01-21-2021, 01:31 AM | #3873 |
Rep 551
I believe the power harnesses are unfortunately depending on the unit chosen and the model of BMW (the PX6 harnesses are not the same as the INTEL which are not the same as the S625 etc ...) It would therefore be necessary be able to start the unit and know "its kernel and identifier" to be able to give you valid advice
01-21-2021, 06:38 AM | #3874 | |
Rep 56
01-21-2021, 07:42 AM | #3875 |
Rep 551
Everything in a car is 12V so I'll tell you "yes"
Once connected, go to your Android and Factory settings to take as many photos and information as possible |
01-22-2021, 05:58 AM | #3876 |
Rep 56
Tried to turn it on with a 12V power supply but it won't. Screen stay black although I can see a red led on the board turns on, then off. Did I just fry it or did I buy a brick?
01-22-2021, 06:06 AM | #3877 |
Rep 56
Oh, and I found a label with the rca tv-in set of wires that said "8509 A9", I googled and there was some android unit for F48 x1. Did it mean anything or was it just a generic label? Thanks.
01-22-2021, 07:45 AM | #3879 | |
Rep 56
https://f30.bimmerpost.com/forums/sh....php?t=1687098 Is there a pin for ACC on the back of the screen? |
01-22-2021, 02:18 PM | #3880 |
Rep 551
01-23-2021, 08:29 AM | #3881 | |
Rep 47
thanks. |
01-23-2021, 02:24 PM | #3882 | |
Rep 56
01-24-2021, 08:46 PM | #3883 |
Rep 399
01-24-2021, 09:17 PM | #3884 | |
Rep 56
These are the wires that I've got: And some unknown funky wiring: Last edited by McLarenF1GTR; 01-25-2021 at 01:14 AM.. |
01-25-2021, 05:58 AM | #3885 |
Rep 399
McLarenF1GTR It sure looks like an SD625 unit. The green plug looks like 6 pins LVDS NBT, the blue is for GPS, and you also have a connection for 4G/LTE antenna.
Any seller of these kind of units on Aliexpress should be able to provide harness. |
01-27-2021, 06:01 AM | #3887 |
Rep 47
01-29-2021, 04:43 AM | #3890 | |
Rep 2,367
Drives: E63 645Ci
Aggro6000.00 |
01-29-2021, 05:21 AM | #3891 |
Rep 551
Wish by the way on my HU I noticed seeing an MCU:
615054dALS-NBT-GTH-191129-B18 This reference does not seem to have been referenced on the sharing site you are quoting, so I wish if I can contribute in making it available, and if so, how to do it? |
01-29-2021, 05:22 AM | #3892 |
Rep 2,367
Drives: E63 645Ci
You can send me the file and we shall add it the library.
01-29-2021, 08:08 AM | #3894 |
Rep 4
Hello, I just updated my Unit with
Ksw-P-Userdebug_OS_v3.9.8-ota.zip dGS-CCC-GTL-200617.zip factory_config_BMW_A9_398_A10_157.zip in this order. Everything works fine, but my PDC with Camera is only shown, if I am in reverse gear. Before the update i was able to show PDC+Cam if I press the PDC button in the center console (where the seat heating buttons are). I can hear that the PDC is active, but I have no PCD+Camera screen. Is it a bug? Do I have to Downgrade? How to restore the old behavior? |
