWM_LEVEL_1 = 13.5V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_L_FIXED_PWM = fixed REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_L_PWM_LEVEL_1 = 13.5V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_R_FIXED_PWM = fixed REM_01 > LceLampMapping2 3063 > MAPPING_NEBELSCHLUSSL_R_PWM_LEVEL_1 = 13.5V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_RUECKFAHRL_L_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_RUECKFAHRL_R_PWM_LEVEL_1 = 13.7V [Default] REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_6_OUTPUT = sl_2_l REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_7_OUTPUT = sl_2_r REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_8_OUTPUT = bfd_l REM_01 > LceLampMapping2 3063 > MAPPING_UNIVERSAL_9_OUTPUT = bfd_r REM_01 > LceOutputChannels 3061 > BFD_L_CCM = ccm_blinker_l REM_01 > LceOutputChannels 3061 > BFD_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > BFD_L_UE_SPG_SCHUTZ = dimmed REM_01 > LceOutputChannels 3061 > BFD_R_CCM = ccm_blinker_r REM_01 > LceOutputChannels 3061 > BFD_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > BFD_R_UE_SPG_SCHUTZ = dimmed REM_01 > LceOutputChannels 3061 > BL_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > BL_L_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > BL_L_UE_SPG_SCHUTZ = nicht_aktiv REM_01 > LceOutputChannels 3061 > BL_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > BL_R_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > BL_R_UE_SPG_SCHUTZ = nicht_aktiv REM_01 > LceOutputChannels 3061 > FRA_H_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > FRA_H_L_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > FRA_H_L_WARMUEBERWACHUNG = aktiv [Default] REM_01 > LceOutputChannels 3061 > FRA_H_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > FRA_H_R_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > FRA_H_R_WARMUEBERWACHUNG = aktiv [Default] REM_01 > LceOutputChannels 3061 > NSL_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > NSL_L_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > NSL_L_UE_SPG_SCHUTZ = aktiv [Default] REM_01 > LceOutputChannels 3061 > NSL_L_WARMUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > NSL_R_CCM = NEW_ccm_nsl_r REM_01 > LceOutputChannels 3061 > NSL_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > NSL_R_KALTUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > NSL_R_UE_SPG_SCHUTZ = aktiv [Default] REM_01 > LceOutputChannels 3061 > NSL_R_WARMUEBERWACHUNG = nicht_aktiv REM_01 > LceOutputChannels 3061 > RFS_L_CCM = NEW_ccm_rfs_l REM_01 > LceOutputChannels 3061 > SL_2_L_CCM = Fxx_ccm_sl_2_l REM_01 > LceOutputChannels 3061 > SL_2_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > SL_2_R_CCM = Fxx_ccm_sl_2_r REM_01 > LceOutputChannels 3061 > SL_2_R_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > SL_L_IS_LED = aktiv REM_01 > LceOutputChannels 3061 > SL_R_IS_LED = aktiv
07-26-2017, 07:48 PM | #172 |
515
Rep 1,063
I still havent coded mine lol I already changed all of mine to work with LEDs a few years ago, I just need the codes that enable the blinker on the trunk lights.
07-28-2017, 09:28 PM | #173 |
Rep 589
Ok, mine are installed finally. Holy balls I'm more than pleased with them. I'll up some pics later, but they need to be coded for sure. They don't look ricey at all IMO on the mineral grey. Blends actually quite nicely with the body paint.
And sweet geesus do the LEDs look WAY brighter than my OEM pre-LCI lights. Last edited by LiquidMercury; 07-28-2017 at 09:34 PM.. |
07-28-2017, 10:46 PM | #174 |
Rep 1,297
do post a pic on mineral grey for f30 please =)
2022 M3 xDrive Comp
2020 M2 CS (retired) 2018 M3 Comp (retired) 2015 335i (retired) |
07-29-2017, 01:36 PM | #176 |
Rep 1,297
2022 M3 xDrive Comp
